Intake manifold and valve cover gaskets.
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 5, 2019.
  1. Jan 27, 2019 at 8:13 PM
    bmf4069
    bmf4069 [OP] WHO KEEPS CHANGING THIS!
    Beau
    TX
    02 AC sr5 4wd v8
    After about 30 miles and 5 stops, the burning oil smell is dissipating. I think it's just burning off residual oil now.
  2. Jan 28, 2020 at 7:52 AM
    WhiteTundrax2
    WhiteTundrax2 New Member
    2010 White Toyota Tundra CrewMax 5.7
    Hey guys, I have a question.
    Do I have to drain the coolant to remove the intake manifold on a 5.7 liter? Some rats got into my knock sensor wires, just wondering before I have to drain my coolant.
    And should I replace my intake manifold gaskets while I’m at it?
    Thanks!
  3. Jan 28, 2020 at 8:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Bumping this old post. I wonder why people say the starter replacement is so difficult. Looks like you have to pull the throttle body first but is it really that bad after that? Can you pull the intake manifold in an hour?
  4. Jan 28, 2020 at 9:01 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I know this is a year old but I think you put your spark plug tube seals in upside down. Probably wont be to big of a deal but something to keep an eye on.
  5. Jan 28, 2020 at 3:21 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I just pulled the 2 nuts and 2 bolts to remove the TB from the intake. I bet I can have it off in 45 minutes now.
    They're the same. I didn't realize it had those stupid tabs that have to bend down.
  6. Jan 28, 2020 at 3:41 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Yeah I was wrong, I may have put mine on upside down now that I think about it!!
  7. Mar 21, 2020 at 7:46 PM
    Waterboyz
    Waterboyz New Member
    Fredericksburg VA
    2006 Silver Tundra X-SP Double Cab 2WD 18" Wheels
    While we are talking valve covers, does anyone have the part number for the washers with the rubber on the bottom that holds down the cover? There are 18 of them. My local dealer gave me the part number but it is for the flat washers for the head bolts.
    Thanks......
    2006 X-SP 4.7 2wd SR-5 double cab
  8. Mar 22, 2020 at 8:46 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I believe it's 90210-07001. Double check me, I've just started researching all the OEM P/Ns.
    11213-50031 Gasket - qty= 1
    1214-50011 Gasket - qty = 1
    11193-70010 Tube Seal - qty = 8
  9. Mar 22, 2020 at 3:27 PM
    Waterboyz
    Fredericksburg VA
    Thanks for the quick reply.
    That website came back with the cover gaskets not fitting my truck.
    These are what it gave me.
    11214-0F010
    11213-0F010
    https://www.toyotapartsdeal.com/oem...4=SR5;5=ATM;6=5HC;7=DCB;9=SD;0=UCK31L-PRBSKA)
    I copied in your washer part number and it came back as "not for my vehicle."
    Huummmmm
    Side rant.....I have been working on machines for 35+ years and have never seen such a crappy online parts lookup. Even the old days of micro-fiche was better.
  10. Mar 23, 2020 at 4:03 AM
    w666
    Maryland
    Sorry, my bad...I was searching for my Land Cruiser. Same engine, but perhaps slightly different P/Ns. I share your frustration with the parts look up.
