interior lighting kits
Discussion in 'Lighting' started by BlueCoon, Oct 10, 2018.
  1. Oct 10, 2018 at 2:11 PM
    BlueCoon
    BlueCoon [OP] New Member
    2015 Blue Crew Cab Limited
    I have had my 2015 for almost a year now and it came with interior and exterior LEDs. The rear cab brake light has always flicked. I was not aware of the reason or that the truck did not originally come with LEDs so when I recently took the truck in for an oil change I asked them to checkout the light. I was told that the LEDs were not original and that if I left them in that they could cause a shortage or something worse, so they removed them for me. Now the interior LEDs are flickering and I was wandering if there is a conversion kit or some other LEDs that are better suited for my truck? Thank you for your input and excuse the long read.
  2. Oct 10, 2018 at 2:16 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Plenty of people here have used a wide variety of different LEDs. If you search Amazon you will find more than you care to sort through. Personally, i use like to use the best available, even if i have to spend a bit more. VLEDS is the way to go. A little bit pricey but in my opinion worth it.
  3. Oct 10, 2018 at 2:29 PM
    BlueCoon
    Cool, I'll check them out. I'm looking to switch out all the exterior lights too.
