Installed Kings - WTF!? Lower ball joints?
Discussion in 'General Tundra Discussion' started by Boosted4runner, Oct 9, 2018.
  1. Oct 14, 2018 at 7:59 PM
    #91
    Vizsla
    Vizsla 2 = 2.5
    You can lose some caster on both sides, .5 degree will probably get you away from the front axle. Less toe if you adjust as well, .07 per side is good.
    Don’t sweat the nitrogen, if low fill up be happy.
    dcsleeper408 likes this.
  2. Oct 14, 2018 at 8:01 PM
    #92
    Boosted4runner
    Boosted4runner [OP] Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    So Offroad shops do this service?
    I’ve never had to “fill up” before lol.
  3. Oct 14, 2018 at 8:05 PM
    #93
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    No, I did not need to compress the coils when I turned the collar when I had my UCA separated from the spindle. I mentioned that if one does not have access to a spring compressor, (since barely out there fits) to separate the UCA and spindle to be able to turn the collar with ease because it relieves the tension from the coilovers.
    Yeah I would say checking up on the caster also.
  4. Oct 14, 2018 at 8:11 PM
    #94
    Vizsla
    Vizsla 2 = 2.5
    Yes, some tire shops can do it as well. Just make sure they are capable of the psi you require.
  5. Oct 14, 2018 at 8:18 PM
    #95
    Boosted4runner
    WA
    I tried to adjust the Kings on full droop (and on bench) and there was waaay too much pressure from the coils to the collar.
    I understand separating them from the upper arm allows the coilover to extend to its full position, but it’s still under a lot of pressure and the coils need to be compressed to adjust collar.
  6. Oct 14, 2018 at 8:21 PM
    #96
    Boosted4runner
    WA
    Thanks!
  7. Oct 15, 2018 at 8:42 AM
    #97
    n2deep
    n2deep Pavement Princess
    Shims are fine, Diff drop is fine, you can adjust the collar without taking anything apart - I do it all the time but have to use two tools. Use a spanner wrench and a punch that fits the hole snug. Also I spray a little wd40 on the threads and spin it a full droop.
    I suggested the Nitrogen pressure already and its the easiest thing to do - I have seen many with a clunk with Low pressure.
    You can ask the tire shop to put at least 150psi and it should do the trick. If you don't have the correct chuck then you need a no loss shock gauge.
    joonbug likes this.
  8. Oct 15, 2018 at 9:02 AM
    #98
    Boosted4runner
    WA
    Awesome! Thanks!!
  9. Oct 17, 2018 at 12:11 AM
    #99
    Boosted4runner
    WA
    FFFFFAAWKK!!!.......no go on removing Diff Drop.
    I’m mocked up, but don’t have stock bolts. Bolts I have are too long. Damnit.
    Skid plate removed, still have clunk.
  10. Oct 17, 2018 at 12:12 AM
    #100
    Boosted4runner
    WA
    I think I’m just going to swap in stock coil to confirm King culprit vs factory issue. :confused:
    SoCal619 likes this.
  11. Oct 17, 2018 at 1:01 AM
    #101
    Boosted4runner
    WA
    Went for a drive with skidplate removed and clunk is still there (I knew it wasn't the culprit deep down, but a part of me was really hoping this was the case LOL).
    I called around to 8 shops today - no Nitro gauge. I’m going to try Air-Gas tomorrow, and if they can’t measure, order my own gauge.
    Unfortunately, I’m guessing if a Nitro fill is required, it will be down right impossible locally.
  12. Oct 17, 2018 at 1:17 AM
    #102
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    you put the stock suspension back in and still a clunk?
    5.7TRDProm and joonbug like this.
  13. Oct 17, 2018 at 2:11 AM
    #103
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Should of went fox! Lol jk. Hope you figure it out. Your cam bolts are snug on the LCA?
    15whtrd and monaco730 like this.
  14. Oct 17, 2018 at 7:55 AM
    #104
    n2deep
    Is there no atv motorcycle shop in town? They have to charge shocks and should have what is needed. Tire shop can do it too - they should be able to set the regulator at 150psi and hit it without a gauge. It doesn't have to be exact cause it will work anywhere from 100psi to 250 to confirm if that is the problem. I have set my compressor to 150 and charged mine with air so I could get to the shop before I had my own nitrogen. Then just release the air and charge with nitrogen.
    joonbug likes this.
  15. Oct 17, 2018 at 9:01 AM
    #105
    Boosted4runner
    WA
    No, sorry. I didn't clarify I was hoping it was the skidplate - and it wasn't. LOL
  16. Oct 17, 2018 at 9:01 AM
    #106
    Boosted4runner
    WA
    It was a serious debate for me LOL. Yea, I double checked cam bolts before, and after alignment.
    xtyfighterx[QUOTED] likes this.
