Installing a new Hot Water Heater..? Any advice..
Discussion in 'Off-Topic Discussion' started by TTU19, Jul 12, 2019.
  1. Jul 14, 2019 at 9:36 AM
    #61
    15whtrd
    15whtrd Mr. Blonde
    I’ve seen the braided ones fail more than once. I prefer rhino flex nowadays. Stainless are almost impossible to kink. Not the ones from Home Depot. Those suck too LOL. I get my stainless rhino flex from my plumbing supply house.
  2. Jul 14, 2019 at 9:50 AM
    #62
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes, most water heaters come with the cheapest drain valves ever and once you open them they never want to close.
    When I worked at a well known service plumbing shop they had this terrible promotion to do a free water heater flush on every residential call. I absolutely hated it because 99% of the time the drain valves leaked after and the shop expected us to sell a replacement or show them how much sediment is in there and sell a new heater. 99% of customers said it wasn't leaking before you touched it. I started carrying brass hose caps in bulk that year. I could be a scumbag on commercial jobs but I wasn't cold enough to stick residents like that.
    I never swapped the hose valve for a ball valve, that's a good idea. The heaters I installed at least had brass drain valves. Bradford White preferred but Rheem was my runner up go-to.
  3. Jul 14, 2019 at 10:20 AM
    #63
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    TLDR: Just a pet peeve of mine.....It is a "water heater". It is not a "hot water heater". That is redundant.:D
    Brought to you by the Department of Redundancy Department
    Darkness and AxelsHumanDad like this.
  4. Jul 14, 2019 at 12:05 PM
    #64
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Well you are right. It didn't even last 24 hours. The hot water line was already leaking at the pipe. I guess because if you look at it, it barely has enough thread to even put on. Put on one of the older supply lines and so far, is working fine.
    15whtrd[QUOTED] and YardBird like this.
  5. Jul 14, 2019 at 12:13 PM
    #65
    15whtrd
    15whtrd Mr. Blonde
    Do those supply lines have washers inside of them? Although I like the tape it may have made it so that you couldn’t bottom out the supply line completely and seal it at the hose washer inside. Typically supply lines are straight thread and the pipe is tapered. So you should only need pipe dope and Teflon if it was pipe thread to pipe thread. But since the supply line should have a washer, Teflon tape is unneeded. Maybe just do one or two wraps.
    Darkness likes this.
  6. Jul 14, 2019 at 12:15 PM
    #66
    15whtrd
    15whtrd Mr. Blonde
    And usually I only see those leak at the union behind the threaded fitting.
  7. Jul 14, 2019 at 12:26 PM
    #67
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yes it did have a washer. I had taped and pipe doped the line. I may have over tightened it and might have pinched the washer, I dunno. But it was leaking just after the piece that threads on.
    Anyway, used the old one and went on nice so we'll see. Hey at least I can return this one to HD and save me some money now, haha.
  8. Jul 14, 2019 at 1:20 PM
    #68
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Good job.
    15whtrd and YardBird like this.
  9. Jul 14, 2019 at 1:25 PM
    #69
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    Guns Up TT!!! You got this.
    TTU19[OP] and 15whtrd like this.
  10. Jul 14, 2019 at 6:46 PM
    #70
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I used the same ones and thankfully they are leak free still.
