Installed Kings - WTF!? Lower ball joints?
Discussion in 'General Tundra Discussion' started by Boosted4runner, Oct 9, 2018.
  1. Oct 9, 2018 at 10:50 PM
    Boosted4runner
    Boosted4runner [OP] Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Cranked the Kings down a tad and have a cunt-hair of clearance
    Pudge and 8MINT8 like this.
  2. Oct 9, 2018 at 10:50 PM
    Boosted4runner
    WA
    Really? Well soma-a-bitch! Instructions didn’t say anything about that lol.
  3. Oct 9, 2018 at 11:29 PM
    Boosted4runner
    WA
  4. Oct 9, 2018 at 11:31 PM
    Boosted4runner
    WA
  5. Oct 9, 2018 at 11:32 PM
    Boosted4runner
    WA
    My TRD shocks with shitty spacers ran better than this LOL
  6. Oct 9, 2018 at 11:35 PM
    Boosted4runner
    WA
    I’m showing 10 threads on the Kings (2” lift). With the CB spacer, I should be at 2.5” total.
  7. Oct 9, 2018 at 11:36 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I see you have shims on top, are the 4 bolts up top buttoned down?
    This picture looks like it has a little gap.
    831Tun likes this.
  8. Oct 9, 2018 at 11:44 PM
    Boosted4runner
    WA
    Yea, that’s the first thing I thought of - so I tried to tighten them all up before test-driving. I blue lock-tighted them, and they’re freaking tight.
    If you’ve ever heard a blown shock before, this is exactly what it sounds like. Even down to how when a blown shock is noticed, it’s over quick holes/rough terrain. (But I don’t get the floaty effect).
    Pretty much the complete opposite of how a King should react.
    I would imagine there are never Kings that have issues if installed new right? The driver side, and rears all seem perfect - and the way I would think a King would ride.
    I’ll take it to the alignment shop tomorrow and have them go through it.
    dcsleeper408[QUOTED] likes this.
  9. Oct 9, 2018 at 11:46 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    How about to compensate for the driver side lean, i measured my truck and the right side on the front is like on inch lower then the left! I’m concerned if I crank my kings that the ride will feel different !
  10. Oct 9, 2018 at 11:47 PM
    Boosted4runner
    WA
    Yea, that’s why you’re supposed to do the CB shims. They provide 1/2” lift.
    So you put 1 CB on passenger side, and 2 on driver side.
    Eta - what’s wierd, is my truck was perfectly level before I took off my TRD w/ spacers. I had zero Tundra lean and have pictures to prove it.
    Now all of the sudden, I have Tundra lean LOL.
    TheBeast likes this.
  11. Oct 9, 2018 at 11:49 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I've seen brand new shocks leak upon install.(fittings were loose out the box) We're all human, we all make mistakes. Some manufactures send out some duds, but all usually do a pretty good job taking care of their customers.
    Definitely have a look. Maybe just remove the shim and just adjust accordingly? I doubt its your ball joint. Leaky doesn't always mean donzo. Just keep an eye on em in the future.
  12. Oct 9, 2018 at 11:49 PM
    anthonygan
    2017 Cement TRD PRO
    Ohhh could I just put one on the driver side and leave the passeneger side?
  13. Oct 9, 2018 at 11:49 PM
    Boosted4runner
    WA
    Yes.
    anthonygan[QUOTED] likes this.
  14. Oct 9, 2018 at 11:53 PM
    Boosted4runner
    WA
    Yea, I’ll pull the spacer - after adjusting the King down, I’m still sitting high on passenger, and this happens to be the problematic side.
  15. Oct 12, 2018 at 1:13 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Did ya get this sorted out?
  16. Oct 12, 2018 at 2:01 AM
    Those bushings are called miss alignment spacers.
    There are one on each side. This give a lot more flexibility.
  17. Oct 12, 2018 at 6:16 PM
    Boosted4runner
    WA
    I just got the truck out from Alignment and I’m heading up hunting. So far it feels better - i’ve noticed a little noise in the front end but not much . I also have the icon Delta joint arms on now as well.
    I might have to pull the wheel when I get back in check to see if I did indeed install that lower shock shaft in backwards.
    thank all you guys for your awesome help I really appreciate it !!!!!
  18. Oct 12, 2018 at 6:17 PM
    Boosted4runner
    WA
    Updated pics - Also installed the 1 inch toy tech shackles and bushings
    dcsleeper408, equin and ColoradoTJ like this.
