Intercooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by GMGood, Apr 5, 2019.
  1. Apr 5, 2019 at 6:33 AM
    GMGood
    GMGood [OP] New Member
    2017 SC CM PRO
    SC, TRD Dual Exhaust, AFE drop in, Upgraded intercooler.
    • Followed a guy's post on another tundra site and upgraded my intercooler on my Magnuson. Here's his post:
    • "Installed a monster sized intercooler heat exchanger Type 101 from frozenboost.com. The core size of the stock one is 18"x12"x1" and this thing is 24"x7"x3.5", so it is almost triple in overall size. I barely managed to fit it in there, all while keeping the stock heat exchanger as well, so in essence I quadrupled the cooling fin area. The fluid first passes through the stock dual pass HE, and then through the new one, which is also dual pass. I have been monitoring the intercooler fluid temps for a couple of years now with a sensor mounted in the oversized coolant tank I am running. While cruising, the temps post S/C were usually around 40-50 degrees F above ambient temperatures these days, without using the Killer Chiller. After installing this upgrade, I am seeing 15-20 degrees above ambient under the same conditions! This is at the hottest point in the system, right after the fluid exits the supercharger intercooler, so I am quite impressed. Nice mod for around $200 for the part and fittings."
    I can confirm my idle and cruising temp is around 8 degrees colder and at WOT then releasing the throttle shows almost a 20 degree drop temperature.
    ViktorG, Saltyhero13 and Wynnded like this.
  2. Apr 5, 2019 at 9:16 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    This thread is useless without pictures......
  3. Apr 5, 2019 at 10:35 AM
    GMGood
    2017 SC CM PRO
    20190404_195654.jpg 20190404_183158.jpg 20190404_213518.jpg 20190404_221526.jpg 20190404_222124.jpg
    Sorry forgot the pictures.
    kbark, MTRock, Saltyhero13 and 4 others like this.
  4. Feb 10, 2020 at 11:31 AM
    Rezzy805
    Rezzy805 New Member
    ‘14 limited pro build
    can You confirm the amount of fittings needed? I see the pic where you have five of each but the installed pic looks like only two of each is needed?
  5. Oct 14, 2020 at 3:16 PM
    FSTsink
    FSTsink New Member
    Hey there,
    Thanks for sharing. Where do I go about finding the tube and fittings. What size is the tube? Thank you.
    HulkSmurf14 likes this.
  6. Oct 15, 2020 at 6:47 AM
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    That's pretty slick. Thanks for sharing.
  7. Jul 22, 2021 at 3:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Any verdict on this addition? Did it lower AI temps...aka...increase power in a sense?
    nags likes this.
  8. Oct 28, 2022 at 12:05 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Bringing back from dead. Observe lower intake temps?
    Saltyhero13 likes this.
