Interior LED replacement question
Discussion in '1st Gen Tundras (2000-2006)' started by ps8820, Mar 22, 2025.
  1. Mar 22, 2025 at 3:47 PM
    ps8820
    ps8820 [OP] New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    Would like to upgrade my ClimateControl backlightjng...
    I see @Pinay posted a 2000 Tundra Lighting spec sheet [way back in 2019- thx!]; well done.
    That table shows the 3 CLIMATE CONTROL specs of "T-10"...
    then @ superbrightleds.com they have 5 different form T-10s...
    one even looks like the original 194/168 incandesent bulb w/a LED inside..?
    Yet another couple look like modernized versions of the 194/168 'mini-wedge'.
    So Im asking which one has anyone here used of these w/out blinding or short life results?
    Thx.
  2. Mar 23, 2025 at 6:21 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    • 2x 36mm festoon for map lights
    • 1x 30mm festoon for dome light
    • 2x 194/168/T10 for door lights
    • 1x 74 LED for glove box
    • 1x 3mm for fog light button
    • 3x 194/168/T10 for climate control
    • 2x T5 for climate control
    • 7x 4mm for instrument cluster
    • 4x 194/168/T10 for instrument cluster
    • 20x T5 for instrument cluster
    This thread here covers all of the LED upgrades https://www.tundras.com/threads/gear-indicator-lamp.11916/
    matkes77, Dakillacore, Dracko and 2 others like this.
  3. Mar 23, 2025 at 4:36 PM
    ps8820
    joe
    thx @The Black Mamba.
    ...im being a bit anal on this since I trying to be one & done orderwise [avoid return ship].
    Hard to tell which of the 5 different 194/168/T10's that 'Superbrightleds' lists is correct for ClimateControls. Trying to not get something too bright compared to rest of lighting.
    From their list:
    I would think the cheapest 5SEM: 194-x5-CBT-CAR may be correct, altho Lumens unspecified, so dont really know if it will be too bright or to dim in White?
    Of other 3 listed, seems 194-xCOB1W would be the one [it looks like the OEM Incandcnt] but again no Lumen value given; also need to pull bulbs to measure if 1"x1/2x1/2" is correct size.
    The next choice might also be the 10SEM mini wedge [194-10SMD-x] but again, no Lumen value given, so too bright? And only in 6500k may be more blue than white. [would like some uniformity w/other whites on climate cluster.].
    From their webpage "Map Light Bulb" [same 5 as their "Interior Door Light Bulb" page]
    "2006 Toyota Tundra⁰
    Map Light Bulb
    Note: Newer vehicle electrical systems may require a CAN Bus bulb for operation. Please consult your cars owners manual.
    ⁹ Our Pick
    194 / 168 / T10 CAN Bus LED Bulb - 5 SMD LED Tower - Miniature Wedge Base
    Part Number: 194-x5-CBT-CAR
    Dimensions: 2.612cm (1.03″) x 1.13cm (0.44″) x 1.13cm (0.44″)
    In Stock
    Color Options
    Whites
    Colors
    Pack
    Starting at
    $2.99
    ea.0
    194 / 168 / T10 LED Bulb - 5 SMD LED Tower - Miniature Wedge Retrofit - 95 Lumens
    Part Number: 194-xHP5-CAR
    Dimensions: 2.535cm (1.00″) x 1.214cm (0.48″) x 1.106cm (0.44″)
    In Stock
    Color Options
    Whites
    Colors
    Pack
    Starting at
    $4.99 ea.
    ⁹194 / 168 / T10 CANbus LED Bulb - 10 SMD LEDs - Mini Wedge - Cool White / Amber / Blue / Red
    Part Number: 194-10SMD-x
    In Stock
    Color Options
    Whites
    Colors
    Pack
    Starting at
    $3.99
    ea.
    194 / 168 / T10 LED Bulb - COB LED - T3.25 Miniature Wedge Base
    Part Number: 194-xCOB1W
    Dimensions: 2.54cm (1.00″) x 1.27cm (0.50″) x 1.27cm (0.50″)
    In Stock
    Color Options
    Whites
    Colors
    Pack
    Starting at
    $2.99
    ea.
