Instrument Panel LED Conversion
Discussion in '1st Gen Tundras (2000-2006)' started by Cybertek, Aug 25, 2021.
  1. Aug 25, 2021 at 8:34 AM
    Cybertek
    Cybertek [OP] 67 Tons of Romping, Stomping mean!
    William
    Pensacola, FL
    2006 Tundra Double Cab 2WD SR5
    None
    I searched the forums for this, could not find anything related so thought I would show off my rookieness. A wise leader of mine told me once that everyone has to be a rookie sometime:)
    Is it possible to convert the lighting in the instrument cluster to LED so that it is brighter at night. I ask because with all you folks' help(Thanks BTW) I finally finished the Center cluster, Map/Dome/Door & footwell converted to LED, still need to do the glovebox. Now that these are all converted it is so bright, when I use the brightness control to turn them down, it also makes the dash lights very hard to see because they are still the old dull original. So is what I want to do possible, or is there another solution?
  2. Aug 25, 2021 at 8:41 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    edit: 2000-2004 trucks only. 2005-2006 see post #4.
  3. Aug 25, 2021 at 8:41 AM
  4. Aug 25, 2021 at 8:42 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    2006Tundra, tunyota and des2mtn like this.
  5. Aug 25, 2021 at 8:44 AM
    des2mtn likes this.
  6. Aug 25, 2021 at 9:36 AM
    Cybertek
    William
    Pensacola, FL
    None
    Wow! Thank you so much everyone, I will do dig into all the info you have provided. I will followup with my results ASAP, salute!
  7. Aug 25, 2021 at 1:08 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    This is super helpful! What bulbs are the P, R, D lights? Also, were you able to reuse the base connectors for the t5 lights. I tried on the climate controls with some Amazon lights that had the base already on them, but they didn't fit.
    @des2mtn (I thought I copied your post, but it didn't work)
  8. Aug 25, 2021 at 1:32 PM
    des2mtn
    Shady Grove
    Tonto cover
    Oops, forgot that the 05-06 has a different cluster. But for your Sequoia the PRND2L should be T4.2 Neowedge. These worked for me https://www.amazon.com/gp/product/B013HJGOAA?ie=UTF8
    They're polarity sensitive so definitely make sure they all work before you put it back together.
    I was able to use all the OEM connectors for the climate control lights (T5 & T10).
  9. Aug 25, 2021 at 1:42 PM
    rock climber
    Thanks! It is for the sequoia.
    des2mtn[QUOTED] likes this.
  10. Aug 25, 2021 at 1:53 PM
    des2mtn
    Shady Grove
    Tonto cover
    richsadams likes this.
  11. Aug 25, 2021 at 11:57 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Quoted from @Tundra2
    Don't want the check engine, low fuel, battery, or air bag light light to be led or they won't work properly. Is that why your low fuel light doesn't work?
    Tundra2[QUOTED] likes this.
  12. Aug 25, 2021 at 11:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I learned from @empty_lord that the the bulbs I didn't replace with LED act as a resistor for the the circuit. I did replace some of those with a new incandescent while I was in there.
  13. Aug 26, 2021 at 12:01 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well just the fuel light does.
  14. Aug 26, 2021 at 12:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yeah, that one...
    des2mtn likes this.
  15. Aug 26, 2021 at 3:02 AM
    des2mtn
    Shady Grove
    Tonto cover
    Nah, it's just my fuel light that doesn't work. The others are fine. Thanks for the clarification @empty_lord
    Tundra2 likes this.
  16. Sep 27, 2021 at 12:14 PM
    rock climber
    Does anybody know where the cruise lights is on an 01? I replaced the park and drive lights and now my cruise light doesn't work. Probably bumped it while I was in there. Crusie works fine, just not the light that says cruise
  17. Sep 27, 2021 at 3:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Most are down next to check engine. I have in past shined a flashlight at instument cluster where they might be and could see the words or indicator....in your case the word cruise !
  18. Sep 27, 2021 at 8:57 PM
    NickB_01TRD
    Nick
    KY
    Stolen from @Tundra2
  19. Sep 28, 2021 at 4:01 AM
    Jcross0304
    Jcross0304 New Member
    Johnathan
    2006 Tundra SR5 DC 4wd
    Could you post pictures of the center cluster? I also have an 06 and would like to see this. Have you done anything with the instrument cluster?
  20. Sep 28, 2021 at 10:12 PM
    empty_lord
    05 rollover special
    The 05-06 have soldered on LEDs. You can replace them technically but it’s a bit of process. I sanded off the green on the cluster face and enjoy the white with green accents now. (Ignore my sometimes dead coolant gauge)
  21. Sep 29, 2021 at 4:34 AM
    Jcross0304
    Johnathan
    For some reason I can not see your picture.
    Tundra2 likes this.
  22. Sep 29, 2021 at 4:36 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Here's a screenshot of his image. Try this one.
  23. Sep 29, 2021 at 5:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Why is your coolant guage dead?
    FirstGenVol likes this.
  24. Sep 29, 2021 at 5:08 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    From time to time when I visit a page, certain pics won’t be visible, just a place marker. Refreshing page fixes it usually !
  25. Sep 29, 2021 at 5:16 AM
    Jcross0304
    Johnathan
    Got it thanks!
    It seems to only be @empty_lord pictures though. I did run across one from @Lil Steve on @Tundra2 "Crackhead Resurrection" Thread. So I dunno.
  26. Sep 29, 2021 at 5:37 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    This is something that we will never experience my friend.
    bmf4069[QUOTED] likes this.
  27. Sep 29, 2021 at 8:01 AM
    empty_lord
    05 rollover special
    If coolant temp is under 75 degrees when I start the truck it doesn’t work. If it’s above 75 it works fine. Something wrong with the servo on the cluster
  28. Sep 29, 2021 at 8:02 AM
    empty_lord
    05 rollover special
    I use discord to host photos. If your at work they may be blocked
  29. Sep 29, 2021 at 8:26 AM
    Jcross0304
    Johnathan
    Busted :rofl:
    Tundra2 and bmf4069 like this.
  30. Oct 16, 2021 at 9:25 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Hopefully doing this mod this week when my LED come in. Anyone figure out how to replace the cigarette lighter bulb?
    Tundra2 likes this.
