Interior Fuse Box Location and Information
Discussion in 'General Tundra Discussion' started by csuviper, Jan 27, 2016.
  1. Jan 27, 2016 at 10:26 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This question has come up several times so i thought i would add the location and some information on the interior accessory fuse box.
    The fuse box is located under the drives side footwell area. You will have to get on your back on the floor and look up. No need to remove any dash components.
    The fuse box has a cover on it that looks like this:
    Here is the fuse box with the cover off:
    Here are some helpful links related to the fuse box:
    Cigarette lighter power accessories not working
    Underhood fuse box information
  2. Jan 27, 2016 at 10:27 AM
    csuviper
    Broomfield, CO
    Saved
    Wero94 likes this.
  3. Jan 27, 2016 at 10:29 AM
    csuviper
    Broomfield, CO
  4. Jan 27, 2016 at 12:14 PM
    darryljohnsonagency
    darryljohnsonagency New Member
    darryl
    2014 Tundra 1794 edition
    Thanks.....
    I'll look for it after my next meeting
  5. Apr 6, 2016 at 10:29 AM
    TundraGirl
    TundraGirl New Member
    Melissa
    2016 Tundra Crewmax SR5 TSS Off-road
    6 inch lift
    Hi All,
    I went to the dealership yesterday 4/5/16 due to all 4 cigarette lighter outlets not working (fyi my USB outlet works great).
    There are 2 under the radio and A/C controls area, 1 in center console, and 1 for the back seat.
    Service Writer told me I blew 2 fuses - the 15A PWR OUTLET and 15A CIG.
    No sooner than I left the dealership, I plugged in my cheapo phone charger and blew them again!
    I got under the kick panel and pulled the blown PWR OUTLET fuse.
    Is the center console on a separate fuse on a 2016? Are there any additional fuses linked to these damn cigarette lighter outlets?
    Thanks in advance :burnrubber:
    99645 Tundra and geno0506 like this.
  6. Apr 6, 2016 at 10:41 AM
    csuviper
    Broomfield, CO
    PWR OUTLET is the only fuse to the cigarette lighters. I believe the cab lights are on this same fuse. Did you replace with LEDs where you could have bent a terminal and have a short circuit?
  7. Apr 6, 2016 at 10:43 AM
    TundraGirl
    Melissa
    6 inch lift
    No sir, I have not replaces any bulbs/LEDs
  8. Apr 6, 2016 at 11:14 AM
    TundraGirl
    Melissa
    6 inch lift
    I just bought a 10 pack of 15A fuses. After work, I will test a different device other than the suspected phone charger. I am pretty sure it was the cheap phone charger.
    I just bought it and suddenly now I have blown fuses where before, I did not.
    MyFj08 likes this.
  9. Apr 6, 2016 at 12:42 PM
    My guess is it's the cheap charger.
  10. Oct 25, 2016 at 1:20 PM
    abraham
    abraham New Member
    ABRAHAM
    2014 toyota tundra
    led lights, wheels, lift, tires, sound system, underbody lights
    installed led reverse lights and they stopped working as well as backup camera and gears PRND but S still works when shifted into that gear. Sounds like a fuse was blown but don't know which one...
  11. Oct 25, 2016 at 4:08 PM
    abraham
    abraham New Member
    ABRAHAM
    2014 toyota tundra
    that sounds like a great idea, i will go buy one tonight to help find which one might be blown.
    NewImprovedRon likes this.
  12. Oct 26, 2016 at 6:43 AM
    abraham
    abraham New Member
    ABRAHAM
    2014 toyota tundra
    thanks for the help it was the BK/UP LP on the interior fuse box. fixed everything!!
  13. Jan 31, 2017 at 7:49 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    @Sean266 @csuviper @bobeast I'm looking to add a dash cam and hard wire using an add a circuit. Do you guys know which one to use for the cab fuse panel? Thinking it is the ATM mini blade type?
    HackerDaHun and 040Tundra like this.
  14. Jan 31, 2017 at 8:49 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
  15. Jan 31, 2017 at 8:58 PM
    Cutter29
    Cutter29 ...
    Utah
  16. Jun 13, 2017 at 4:42 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  17. Jun 13, 2017 at 6:49 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    This site gives a pretty good overview of the various automotive fuse types.
  18. Jul 16, 2017 at 6:17 AM
    ThorXP
    ThorXP New Member
    2017 Barcelona Red 4x4 Tundra XP
    Thank you for this post. I have installed a Light bar and run the wires through fire wall. But, now I want to change the supplied switch to a more stock switch that I bought from aironboard. I just don't know where to add a circuit in the fuse box in order to illuminate the switch. I want it to work like the other switches in the truck. Thank you in advance!
    csuviper[OP] likes this.
  19. Jul 16, 2017 at 11:04 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    For the AirOnBoard switches there is no need to tap into the fuse box. Every switch on your dash has an illumination wire, so just tap into an adjacent switch using a small PosiTap.
    Ccleme11 and NewImprovedRon like this.
  20. Jul 16, 2017 at 12:36 PM
    ThorXP
    ThorXP New Member
    Thank you for the reply. I don't have a positap....only have a "add a circuit". So having that, where would you recommend I place it?
  21. Jul 16, 2017 at 3:25 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    You'll want to tap into the 7.5A "Panel" fuse as shown on your fuse box cover.
  22. Aug 15, 2017 at 6:27 PM
    Morath1173
    Morath1173 New Member
    Spencer
    2014 1794 tundra
    Does anyone know if you can replace the entire fuse block?? Just bought my used 2014 and fuses were blown and when I checked this is what I got....
    99645 Tundra likes this.
  23. Aug 15, 2017 at 6:56 PM
    SiberianTundra likes this.
  24. Aug 15, 2017 at 7:22 PM
    Morath1173
    Spencer
    2014 1794 tundra
    Truck is from Florida I found out. Not sure what happened
  25. Aug 16, 2017 at 9:16 AM
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    Does it have a clear title? Can you return it? There is no way I would buy a truck with any type of electrical issues. You'll be chasing those down forever.
    Sorry to see that dude.
  26. Aug 16, 2017 at 9:54 AM
    csuviper
    Broomfield, CO
    If you purchased from a dealer they have to disclose if it was in a flood. You should take it back there and get them to inspect and fix if its minor. If in a flood that could be a serous claim against them.
    Jagamov likes this.
  27. Sep 4, 2017 at 9:30 PM
    mscroggi
    mscroggi New Member
    Oh man.. I have seen some tap connectors but I was unaware of these PosiTap ones.. Geez those things look fabulous (watching some youtube demos) ... Also the PosiLock ones..
    Many thanks! I will make use of these soon.. I plan on adding some USB charge ports.
  28. Sep 5, 2017 at 3:28 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I am doing the same. I was going to use the blue wire? on a neighboring switch for illumination vesus a add-a-tap.
  29. Dec 8, 2017 at 1:23 PM
    Jon4542
    Jon4542 New Member
    Jon
    I swear...I have gotten under my driver side dash and cannot locate an internal fuse box. Only the one in the engine compartment....am I missing something. 2014 tundra.
    Jsnake89 likes this.
  30. Dec 8, 2017 at 2:50 PM
    warlord192
    warlord192 Get off my lawn !!
    New Orleans
    2014 Silver Sky metallic Tundra Double Cab
    I have a '14 too and its on the driver's side behind the kick panel alongside the emergency brake.
