Instructions for custom tuning the truck with HPTuners.
Discussion in 'Performance and Tuning' started by ViktorG, Jul 9, 2020.
  1. Jan 7, 2023 at 10:26 AM
    #91
    Vizsla
    Vizsla pretend2send
    Torque converter flex lock up is used to partially lock the torque converter under light throttle driving conditions to improve fuel economy
    Saltyhero13 likes this.
  2. Jan 7, 2023 at 10:59 AM
    #92
    centex
    centex New Member
    Partially lock?
  3. Jan 9, 2023 at 4:02 PM
    #93
    centex
    centex New Member
    What pid’s are y’all using for logging? I downloaded some layouts I found on hptuner forum but I guess they are to old for my version to open.
  4. Jan 10, 2023 at 8:37 AM
    #94
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    It will duty cycle the lockup solenoid to achieve flex lockup. I don't believe the tundras use flex lockup too aggressively but on a lot of the new 8 speed cars like the camry and highlanders you can feel it. I absolutely hate how it feels but its supposed to help for fuel mileage.
    mustang67408 and Saltyhero13 like this.
  5. Jan 10, 2023 at 8:51 AM
    #95
    centex
    centex New Member
    Ah. That's a big factor in the chevy converters failing. That constant partial slipping of the lock up converter takes it's toll after a while. Best thing to do is set it for 0% slippage, at least on the chevy's.
  6. Jan 10, 2023 at 9:29 AM
    #96
    ssmokedz
    Shelton CT
    Yup it takes its toll on Rav4’s Camrys and sometimes the Tacomas too. I see some Tundra ones failing but they are usually high mileage and poorly maintained.
  7. Jan 10, 2023 at 9:33 AM
    #97
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Rpm, MAF voltage, MAF airflow, knock feedback, knock correct learn, actual spark, throttle position, EQ ratio 1 and 5, EQ commanded, long term fuel trim, IAT, ECT, Trans Gear, TCC locked, Injector DC
    M3Tundra-JK, sd172 and centex[QUOTED] like this.
  8. Jan 13, 2023 at 12:35 PM
    #98
    centex
    centex New Member
    Anyone ever play with max throttle angle? Mine is set at 86* which I know isn't unheard of through various makes.
  9. Jan 13, 2023 at 1:33 PM
    #99
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    On the Tundra, that is the max.
  10. Jan 13, 2023 at 2:30 PM
    #100
    centex
    centex New Member
    Figured as much.
  11. Jan 17, 2023 at 12:34 PM
    #101
    M_RED
    M_RED New Member
    Infinite Gratitude for this thread, I can't wait to get my hands on an MPVI2 that my brother has... It's going to be fun!
  12. Jan 17, 2023 at 12:47 PM
    #102
    snivilous
    SW UT
    I've read about people increasing it, I think on Tacomas (I guess to 90deg?) but that it's set at 86 to prevent the valve jamming, and the flow difference is effectively negligible anyways.
    Wynnded and Saltyhero13 like this.
  13. Jan 17, 2023 at 1:34 PM
    #103
    centex
    centex New Member
    Got my first log done and it's about what you'd expect from a stock truck with an intake and a muffler. Need to add maybe a bit to the MAP scaling but not much. Need to go back and re-read what the knock learn and feedback is and how to interpret. The IAT's are interesting. It's the rough country intake (previous owner, not my choice) and sitting at idle the IAT's are 10* higher than ambient, cruising they are 20-30*, and at wot I'm seeing 30* or more.
  14. Jan 17, 2023 at 1:43 PM
    #104
    snivilous
    SW UT
    That's interesting. My stock style airbox is within 5deg of ambient when moving. Parked it can vary a lot, in the summer if it's 100+ out in a drive through the IAT will climb to 200F.
  15. Jan 17, 2023 at 1:44 PM
    #105
    centex
    centex New Member
  16. Jan 17, 2023 at 5:21 PM
    #106
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Has anyone got a wideband 02 sensor to communicate into HP and datalog it?