  17. Oct 17, 2018 at 9:36 AM
    #107
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I was getting ready to remove my diff drop a few weeks ago and realized I had no idea where I put my stock bolts too. Anyways, I would really try the nitrogen first before trying anything else. Could turn out to be a really easy fix.
  18. Oct 17, 2018 at 9:39 AM
    #108
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    So this is a long shot, because it looks like your resi's don't interfere like mine did.....but I'll mention it just in case.
    I had a clunking/popping noise on my ADS setup - passenger side that I tracked down for quite a while. Here is the thread, including where I found the cause of the problem:
    https://www.tundras.com/threads/new-noise-help-me-brainstorm.25846/
    Basically, my reservoir had moved forward slightly and was rubbing on the inner fender liner. I never thought to look there, because it didn't seem like that would cause a "clunk" or "pop" like I was hearing. But, moving it fixed the problem.
    Like I said, looking at the King setup, I doubt this is the problem - your resi's look shorter than mine and I doubt that they are close to interfering. But, thought I would mention it.
    Good luck, man. I know how frustrating stuff like this can be.
    SoCal619 and Boosted4runner[OP] like this.
  19. Oct 17, 2018 at 9:44 AM
    #109
    Boosted4runner
    WA
    Yea there is, and they don't have a gauge LOL. I called Airgas and they don't either.
    One 4x4 shop said they have a gauge in their race-truck off-site. They didn't sound too enthused about finding it and left me on hold for 20 minutes.
    I just called SDHQ off-road and spoke to a tech. He said either coil/parts are making contact or a possible arm bushing/lower BJ failure. I wiggled the shit out of the tire/wheel and lower BJ seems fine. I told the tech that prior to the King install, the TRD coils/spacer was a smooth ride without issue. He said that the stock parts (arm/lower BJ) could have still been worn decently and not shown any signs. The Kings put more pressure/stress on those components and now they are showing their ugly ass head.
  20. Oct 17, 2018 at 10:45 AM
    #110
    Boosted4runner
    WA
    At this point - I'm looking for everything to try! My resi was REALLY close to the washer bottle, and I will move it back more! LOL
  21. Oct 17, 2018 at 10:51 AM
    #111
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I told u to send them to me but u didn’t listen lol jk buddy hope u get it all worked out
  22. Oct 17, 2018 at 11:43 AM
    #112
    n2deep
    You don't need a gauge to get close and find out if thats the problem or not. Every nitrogen setup has a regulator because they put 2200 psi in the bottle and you can't use that pressure so the regulator keeps it at a pressure that is usable. Set the regulator to 180psi (its a knob and all they have to do it turn it till it reads 180psi) and then charge the resi- If it turns out that its off by 20-50psi you are still in a good range. Just ask if they can charge your coilover with nitrogen, not if they have a gauge or not. You can't use a regular tire gauge to check it after its charged otherwise you lose pressure - Its not the same as a tire. Takes like 10 seconds.
    15whtrd likes this.
  23. Oct 17, 2018 at 12:53 PM
    #113
    TheBeast The Beach
    costco has nitrogen if you have one close by.
    831Tun likes this.
  24. Oct 17, 2018 at 2:29 PM
    #114
    Boosted4runner
    WA
    I called two - they won’t use it on shocks - only tires!
  25. Oct 17, 2018 at 2:33 PM
    #115
    Boosted4runner
    WA
    Okay - so I went to move the reservoir back, and noticed it was Really hot!
    I checked my driver side - nowhere near as hot! I think that’s a good sign! LOL
    Also, is the fitting for that goes into the reservoir supposed to spin freely?
    I’m pointing at where it spins
  26. Oct 17, 2018 at 2:35 PM
    #116
    Boosted4runner
    WA
  27. Oct 17, 2018 at 2:41 PM
    #117
    Boosted4runner
    WA
    I’m duck-taping my Fing iPhone to the Icon arm and doing a video LOL.
    SoCal619 and 15whtrd like this.
  28. Oct 17, 2018 at 2:43 PM
    #118
    15whtrd
    15whtrd Mr. Blonde
    You got to do what you Gotta do! If you don’t have insurance on the phone call and add it now LOL
  29. Oct 17, 2018 at 2:56 PM
    #119
    Boosted4runner
    WA
    LOL! I’m getting the new XR in a few weeks so said F it :thumbsup:
    So, made 3 videos - and don’t have the best roads around here to duplicate the sound. That sucks.
  30. Oct 17, 2018 at 2:57 PM
    #120
    Boosted4runner
    WA
    Does it make any sense that one shock is consistent hotter than the other?
    I’m praying it’s nitrogen.
    Waiting for a call back from another shop if they can fill them.
    Is it the same as when filling tires?
