Installing LED in Spyder projector beam headlight
Discussion in 'Lighting' started by dmr, Dec 4, 2019.
  1. Dec 4, 2019 at 2:50 PM
    dmr
    dmr [OP] New Member
    Dave
    2007 Toyota Tundra DoubleCab Limited
    Amateur hour here. I ordered new Spyder projector headlight housings for my ’07. I have H11 LED lamps. The product stated it accommodates H11, but it came with a halogen bulb and fitting that I can't imagine how to attach my LEDs. Thoughts? Thanks! AE6D5C2D-BE5A-462C-933B-35B7914B2AA7.jpg
    Headlight Revolution and Rica25 like this.
  2. Dec 4, 2019 at 3:36 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I believe they wre incorrect. That housing will ONLY accept H1 bulb. H11 bulb look similar to our 9006 and 9005 bulb. There is no way you can fit h11 into that h1 housing.
    Rica25, zachzap361 and dmr[OP] like this.
  3. Dec 4, 2019 at 3:38 PM
    dmr
    dmr [OP] New Member
    Dave
    I think you are correct. I may have some h11 led’s for sale. Two weeks old.
    Rica25 likes this.
  4. Dec 4, 2019 at 3:41 PM
    dmr
    dmr [OP] New Member
    Dave
    Heh, except vled doesn't make h1 led’s...what an expensive endeavor this has been.
    Rica25 likes this.
  5. Dec 4, 2019 at 3:44 PM
    BrandonL812
    Brandon
    You can still return the spyder headlights, right? Unless you want to keep them. You can always do retrofit with better projects for much better output.
    Rica25 likes this.
  6. Dec 4, 2019 at 4:06 PM
    dmr
    dmr [OP] New Member
    Dave
    I'm def not the guy to do a retro myself. Unsure where to even begin.
    Rica25 likes this.
  7. Dec 4, 2019 at 4:39 PM
    BrandonL812
    Brandon
    They can be expensive, that's for sure. I would email the people at lightwerkz.net for a quote.
    Kustom54lighting also does them.
    It's probably cheaper on your lights because they are swapping projectors instead of a full retro.
    dmr[OP] likes this.
  8. Dec 4, 2019 at 4:43 PM
    dmr
    dmr [OP] New Member
    Dave
    Thanks very much for your help! Much appreciated.
    Rica25 and BrandonL812 like this.
  9. Dec 4, 2019 at 5:45 PM
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    Correct and wish I saw this sooner, have a lot of experience and was in the same place you were a few months ago.
    So quickly, 1 spyder's do not come in (for whatever reason) the exact bulb you run. Mine came with H1 high beam and H7 low beam if im not mistaken, and my truck came with H11, so bought those bulbs and was like wtf. To add on to that the headlights were wired up with a H11 port to run into the main housing so they did work just with different bulbs. I wanted LED's like yourself so was confused on what to do.
    2. I would look at the bulbs sizes that are in the headlight housing (probably H1 and H7 like mine), and order those LED's instead. They should work fine with the sypders.
    3. If you don't have a H1 to H11 converter I can send you a link to one that worked for me on the H7 to H11.
    4. Check out @Headlight Revolution , they know their stuff and completely got me back into the tundra game let alone the lighting game. Actually got some goodies coming in tomorrow. If you need anymore help just hit me up I can walk you through it all.
    Headlight Revolution and dmr[OP] like this.
  10. Dec 4, 2019 at 5:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The spyder lights have proven to not do well with LED bulbs, they do however, perform very well with an HID kit. There are a few more parts such as ballasts and extra wires but it's not bad at all and not too expensive. @Toytec Lifts used to and may still sell a nice HID kit for spyders. I'd suggest going that route if you wanna improve your spyder performance
    Rica25 and dmr[OP] like this.
  11. Dec 4, 2019 at 5:56 PM
    dmr
    dmr [OP] New Member
    Dave
    I just chatted with CarID and they said I may have received the wrong part.
    I may be foolishly focused on using my H11’s as I'm using them and can't return ’em. I broke the trim under the headlights removing them to install the LED’s; something that will cost more $ to fix. I'm just frustrated and don't want to spend a grand on my led upgrade.
  12. Dec 4, 2019 at 6:00 PM
    zachzap361
    Zach
    San Antonio
    @dmr post some pictures so I can see what your working with. Your a 2nd gen like mine so should be same set up so I can help.
  13. Dec 4, 2019 at 7:40 PM
    dmr
    dmr [OP] New Member
    Dave
    12B584BB-543D-48C5-8D45-0C3489B1961C.jpg C0F0BE66-6058-4A25-B75D-192D1AE6B1C1.jpg 12B584BB-543D-48C5-8D45-0C3489B1961C.jpg 12B584BB-543D-48C5-8D45-0C3489B1961C.jpg A4B84A81-9ABB-4DDF-AE46-5F8E9D4B4F04.jpg
  14. Dec 4, 2019 at 7:42 PM
    dmr
    dmr [OP] New Member
    Dave
    Apologies for the dupes. New to the forum, new to modifying anything on my truck and apparently new at posting photos on any forum.
