Installed Wolfbox rearview mirror dashcam
Discussion in '2.5 Gen Tundras (2014-2021)' started by dan_osms.io, Dec 18, 2023.
  1. Jan 10, 2024 at 7:10 AM
    Vizsla
    Vizsla 2 = 2.5
  2. Jan 10, 2024 at 7:14 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Vizsla, Mater and texasrho83[QUOTED] like this.
  3. Jan 10, 2024 at 7:17 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    TRDFerguson[QUOTED] likes this.
  4. Jan 10, 2024 at 7:19 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I don’t see any reason why it wouldn’t. It uses the same BD mounting pattern so should really work with any S2 plate on the market.
  5. Jan 10, 2024 at 7:23 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I would much rather do this than an inside mounted camera for the rear.
  6. Jan 10, 2024 at 7:28 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I was thinking about that for my rear cam with my Thinkware. I had actually purchased the housing to start going down that path, but couldn't get them to ship the damn thing. I'm not a fan of their customer service.
  7. Jan 10, 2024 at 7:31 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Evil? They were kinda hard to get hold of when I asked to replace one of the burnt out LEDs but once I made contact, they were quick and friendly.
    The modification of the 3rd light would require removal of one of the Baja S2 light pods. Not sure I wanna do that but it looks like that's the only way it'd work. I love the longer light housings for the Raptors.
  8. Jan 10, 2024 at 7:36 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That was my experience too, but I was told it would ship "today or tomorrow" 3 times over the course of a month. So I gave up. I found better ways to spend that money, for now.
    Same. But it's Toyota's fault for the small opening used for the stock brake light.
  9. Jan 10, 2024 at 7:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd be willing to bet that the longer light housing would still work as long as the wiring was long enough, or elongated, to go through the OEM opening in the cab.
  10. Jan 10, 2024 at 10:34 AM
    dan_osms.io
    dan_osms.io [OP] Milana Vayntrub...
    NorVA
    2020 Tundra Ltd w/ TRD, 2003 Honda S2000 (NASA)
    Retrax XR, Yakima Overhaul HD w/ 78" Yak Crossbar, NatureNest RTT, WolfBox G850, Halolock Phone Kit, ICS DashMount
  11. Jan 10, 2024 at 10:35 AM
    dan_osms.io
    NorVA
  12. Jan 12, 2024 at 12:18 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    20240112_143956.jpg Here's where I put my camera.
    bulldog93 and dan_osms.io[OP] like this.
  13. Jan 12, 2024 at 4:02 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    By the way, for anyone also interested in doing the Evil Mfg 3rd brake light camera mount, I got word from them that the ideal light housing to purchase is the one for the 2019+ Ram Model. The angles will be much closer to correct lighting-wise vs the Raptor version which would put the light pattern in the bed. This would give you 2 Baja S2 pods along with a camera in the center. They also referenced a DVR unit that would pair up nicely with the camera.
    Guess I'll start saving up for another 3rd brake light fixture :frusty:
    dan_osms.io[OP] likes this.
  14. Jan 12, 2024 at 6:44 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The Ram housing would fit the Tundra? Interesting.
    reywcms likes this.
  15. Jan 12, 2024 at 6:50 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Only thing is, I'd have to drill another set of holes but the old holes would be covered up and sealed so eh.... I'm not opposed to drilling holes in my cab considering I have cab lights.
  16. Jan 16, 2024 at 8:04 AM
    dan_osms.io
    NorVA
    Drilling holes ? Seesh, why can't they just fabricate a version for the 2nd Gen Tundra?
    rdiddy5 likes this.
  17. Jan 16, 2024 at 8:06 AM
    dan_osms.io
    NorVA
    Which model of wolfbox are you running? I have the 850, and I just updated the firmware the other night. Nothing terribly noticeable with the update. I was toying with the idea of adding a camera splitter, so from an AV box I can flip cameras.
    Curious @Rustedfenders why not use the license plate mount?
    The camera uses a "headphone" jack mini (I need to get the spec) to see if there is a junction box that I can wire up so I can add another camera once I get a rack installed.
  18. Jan 16, 2024 at 8:09 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    the OEM housings have a propensity for leaking.
  19. Jan 16, 2024 at 8:41 AM
    #49
    dan_osms.io
    NorVA
    I hear you @texasrho83. I don't doubt that others are having that problem. Even after my modification no water (crossing fingers) has leaked through. I wonder if that leak is specific to a given year tundra or not.
    The amount of swearing when taking off my 3rd brake light was no small amount. The bastard was on there and VERY tacky.
  20. Jan 16, 2024 at 12:17 PM
    #50
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I got REAL good at taking it off. Problem isn't necessarily the housing, but the 2 small screws meant to supply enough pressure distributed evenly to keep a good seal on there.
  21. Jan 16, 2024 at 3:04 PM
    #51
    dan_osms.io
    NorVA
    I know when I took my 3rd brake light out, there was this gasket like component that w/o, would easily cause the issue.
  22. Jan 16, 2024 at 4:08 PM
    #52
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The gasket is poo.
  23. Jan 19, 2024 at 8:50 PM
    #53
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, gonna jump in with both feet...
    TRDFerguson likes this.
  24. Jan 20, 2024 at 10:30 AM
    #54
    dan_osms.io
    NorVA
    Could you do me a favor and show me the camera cable that comes with the kit? Or a link to it will suffice. I didn't see that when searching.
  25. Jan 20, 2024 at 11:01 AM
    #55
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Evil is really bad about pics and documentation… now if @texasrho83 needs a new home for that old housing… I know a guy.
    texasrho83 likes this.
  26. Jan 20, 2024 at 11:49 AM
    #56
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I will definitely have an empty housing :thumbsup:
  27. Jan 20, 2024 at 11:51 AM
    #57
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have an old pic of the one that's currently in my truck. I'll look for it...
  28. Jan 20, 2024 at 2:00 PM
    #58
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dawned on me that I don't have the camera. It'll ship soon so when it comes in, I'll snap a pic and post up.
  29. Jan 22, 2024 at 8:28 AM
    #59
    dan_osms.io
    NorVA
    I can haz nerd too. You could say I am a cloud guy. :p
    I also noticed this, but think they don't want folks copying their stuff.
  30. Jan 22, 2024 at 8:33 AM
    #60
    dan_osms.io
    NorVA
    Just saw you are a USN @texasrho83, thank you for your service bud. My pop was Navy, and I don't give a shit what anyone says about a Civvie not getting the sacrifice.
    My pop certainly made it clear to me.
