Installed Kings - WTF!? Lower ball joints?
Discussion in 'General Tundra Discussion' started by Boosted4runner, Oct 9, 2018.
  1. Oct 17, 2018 at 7:02 PM
    #181
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wow this turned heated, OP is the one who should be pissed, not any of us.
    The cap shouldn't spin, charged or not. We know it needs charge since he can hear fluid slosh, that tells you there is no pressure. Even if he pumps it with air to trouble shoot what we have already deduced it sounds like hes out of luck on getting a proper charge. I know a lot of shops refuse to charge a shock unless they rebuilt it, I've been through that and you can imagine why. I wouldn't be shocked (yeah I said it) if he has a bad seal.
    The lack of gas is only part of the trouble, I'm still wondering why your axles are so close to the lower mount. Although some have had success with those top shims I would ditch them. They may be changing the angle of the shock by effectively lowering the upper mount where the eyelet bolts in.
    Curious do you have any confirmation on the part number of these coilovers?
    TheBeast and Boosted4runner[OP] like this.
  2. Oct 17, 2018 at 7:12 PM
    #182
    n2deep
    n2deep Pavement Princess
    Dis you not watch the video? No pressure the cap will spin that is normal. Also the axle was close to the coil because he hadn't done an alignment. My axles rub at full lock but I don't have steering stops. And the lower mount is normal to touch at full droop. Back when Fox made the KORE that was part of the install to grind that pocket out. So the shims may be the cause but not hurting anything now that it's done.
    But then what do I know??
  3. Oct 17, 2018 at 7:19 PM
    #183
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nope, not watching a shock get charged bud, isn't new to me. When I took my Fox apart that end cap didn't spin. It took effort to push it in to get the clip out, it was snug. Maybe they're different or maybe I had more miles but it did not spin.
    I saw alignment results and somebody commented it could have been better. He got aligned right?
  4. Oct 17, 2018 at 7:21 PM
    #184
    Pudge
    CT
    2015 Blue Ribbon Platinum
  5. Oct 17, 2018 at 7:23 PM
    #185
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There ya go
  6. Oct 17, 2018 at 7:23 PM
    #186
    n2deep
    There is nothing holding that cap other than the clip and nitrogen pressure so it will spin all day long with no pressure against the clip. Yeah he got the axle coil spacing resolved the lower cup contact is probably due to the shims pushing it down further on droop.
    Boosted4runner[OP] likes this.
  7. Oct 17, 2018 at 7:25 PM
    #187
    n2deep
    Naww I like wasting your time.
    dcsleeper408 likes this.
  8. Oct 17, 2018 at 7:49 PM
    #188
    Vizsla
    Vizsla 2 = 2.5
    Pretty sure he is referring to removing the shaft spacers, not longer shafts. He beat the snot out of them driving them as is, my point is even if fine, it won’t be the same as the brand new shock on the other side longevity wise.
    I had to grind the pockets on my et Fox coilovers 2 months ago, still the same and no big deal. You and I will disagree about the shims, one might be fine, duplicates removing the shaft spacer yielding the et version of the coilover. Put 2 on like the op, and it’s dumb imo.. Your advice and knowledge is appreciated, dont stop. People listen.
    831Tun, TheBeast, joonbug and 2 others like this.
  9. Oct 17, 2018 at 7:58 PM
    #189
    Boosted4runner
    Boosted4runner [OP] Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Here’s a pic of the box! :)
  10. Oct 17, 2018 at 8:02 PM
    #190
    Boosted4runner
    WA
    So King said apparently the aftermarket upper arms create more downward travel, which the model of Kings I have aren’t rated for. He said there’s two models, one for aftermarket a-arms and the other for stock arms.
    15whtrd, SoCal619 and Pudge like this.
  11. Oct 17, 2018 at 8:07 PM
    #191
    n2deep
    Not saying I approve of the shims just that is probably why the shocks are making contact with the cup at full droop. It is an issue caused adding those and not a problem with the shocks. Removing the internal spacer won't cause any issue like you said but changing to longer shafts or longer ends could cause the shock to bottom before the bumpstop. Its up to the OP if he wants to return them but I don't thing there was any permanent damage but if he has the time and energy then return it but I bet they just charge it and send it back. Maybe they will pull it apart and add new seals. Or hopefully they send a brand new one. I would put a little sharpie mark somewhere just to see if they send the same one back.
  12. Oct 17, 2018 at 8:22 PM
    #192
    Boosted4runner
    WA
    I’m going to try more places tomorrow first thing AM. I have a buddy that races down in Baja and he gave me some more names of possible places.