  19. Oct 12, 2018 at 6:19 PM
    #49
    Boosted4runner
    WA
    and the wife pulled up next to me and noticed both front and rear shocks looked really expensive LMFAO !!!!!
    She said why in the hell is your truck higher!?! You lifted it!!! LOL!!!
    I said they all come that way babe they’re adjustable. She said how much more did that cost and I said I don’t know couple hundred bucks or so but I don’t have to buy shocks ever again because theyre rebuilable LOL
    I’m not sure she’s going to buy the dirty deeds box that shows up and says you won a raffle LOL
    Civiceg94, Darkness, 15whtrd and 6 others like this.
  20. Oct 12, 2018 at 6:46 PM
    #50
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Isn't that spacer on the bottom of the shock supposed to be the other way so it pushes the shock towards the front of the truck a bit?
    Boosted4runner[OP] likes this.
  21. Oct 12, 2018 at 7:08 PM
    #51
    TheBeast The Beach
    that's because factory TRD shocks are already designed to compensate for the lean. once you go to King you go to same height on each side. I opted to put more preload on driver side than passenger. I did not want to add spacers on top to correct it. kinda defeats the purpose of going with coilovers. i think i have 5 more turns on driver vs passenger. Rides perfect.
    and yes it's tight there with the King shaft. check your sway bar too. mine was rubbing. alignment should fix all of that.
  22. Oct 12, 2018 at 7:14 PM
    #52
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I'm glad you seem to be back on track. Your truck is sweet man. Report back after the hunting trip, I'm curious as to how this worked out.
    Also it's been nice knowing you, the dirtydeeds BAmuffler sounds like the nail on the coffin. You could think of it this way .... divorce is cheaper than ..... well it's not cheaper than anything really. Never mind. Good luck lol
  23. Oct 12, 2018 at 8:53 PM
    #53
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Another way to turn the CO if that perfect spring compressor isn't accessible is to separate the UCA from the spindle and the coil collar spins like a breeze!
  24. Oct 12, 2018 at 9:08 PM
    #54
    n2deep
    n2deep Pavement Princess
    Clunck can come from low Nitrogen pressure too. Should be between 150psi and 250psi. I run about 185psi
  25. Oct 13, 2018 at 7:24 AM
    #55
    Boosted4runner
    WA
    Up hunting - don’t have much for cell service lol Weather is waaaay too nice for hunting deer. Going to be a bunk weekend I think. Zero shots fired opening morning is a baaaad sign lol.
    So on the way to my hike this am - traveled on gravel some.
    There is a problem, and I’m almost positive you guys are dead-nuts correct on that lower alignment bushing.
    The truck drove waaaay better on the twisties/pavement coming up. I couldn’t believe how planted it was! I drove the shit out of the back roads :)
    The clunk come from sudden impacts, say a 3” sized rock, a transition in concrete to asphalt where there is a gap/etc.
    Really hoping that bushing is the ticket! Can’t wait for my right side to be as nice as the left lol :)
    Pudge likes this.
  26. Oct 13, 2018 at 7:26 AM
    #56
    Boosted4runner
    WA
    I had no idea the TRD’s were designed this way!
    So I did end up putting the 2nd CB spacer on the driver side and it did correct the lean perfectly in the front.
    Although with a full tank of fuel, my rear driver side sits 3/4” lower than passenger. Front is level.
  27. Oct 13, 2018 at 7:36 AM
    #57
    Boosted4runner
    WA
    Hoping this isn’t the case! :D:fingerscrossed:
  28. Oct 13, 2018 at 7:37 AM
    #58
    Boosted4runner
    WA
    Sweet! Thank you!!!
    5.7TRDProm[QUOTED] likes this.
  29. Oct 13, 2018 at 7:40 AM
    #59
    Boosted4runner
    WA
    Thanks!! You too buddy! Amazing community this place is!! :thumbsup:
    Yea, not sure how the BAmuffler will work out LOL.
    Divorce isn’t a word in our vocabulary lol :)
    ColoradoTJ, 15whtrd and Pudge[QUOTED] like this.
  30. Oct 13, 2018 at 8:12 AM
    #60
    15whtrd
    15whtrd Mr. Blonde
    Haha you’re on Tundras.com because this place is so addicting yet there’s a buck out there taunting you like
    LOL