  15. Dec 4, 2019 at 7:44 PM
    dmr
    dmr [OP] New Member
    Dave
    There’s the LED. Not in the pic is the cooling fan in the back which takes up a lot of room. 14DEF5F3-8130-406E-895E-294ACB6922F4.jpg
  16. Dec 4, 2019 at 7:46 PM
    dmr
    dmr [OP] New Member
    Dave
    I might consider this...i didn't think headlights were gonna turn into a part time job.
  17. Dec 4, 2019 at 7:49 PM
    Rica25
    Ricardo
    Tulare
    The led light out put is going to be terrible I had same exact set up and ended yo p after warranty was over replacing with HID and out is way better than halogen and led ......if you watch some videos it will tell you that projector set ups dont go well with leda
  18. Dec 4, 2019 at 7:51 PM
    Rica25
    Ricardo
    Tulare
    This is where I bought mine
    Pudge[QUOTED] and dmr[OP] like this.
  19. Dec 4, 2019 at 9:56 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I ordered the morimoto hid kit for the Spyder lights I bought. When I did a test fit of the bulb in the lights they fit fine, except for the latch. As near as I could tell, it looked like I would have to really flex the metal gate over the bulb to get it to stay in place. Am I missing something? Anyone know what I'm talking about with this?
    I didn't want to bend anything so I just have the lights, housings and a set of v3 running lights that I have yet to use. I'm almost considering just selling it all and buying something simple. Maybe the morimoto housings.
  20. Dec 5, 2019 at 4:41 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Appreciate the Tah @zachzap361 ! :)
    Good Morning OP!
    Welcome to the Lighting Game! Haha :) Looking at the picture, this takes an H1 style bulb! It can be kind of confusing for sure, but that's aftermarket stuff for you haha.
    The Housings you have should go from H1/H7 to H11/9005 like your OEM Connections call for, as long as they are the correct style for your Truck. It's just a wiring adapter! :)
    Essentially, shop for what the Headlight calls for, not the Truck. It's like swapping an LS motor into a Miata. You aren't exactly shopping for your Average Miata anymore. :rofl:
    Feel free to send over a picture of the other bulb so I can confirm the size for you. Hope you have a great day!
    Rica25 and zachzap361[QUOTED] like this.
  21. Dec 5, 2019 at 5:38 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I have black spiders with hids and led turning bulbs and low beams. For sale message me. Willing to let go cheap
    Rica25 and zachzap361 like this.
  22. Dec 5, 2019 at 7:57 AM
    dmr
    dmr [OP] New Member
    Dave
    Thanks for everyone’s input. Confirmed this morning that I received the wrong part.
    Zooming out, what a confusing journey. This was my very first attempt at an upgrade and can’t believe how complex it became.
    I plan on having a leveling kit installed early next year and now don’t know how to evaluate a good one from a bad one if there are differences. Geez.
    Thank you all for your feedback. I’ll take it all under consideration and likely continue making mistakes. I am glad for this forum tho and your help!
    Dave
  23. Dec 5, 2019 at 1:18 PM
    BrandonL812
    Brandon
    For future plan. I would come back and post up what you are "planning" on purchasing. Ask first, then buy. That way you know exactly what will happen and be prepared for it.
  24. Dec 5, 2019 at 4:54 PM
    dmr
    dmr [OP] New Member
    Dave
    Oh you bet I will. I discovered the forum after I started this journey.
  25. Dec 13, 2019 at 11:21 AM
    dmr
    dmr [OP] New Member
    Dave
    Quick follow up: what a run-around CarID is giving me trying to exchange the wrong part they shipped returned in exchange for the correct part. I'm furious.
    Headlight Revolution likes this.
  26. Dec 13, 2019 at 11:23 AM
    Atlanta, GA
    Yeah.... We hear that about them alot... Sorry for your Poor experience my man. Hope you get it Resolved shortly!
    dmr[QUOTED][OP] likes this.
  27. Dec 13, 2019 at 11:33 AM
    dmr
    dmr [OP] New Member
    Dave
    Checked your site out. Nice headlights!
  28. Dec 13, 2019 at 11:55 AM
    Atlanta, GA
    Hey Thanks! Took a looooong time figuring out what’s worth people’s Money and what isn’t. But I’m proud of the work our Team has done so far! We’ll keep the hard work comin’ ! :hattip:
  29. Dec 19, 2019 at 3:12 PM
    dmr
    dmr [OP] New Member
    Dave
    Update: having the absolute worst customer service with CarID. There weeks and no RMA. Sent two rounds of photos two weeks ago and last Friday. None were sent to Spyder till this morning after I contacted customer service for the fifth time last night. Lost my job in between starting this stupid adventure and am now too committed with spend to say screw it and buy something better. What a shit experience.
  30. Dec 19, 2019 at 4:22 PM
    Atlanta, GA
    Damn man... that is the worst, I’m sorry to hear about that brother. I bet they are pretty slammed with Black Friday and such but 3 weeks is some serious time to leave you hanging. :(
