Installing Sub to stock stereo - my install
Discussion in 'Audio & Video' started by csuviper, May 28, 2015.
  1. May 28, 2015 at 11:02 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    So i decided to document my install. Made the install take a little longer but might give others ideas about how to go about their own install.
    Line Output Converter: AudioControl LC2I 2-Channel Line Out Converter and Subwoofer Control
    Sub: Sony Xplode XS-L1035
    Sub Enclosure: Custom built by myself using 3/4" thick MDFB
    Amp: MTX Audio
    Wire Kit: Lightning Audio by Rockford Fosgate 8 Gauge Amplifier Installation Wiring Amp Kit
    Add a fuse holder: Bussmann BP/HHH ATM Add-A-Fuse
    Base control knob: ACR-1 Remote Level Control installed in switch blank curtsy of @TruckyTruck
    Concept drawing of the sub box.
    Using the table saw to cut the MDF.
    Drawing the hole for the sub. Used a drill bit, cardboard and pencil.
    Started the main hole using a whole saw and then moved to a saber saw to complete. Finished off with sander.
    Progress of the enclosure.
    Enclosure screwed together.
    Completed custom sub enclosure with sub installed. Nothing fancy but it does the job. It is painted with Rustoleum truck bed liner.
    Chose to place the fuse for the amp in the engine compartment fuse box. Drilled two small holes and used grommets to seal it up with the wire. These were the two locations that made sense that i could get a drill to without removing the fuse box and wireclips.
    Close up of the fuse siting in the fuse box
    Chose to put the LOC in the space under the cup holders. Had to drill a hole in the side where the storage space is to feed all the wires through.
    Close up of the hole with wires to the LOC
    Chose to run the power, accessory and RCA cables from the stereo to the amp in the wire runners under the plastic panel by the door. Not sure what they are actually called.
    To get to the stereo you have to remove the cup holders, the center console single cup holder/storage piece, cig ligher section and A/C controls before finding the 4 bolts that need to be removed for the stereo.
    Closer pic of the stero showing the bolts to be removed.
    An add a line fuse holder was used to provide accessory power to the amp. This plugs into either an open slot or an occupied slot. The add a line fuse holder has two spots for fuses. One as a replacement of the existing fuse and one for the new wire that you can connect to.
    Add a line fuse holder installed (bottom of pic with 10A fuse sideways)
    LOC in position. Wires not cleaned up yet.
    Removed the rear seat to be able to run the amp wiring under the carpet.
    Connection of power and ground for the LOC to the cig lighter accessory outlet.
    Amp in position under the seat and wires pulled under the carpet.
    Base adjustment knob installed in the switch blank (provided to my by @TruckyTruck from his previous install)
    The ground connection point that i chose was next to the rear seat belt piller. It is the ground point for the rear window motor.
    Close up of the ground connection.
    Amp in position and wired up.
    Close up of the wires pulled through the carpet.
    Amp in position and seat installed.
    Removing the center console single cup holder and storage section. Just pull up and it pops off.
    Completed look at the battery. No wires show for the amp install.
    While i was doing the install i decided to clean up the battery terminals and replace the rusted and acid covered battery hold down with an aftermarket rubber hold down that i found at Advance Auto. Snug fit. Just need to trim the supports down.
  2. May 29, 2015 at 5:02 AM
    msg148
    msg148 Hulk Smash
    Philadelphia
    15 Tundra Platinum Package
    7" BDS coilover lift kit w/Fox front and rear suspension, 20" Monster 2 Rims, 37" Deegan Tires, TRD Exhuast, TRD Intake, Bushwacker Pocket Flares, Blacked out Mirrors/Door handles, LED interior lights, Stubby Antenna, Bakflip F1 Tonneau Cover, 20% Tint Front windows
    Looks like a lot of fun. Thanks for the write up.
  3. May 29, 2015 at 9:59 AM
    csuviper
    Broomfield, CO
    Updated with descriptions for each pic.
  4. May 29, 2015 at 1:22 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    This is an awesome thread! I really like what you did with the fuse box hiding the main amp fuse. I might have to do that one. I'd really like to to see how your rear seat sits with the box and what you think of the bass you get from it.
  5. May 29, 2015 at 1:26 PM
    csuviper
    Broomfield, CO
    I will provide pics of the sub enclosure behind the seat this weekend.
    As far as sound i haven't messed with it much yet. Sounds decent so far though.
    If you didn't see the other thread yet, the base knob doesn't work. Ill try a different cord this weekend but right now no light and no adjustment.
    Phillip likes this.
  6. May 29, 2015 at 1:30 PM
    TruckyTruck
    Gary
    I saw that just now. That really stinks.
  7. May 29, 2015 at 3:44 PM
    Engineers and your perfect design cuts...
    FlashCulprit likes this.
  8. May 1, 2016 at 6:41 PM
    montej23
    montej23 New Member
    Nice work
    Phillip likes this.
