Intake and Fiberglass Fenders
Discussion in 'Long Travel Suspension' started by tbrown, Aug 18, 2020.
  1. Aug 18, 2020 at 8:03 AM
    tbrown
    tbrown [OP] 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Has anyone found any good solutions for protecting the intake in the fender well after adding fiber glass fender? i dont really care if its a fully covered fender well, just looking for a way to not rock a fully exposed intake.
    831Tun likes this.
  2. Aug 18, 2020 at 8:08 AM
    TXTundra2722
    2015 Black Tundra
    :popcorn:
    I've been sitting on my glass fenders for awhile sure to other things, but this is on the list.
    tbrown[OP] likes this.
  3. Aug 18, 2020 at 10:56 AM
    tbrown
    Nashville, TN
    Mine have been fitted and are being painted now. Final long travel parts get in Thursday. I have looked this up in the past and i never seem to find a solution. Seems like most people just run them open.
  4. Aug 18, 2020 at 12:55 PM
    TXTundra2722
    2015 Black Tundra
    what was the cost of paint? I guess fitment is included in that cost
  5. Aug 18, 2020 at 1:32 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you are going fiberglass fender, maybe look into modding a snorkel that would fit- would probably solve your issue and they look awesome on Tundras
  6. Aug 18, 2020 at 1:50 PM
    tbrown
    Nashville, TN
    I’ve gone down this rabbit hole, and I can’t get myself to love the look :crapstorm:
    rockmup likes this.
  7. Aug 18, 2020 at 1:54 PM
    tbrown
    Nashville, TN
    im not a good one to ask because I added a bunch of stuff. I’ll probably be 6k or so all in. A good chunk was figment, lines and trimming were done perfect and it looks factory, took a good bit of work. We sprayed inside with a bed liner type material. We painted entire truck except for roof (instead of blending cab and doors had him do this because doors has chips and scratches, and front was a little off from grille surround to hood so we corrected) and did a clear bra. Could have gotten cost way down but I don’t have time to do any of it myself and had them do a lot of extra stuff. If you have time you can hang everything and get it pretty close yourself.
  8. Aug 18, 2020 at 2:08 PM
    Kelvin
    Kelvin New Member
    On my 4Runner when I chopped the fenders and ran everything open I just slipped a pre-filter over the intake portion that stuck out into the wheel well. This was just a cheap, and very quick, idea that I came up with.
    Other ideas I’ve seen were cut up trash can plastics to form a shield along the perimeter of the wheel well. L-brackets to hold them on. This one also protects the paint on the inside of the fiberglass fenders from chipping.
  9. Aug 18, 2020 at 2:32 PM
    tbrown
    Nashville, TN
    good stuff! Thanks!
  10. Aug 18, 2020 at 3:20 PM
    The air injection pump intakes will be exposed too with a LT setup. I recommend this kit from SDHQ....https://sdhqoffroad.com/products/07...uilt-secondary-air-pump-intake-relocation-kit
    tbrown[QUOTED][OP] likes this.
  11. Aug 18, 2020 at 7:08 PM
    tbrown
    Nashville, TN
  12. Aug 19, 2020 at 7:58 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I made an invisible snorkel. I didn’t want anything sticking out and catching on trees and shit.
    it draws from the cowl like an old muscle car.
    my wife and I dumped two five gallon buckets on the windshield at the same time to try and simulate a big splash like we often hit during the monsoons in AZ. Bone dry.
    https://www.instagram.com/p/BWDflkxhXBx/?igshid=gnkwbrfxh4y6
    A5367BDE-6A2C-4CDC-98E1-064D26BEC6C9.jpg 354D4816-4C38-4D9F-ADCA-A7D606A8B93D.jpg
  13. Aug 19, 2020 at 8:34 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    TXTundra2722 and tbrown[OP] like this.
  14. Aug 19, 2020 at 8:40 PM
    tbrown
    Nashville, TN
    Followed your adventures and love every bit of it. I almost just messaged you directly when I went down this path lol thank you for this!
    KevinK[QUOTED] likes this.
  15. Aug 19, 2020 at 10:39 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'll try and get ya some pics tomorrow. But, basically I cut up the OEM liner, pushed it farther up and have a cone filter mounted high up in the wheel well.
    joonbug likes this.
  16. Aug 19, 2020 at 11:05 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Having problems getting the 2nd (more important) photo off my phone due to all the smoke here I think. But, here's the first oneintake.jpg
    joonbug, KevinK and tbrown[OP] like this.
  17. Aug 20, 2020 at 9:17 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's hard to see but the metal fitting next to the filter has a tab that's bolted to the inner fender. The whole thing is an Injen intake with a couple pieces added to make it longer