    I have my Innovate PSB-1 hooked up through the analog output to laptop and it's not happy. I just bought another serial to usb adapter to see if that works at all.
  17. Jan 17, 2023 at 5:41 PM
    #107
    centex
    centex New Member
    Need the pro package for that I believe. There may be other ways as I’ve seen LS folks tie a wideband into a different sensor and then adjust the values from there.
    ZPhilip likes this.
  18. Jan 20, 2023 at 9:59 AM
    #108
    centex
    centex New Member
    First tank with the first rev tune showed a .7mpg increase. Last three tanks have been 12.5 and this one was 13.2 and that’s with a lot more high speed 70+mph driving and stop and go. Need to get back on the tune and keep tweaking.
    ZPhilip likes this.
  19. Feb 11, 2023 at 9:28 PM
    #109
    ryanallaire
    ryanallaire New Member
    Ryan
    2010 CM 5.7
    3" RC leveling kit, S&B intake, custom DIY exhaust, tuned for 91 octane, morimoto headlights, all LED interior lighting.
    So from what I'm gathering here, you start with the preloaded TRD tune and make adjustments from there?
  20. Feb 12, 2023 at 5:22 PM
    #110
    snivilous
    SW UT
    Start out with whatever tune HPT gives you. When you "read ECU" it doesn't actually read it, it'll just download to your computer what the stock calibration tune is, which if it was originally a TRD tuned truck will be the TRD tune it downloads. The TRD tune isn't anything special in and of itself. I tuned a guy's truck a few weeks ago and he sent me the stock file that HPT downloaded and I modified it from there.
    mustang67408 likes this.
  21. Feb 13, 2023 at 6:31 AM
    #111
    ryanallaire
    Ryan
    2010 CM 5.7
    Oh ok, do you get a second file just to have a 'stock' tune to revert back to in case of issues?
  22. Feb 13, 2023 at 6:53 AM
    #112
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    With Hp, you read the stock file before it is modified and save the file somewhere you won’t lose it as the stock file. The stock file is then modified and as revisions are made you just save the revised file and name it accordingly.
  23. Feb 13, 2023 at 8:11 AM
    #113
    ryanallaire
    Ryan
    2010 CM 5.7
    Thanks for clarifying, does the module come with a cable to connect it to a laptop? I've added the prolink+ cable but don't see anything about the obdII cable...
  24. Feb 13, 2023 at 8:13 AM
    #114
    ryanallaire
    Ryan
    2010 CM 5.7
    Also does anyone know if you can read and clear dtc's on other vehicles?
  25. Feb 13, 2023 at 8:26 AM
    #115
    Silver17
    Northeast
    The MPVI2 comes with a cable, yes. Not sure about your DTC question.
  26. Feb 14, 2023 at 1:25 PM
    #116
    ryanallaire
    Ryan
    2010 CM 5.7
    Thank you. I found out you can use the scanner on other makes/models, i'm inquiring to see if there's any datalogging capability as well..
    Silver17[QUOTED] likes this.
  27. Feb 14, 2023 at 1:58 PM
    #117
    Silver17
    Northeast
    Data logging with the MPVI2 is done with VCM Scanner.
  28. Feb 14, 2023 at 2:03 PM
    #118
    ryanallaire
    Ryan
    2010 CM 5.7
    Sorry I meant datalogging on other makes/models..
  29. Feb 14, 2023 at 2:04 PM
    #119
    ryanallaire
    Ryan
    2010 CM 5.7
    Also the one i bought is the MPVI3, not sure if that makes a difference..
  30. Feb 14, 2023 at 2:05 PM
    #120
    snivilous
    SW UT
    https://www.hptuners.com/vehicles/
    This is the list of all the supported makes and models with the MPVI port/cable.
    Wynnded and Silver17 like this.
