Installed K&N Filter, now Check Engine light stays on and Traction Control off
Discussion in 'General Tundra Discussion' started by dekberg13, Jan 30, 2016.
  1. Jan 30, 2016 at 6:11 PM
    dekberg13
    dekberg13 [OP] New Member
    2016 Tundra 4x4 (White)
    New to the forum and a new owner of a 2016 4x4.
    I just installed a K&N cold air intake and now my check engine light stays on and the center display says "Traction Control Off" repeatedly. I have shut off and the engine and restarted it and I have pressed the traction control button multiple times (turning it on and off with the button) but the center display shows the same thing both ways ("Traction Control Off").
    I disconnected the battery as noted in the K&N instructions. Not sure if killing the power caused the warning lights/indicators.
    Any ideas?
    Thanks!
    Darren
  2. Jan 30, 2016 at 6:21 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    You took the negative off?
  3. Jan 30, 2016 at 6:25 PM
    dekberg13
  4. Jan 30, 2016 at 6:29 PM
    dekberg13
    Yes it was the negative
  5. Jan 31, 2016 at 7:31 AM
    Did you see what the code reads?
  6. Feb 3, 2016 at 7:38 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Maybe the air box didn't seal all the way back up when you had it apart? Check fitment?
