Installing higher watt alternator than the original
Discussion in '2nd Gen Tundras (2007-2013)' started by my1st4x4tundra, Nov 26, 2016.
  1. Nov 26, 2016 at 12:43 PM
    my1st4x4tundra
    my1st4x4tundra [OP] New Member
    2010 tundra 4x4
    Does anyone know if I can install the 130w or 150w alternator in my Tundra which came with the 100w alternator. The 150w is installed on the Tundras with the tow package. I believe that my alternator has gone out and I may want to install the tow package at a later time.
    Thanks,
  2. Nov 26, 2016 at 1:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    If it's an option with the Tundras with the tow package then it should work as an upgrade on yours
    NewImprovedRon likes this.
  3. Nov 27, 2016 at 6:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    One little thing, it's amps, not watts that alternators are rated in. Just to save some confusion when you go to buy one. FWIW, 150A amps at 12V = 1800Watts
  4. Nov 27, 2016 at 6:39 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Just remember PIE. P=I*E. Power equals current (I) times voltage (E).
    GNTundra likes this.