    194 / 168 / T10 CANbus LED Bulb - 18 SMD LEDs - Mini Wedge - 210 Lumens - Cool White / Amber / Red
    Part Number: 194-18SMD-x
    In Stock Color Options Whites
    Colors
    Starting at$4.99 ea."
  4. Mar 24, 2025 at 2:36 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    G_unit3000 likes this.
  5. Mar 24, 2025 at 9:29 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
  6. Mar 24, 2025 at 10:21 AM
    ps8820
    joe
    thx @w666 & @PNW15.
    So using this specific bulb seems to mimic or blend w/remaining backlight levels?
    IE: Not over-illuminating such that if you adjust Dim/Brightness, the dash cluster is in relative sync with controls cluster?
    Im probly going 'Nat. White' color [4000k].
    Of the 5 types, this seems to mimic the OEM design standard [194/168], so apparently no retrofit issues with a tight mount into the plastic sockets.
    Observation Minutia:
    A bit in the weeds about these LEDs, [Or how the 'apples compare to the oranges' if you will], meaning their stated specs express the equivalence of 10 watt incand. to 1 watt LED. [their rating for this particular LED]
    So, a 10 watt incand. is equivalent to a 1 watt LED ? [Light output?]
    According to Sylvania, etc, a std incand. 168 = 5 watt; 194 = 3.8 watt- 25% difference.
    Would think thats a noticeable difference, so what did Toyota use in the ClimateControl sockets, 168 or 194?
    Like I said, im getting anal and should just be happy I can bring 19yr old lighting back to life...
    Their published spec:
    "Enclosed Fixture Rated Yes
    Equivalency 10 Watt Incandescent
    LED Lifetime 50000 Hours
    Operating Voltage 12-14 VDC
    Oversize No
    Polarity Sensitive Yes
    Reference Number 194/168/T10
    Warranty 3 Year
    Wattage 1 Watt"
  7. Mar 24, 2025 at 10:26 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    I used ultra warm with green covers. This is close to the OEM dash LEDs in my 2006.
    If you go for 4000k they will be too cold imo.
    Lastly. They dim similarly to the factory dash, but not perfect. if you pick too intense of a color or temperature this will exacerbate the inconsistency.
  8. Mar 24, 2025 at 11:24 AM
    ps8820
    joe
    Ok, thanks @PNW15...good info. I might go w/3 - 4000k and 3 - 2500k. Could likely use either in another location if not quite right. I prefer keeping truck near stock, but since my Climates are dead except one, its hard to tell whats green or white.
  9. Mar 24, 2025 at 12:36 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    I did put bright whites of whatever I had lying around in my doors. But that's 4, not three!
  10. Mar 24, 2025 at 2:41 PM
    ps8820
    joe
    being an AC truck, only 2 door lights, so these seem brightest for that purpose, or overheads:
    brand logo Part Number: 194-18SMD-x
    Would help if 'superbrightleds' organized these specific groups in an Excel spread sheet; distilling the specs, I think main differences [beside price and color] in the 5 types listed for what they designate as 'Interior/Map lighting', is current consumption and that some are NOT Dimmable, such as 194-18SMD-x [above] better suited for license plate or door courtesy?...
    Looks like most correct for dash backlighting [depending on color prefernce] is the 194-xCOB1W.
    The COB
    [CHIP ON BOARD type LED] are supposedly more reliable and better output for lower current demand [At least thats what i learned fr/a quik read of an 'industry' website.] AND are the least expensive of their Interior Dimmables for our trucks.
    Heres a long version explanation of COB LEDs:
    https://lumileds.com/technology/led-technology/understanding-cob-leds/
  11. Mar 25, 2025 at 4:07 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    After you settled on your choices, post some pictures--curious to see how they turn out for you and might follow suit. Although my original lights seem to all be working except for the "D" which seems to be common since it probably stays lit up more than others. I'm leaning toward sticking closer to the stock look as well.
  12. Mar 25, 2025 at 9:04 AM
    ps8820
    joe
    @Dblock500...will do.
    Im only replacing HVAC backlights for now, but if my instrument cluster BRIGHT/DIM doesnt sync well w/HVAC backlights, via the dimmer control, I may have to make changes to the instrument backlights...btw, I think '05-06 went to LEDs for 'PRNDL'. You might have already seen threads doing so, but the '00-04' instrument panel LED conversion has been done w/ good success.
