Interior LEDs
Discussion in 'Lighting' started by nowayout, Oct 3, 2018.
  1. Oct 6, 2018 at 1:27 PM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    UGH
  2. Oct 6, 2018 at 9:41 PM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Happened to me as wel. I took it down and put some crazy glue on those points so they don’t go back up in the future
  3. Oct 17, 2018 at 12:28 PM
    TundraLuv
    Kent
    IA
    Just got back from the dealership doing the recall on SRS sensor software update. While I was there I had them look at my map light that was all jacked up. They said they don't sell that particular part separately and will need an entire "overhead console box" which is $432.31. I haven't shopped around (Roman?) but for two map light issues this is turning into a nightmare. Does anyone have a solution for one map light other than replacing the entire overhead console box?
  4. Oct 17, 2018 at 12:50 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Yup, my driver side map light was flickering so I took it out to adjust it, when I tried to put it back in the prongs bent and I so far can’t get in there to straighten it. Btw. Bulbs were from Headlight Revolution, which I don’t fault for this at all, very happy with the LED upgrades.
  5. Oct 17, 2018 at 2:06 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I call BS! Betcha they didn’t even open it. This part connected to the prong tends to break with bulb install mishaps. Pry open the map holder cover, there are 3 small torx holding the console up. Take it down off the ceiling.
    Look to see if the prong is still connected to the part properly. Carefully bend the prong back where it should be grasping the bulb, and flatten out anywhere along its path, Gorilla glue it down if necessary. If it’s broken you can easily Mcgyver a metal bridge, it doesn’t do anything besides make a electrical connection to this which is commonly the problem inside one of those 3 entries.
    Part is Dorman 924-798, less than $20 on Amazon pair.
  6. Oct 17, 2018 at 2:17 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Ahh, awesome!! :bowdown: Should any electrical be disconnected? The one time I tried using a small screwdriver in there I got a spark...
    JoshuaA[QUOTED] likes this.
  7. Oct 17, 2018 at 2:19 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Yes, d/c the battery while you fiddle unless you want to go through a ton of fuses lol.
    Pudge likes this.
  8. Oct 18, 2018 at 12:12 AM
    TundraLuv
    Kent
    IA
    Thanks. Will give it a shot.
  9. Oct 18, 2018 at 8:03 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I just caved and got the VLEDS amber v6 turn signals for my 18, went ahead and got the 4 map LEDs. I got all the other LEDs (foot well, vanity mirror) from Headlight Revolution.
  10. Oct 18, 2018 at 8:38 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I originally bought a cheap set on Amazon for about $15. I was happy at first as I didn’t have anything to compare it to, but pretty soon all my leds started flickering as if they didn’t fit well in the housings. I went back and bought Philips vision leds, and they were more than amazon, but cheaper than the vleds. I will say, my philips bulbs now have no flickering but also fit better, and are much whiter. My others had a blue tint to them.
  11. Jan 11, 2019 at 3:52 PM
    Tundratech
    Tundratech New Member
    How's the brightness of your Philips? Are they current control LEDs?
  12. Jan 14, 2019 at 11:52 AM
    parker44
    parker44 New Member
    This was an old comparison picture of the Philips (left) vs my Amazon lights. I've seen others though where the cheaper lights didn't look as blue as mine, so maybe I got a bad batch.
    I can take a picture tonight of the inside of my truck to show the light. I used to have one but I must have deleted it.
    Tundratech likes this.
  13. Jan 14, 2019 at 1:45 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I used this kit from Amazon by Check It Auto for my wife’s 4Runner and they are working great so far. Provides bulbs for every spot, plus plate lights, and some extras that I don’t even know what for.
    https://www.amazon.com/gp/product/B00FW1JXGO/ref=ppx_yo_dt_b_asin_title_o09__o00_s00?ie=UTF8&psc=1
  14. Jan 14, 2019 at 3:16 PM
    Tundratech
    Thank you for the pictures.
    Philips looks good but maybe I think I wanna go with bigger LEDs? like panel type?
  15. Jan 14, 2019 at 4:25 PM
    parker44
    parker44 New Member
    Not sure what the panel type would be if you are just swapping the bulbs. They are all small and the same size. With the light cover back on, it has more of a “panel” look if that’s what you are referring too.
  16. Jan 15, 2019 at 3:38 PM
    Tundratech
    Finally I found one company makes the panel type LEDs but they don't have it for our Tundra. Emailed them to make them for Tundra and waiting for the reply....
  17. Jan 18, 2019 at 6:46 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  18. Feb 11, 2019 at 2:09 PM
    Tundratech
    Panel type LEDs taking some time so I placed order for the ebay regular LEDs, and after few days, one LED is out......... and not even bright enough....