    If that doesn’t work, I’m going to Airgas, buying a bottle of nitrogen - and hope they have an adapter to fill myself.
    Then I’m going to launch Portland’s first nitrogen fill station LMAO.
    Darkness, TheBeast, Vizsla and 2 others like this.
  13. Oct 17, 2018 at 8:33 PM
    #193
    n2deep
    It will cost ya a few hundred for a nitrogen setup with bottle, regulator and gauge. Here is my portable nitrogen setup.
    ColoradoTJ, SoCal619, 15whtrd and 6 others like this.
  14. Oct 17, 2018 at 8:36 PM
    #194
    Vizsla
    Vizsla 2 = 2.5
    Shocks dictate downward travel, the arms could care less. Your arms are just capable of more droop while staying in an acceptable alignment curve. King phone reps sound interesting...
    ColoradoTJ, SoCal619, 831Tun and 2 others like this.
  15. Oct 17, 2018 at 8:37 PM
    #195
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You and me both, they're not cheap though.
    Vizsla and dcsleeper408 like this.
  16. Oct 17, 2018 at 8:43 PM
    #196
    Boosted4runner
    WA
    Damn! That’s badass! In a Pelican too lol.
    Vizsla likes this.
  17. Oct 17, 2018 at 8:49 PM
    #197
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’m betting it just needs nitrogen. But it being a brand new shock I would just send it in to King just to be sure you didn’t damage it, or it wasn’t damaged somehow before you bought it. Since you have another car to drive, might as well take care of it while it’s still under warranty. Same thing happened to me, except both my resis leaked. I could’ve just tried refilling with nitrogen but since they were brand new, I sent them in to be 100% sure. Good thing I did because it turned out I had a defective part and they would’ve failed again.
  18. Oct 17, 2018 at 8:56 PM
    #198
    TheBeast The Beach
    I'm with you here. first I heard about dedicated arms..sounds like rep BS
    Vizsla[QUOTED] and joonbug like this.
  19. Oct 17, 2018 at 8:56 PM
    #199
    TheBeast The Beach
    great info here minus the testosterone :D
  20. Oct 17, 2018 at 9:09 PM
    #200
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The upper arms can allow more downward travel, the shock is limiting that. His version is meant for stock upper arms. There is another version of that coilover with "EXT" at the end of the part number , those are meant to be paired with aftermarket uppers to take advantage of the extra droop.
    Not sure if it's the same with King but Icon used to offer conversion to the extended travel while doing rebuilds.
  21. Oct 17, 2018 at 9:25 PM
    #201
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I had to do this same thing with my Radflo 2.5 coilovers
  22. Oct 17, 2018 at 9:39 PM
    #202
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    7EE264C1-05F4-4D66-B718-6D6E72B9BEB1.jpg I don’t think it was 100% bs! Becuase if you order them from filthy Motorsports it allows you to select “ENTENDED TRAVEL” which that means you have a aftermarket UCA
  23. Oct 18, 2018 at 8:25 AM
    #203
    n2deep
  24. Oct 18, 2018 at 9:03 AM
    #204
    Boosted4runner
    WA
    So, charged the shocks with air - you can hear the leak.
    N2 - is it easier to rebuild myself or send them back?
  25. Oct 18, 2018 at 9:06 AM
    #205
    Boosted4runner
    WA
    Is that an internal spacer?
  26. Oct 18, 2018 at 9:09 AM
    #206
    Boosted4runner
    WA
    Ps - leak is coming from resi
  27. Oct 18, 2018 at 9:26 AM
    #207
    n2deep
    If they are new and you have never done it I would send them back and let King deal with it. Its a hassle but it wasn't right from the start and you shouldn't have to pay for anything. Or make them ship you a new one and pick up the other one. Plus you can have them modified for the EXT at the same time.
    15whtrd and joonbug like this.
  28. Oct 18, 2018 at 9:37 AM
    #208
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Should not have an effect on the location of the front CV's and half shafts. Just a vertical drop of 1.5 to 2" depending on the lift.
  29. Oct 18, 2018 at 10:04 AM
    #209
    Boosted4runner
    WA
    Okay, thanks for the input!
    I’d have to send both shocks in for the EXT, which sucks - but if it’s best then I have to.
    If I can run my model and be okay - I’d rather do that. What shitty timing - in the middle of hunting season. :(
  30. Oct 25, 2018 at 1:37 PM
    #210
    Boosted4runner
    WA
    What's your address. I'm sending you some beer.
    15whtrd and TheBeast like this.
