Installed new led headlights on my 2000 Tundra And now my fog lights dont work. Any fixes?
Discussion in '1st Gen Tundras (2000-2006)' started by Konaboyiss808, Dec 3, 2019.
  1. Dec 3, 2019 at 9:49 PM
    Konaboyiss808
    Konaboyiss808 [OP] New Member
    Jr
    2000 tundra
    Stereo, 1” lift in the front for 20” rims, leds inside and out
    So I installed new led headlights on my 2000 tundra and now the fog lights don’t work. When I first installed one of the leds the fog lights were good but when I installed both then the fogs turned off. Anyone find a solution to fixing this problem?
  2. Dec 3, 2019 at 11:55 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So if you revert to previous non-led bulbs the fogs return to working? If they don't then perhaps a fuse dedicated to fogs blew?
    Power to main and fogs are not the same and can't imagine how a lower main light load would cause fogs to cease.
  3. Dec 4, 2019 at 12:21 AM
    Aerindel
    Aerindel New Member
    Montana
    I don't know...but the relay for the fog lights is powered by the same feed that runs the low beams.
  4. Dec 4, 2019 at 12:58 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Screenshot_20191006-225542_Gallery.jpg You need to get a resistor harness. Check with your vendor. Beamtech sent me theirs for free.
  5. Dec 4, 2019 at 3:59 AM
    Professional Hand Model
    Hand Protectors
    Resistor time Boiiii!
    Too late for you, but anyone else reading there are too many good bulb options at great pricing to need resistors anymore. Do your research upfront so you don’t end up like dis boi wit wire all ova!
  6. Dec 4, 2019 at 4:47 AM
    Aerindel
    Aerindel New Member
    Montana
    So this is just my uninformed thoughts...
    But if you need a resistor to make LEDS work then what is the point of the LEDS?
    And if you are only doing that so your fog lights work properly....requiring your fog lights is a pretty trivial project.
  7. Dec 4, 2019 at 4:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You're on the right path. If R stays the same, and V stays the same, then A will also stay the same. But LEDs in a vehicle aren't so much about amp draw as it is lumens per watt, in which LEDs excel.
    Aerindel[QUOTED] likes this.
  8. Dec 4, 2019 at 6:49 AM
    Konaboyiss808
    Jr
    2000 tundra
    Yes if I put my previous bulbs the fog lights come back on. So on my truck even before putting the leds if the fog lights are on and you put them on high beam the fog lights turn off. So I do believe I need a resistor.
  9. Dec 4, 2019 at 4:43 PM
    Johnsonman
    Austin
    Sequoia
    Yeah my truck is wired the same, high beams = no fogs (if fogs turned on), flip high beams off and fogs go on (if fogs on). I have leds in the main lights (they serve as low & high) w/separate fogs. I never could find led h3s to fit my fogs so they stayed incandescent yet they work with the leds serving as mains.
    On my truck the only place that wanted a resistor when using leds was the blinkers, i would get the rapid blink (as if a bulb were out).
    So on your truck, its as by using leds as mains the system thinks the high beams are on and shuts fogs down. If you do use the resisitors, careful they get really hot. Usually they're mounted onto a metal brace so the heat dissipates somewhat onto the metal.
    Luck. :^)
  10. Dec 4, 2019 at 5:46 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I’d find a different bulb that doesn’t require a resistor personally. Those resistors get stupid hot and will melt anything near them. HIDS don’t require any resistors FYI.