  9. Nov 16, 2016 at 5:58 AM
    markiemark9
    markiemark9 New Member
    Mark
    Omaha, NE
    2016 SR5 TRD Crewmax
    RC 3/1 Leveling Kit, Blacked-out badges, stubby antenna, Husky floor liners, spray bedliner, low-profile toolbox, paracord wrapped grab handles, 33" Toyo Open Country M/T Tires,TRD Pro Headlights w/ LED Conversion,TRD Pro Grill, BAM TRD Replacement exhaust, TRD Shift Knob, TRD Rear Swayback bar
    Is your pickup a crewmax or doublecab? Trying to replicate this in my DC and need some measurements for the box to fit behind my rear seats.
  10. Feb 27, 2017 at 2:12 PM
    NAXD
    NAXD New Member
    Nate
    2017 Tundra SR
    35" Mickey Thompson Baja ATZ on 20" Fuel Couplers 3" x 2" level lift Corsa db cat-back exhaust K&N Air Intake
    Great job - I know this was a couple years back, but I just did this on my 2017 Tundra SR Dbl cab with an LC7i, Rockford 250x4 amp, Rockford PS8 with Rockford speakers in doors, all mounted under the rear seat... and funny thing, I did the exact same thing with my power/fuse in the fuse box ;)
    If anyone has questions on the install or needs help, I have some good info, having researched the heck out of this and just did it myself... happy to help! (Wiring diagrams, pics, advice, etc)
    Pork Pistol and JackWagon like this.
  11. Apr 11, 2017 at 4:26 PM
    Tundra13jr
    Tundra13jr New Member
    concord nc
    2017 Toyota Tundra 4x4 magnetic grey
    I have all the stuff to install (subs ,wires, amp,fuses) just don't know where to begin lol i want to use the stock head unit.
  12. Apr 19, 2017 at 7:22 AM
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    About to install a sub box in my 2017 Crewmax...hoping there is enough room behind the rear seats! Also installing a 5 channel amp and door speakers. Using a JBL processor.
  13. Apr 21, 2017 at 7:13 AM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    Did you have JBL or Non-JBL? I'm looking into replacing the factory speakers/amp. I've already got subs/amp waiting to go in.. Just not sure what to do about speakers yet.
  14. May 12, 2017 at 8:47 PM
    Ramon
    Ramon New Member
    Orasio
    2017 SR5
    Head unit sound system
    Awesome post bro. By any chance do you know or remember the angles of the cuts for the box?
    Idaho Tundra likes this.
  15. Jul 20, 2017 at 10:55 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Pretty damn cool.. I dont know how you guys do al this wiring stuff.. looks good tho.. no pics of how the box looked in the truck? D.C. Or CM
  16. Jul 31, 2017 at 7:51 PM
    Pork Pistol
    Pork Pistol Oh queso, let's do this
    Rob
    DFW, Texas
    2017 Tundra DBC SR5 TSS Off-Road 4.6L
    Slight
  17. Aug 10, 2017 at 5:52 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    Looks pretty nice...
  18. Dec 28, 2017 at 11:11 AM
    csuviper
    Broomfield, CO
    Here are the dimensions if anyone wants them
  19. Dec 30, 2017 at 12:31 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Question - has anyone tried to do an under set flush/shallow mount 10 or 12 in a gen 2 CrewMax?
    I woke up one night thinking it could be done so that the seats still move forward and back and and recline.
  20. Dec 30, 2017 at 2:22 PM
    TruckyTruck
    Gary
    I really doubt it. If you could, you certainly couldn't lower the seat back down.
    DalTee[QUOTED] likes this.
  21. Dec 30, 2017 at 9:33 PM
    csuviper
    Broomfield, CO
    Only room for an amp from what I recal.
  22. Dec 31, 2017 at 2:20 AM
    DalTee
    DalTee New Member
    Dal
    Ok thanks
  23. Dec 31, 2017 at 2:21 AM
    DalTee
    DalTee New Member
    Dal
    My back seat reclines - seat bottom doesn’t fold
  24. Dec 31, 2017 at 5:00 PM
    TruckyTruck
    Gary
    I assume we have the same type of seats... Your seat backs don't fold down flat?
  25. Dec 31, 2017 at 5:43 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    14 and up crewmax seats are different.
  26. Dec 31, 2017 at 5:56 PM
    TruckyTruck
    Gary
    Yes, but his profile says 2011 crewmax
  27. Dec 31, 2017 at 5:58 PM
    Berdine
    Binghamton, NY
    Sorry didn't look at that
    TruckyTruck likes this.
  28. Dec 31, 2017 at 11:00 PM
    DalTee
    DalTee New Member
    Dal
    Yes they do
  29. Feb 8, 2018 at 7:57 AM
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    I'm guessing these measurements for a single sub enclosure would work for someone wanting to put a duel subwoofer setup behind the back seats of their 2016 CrewMax?
  30. Feb 8, 2018 at 12:50 PM
    Berdine
    Binghamton, NY
    Double the width. I know audio enhancer box is 50" wide for 2 subs. Few others are 48" wide.
