Installed JBA long tubes
Discussion in '1st Gen Tundras (2000-2006)' started by tyler-brown, May 9, 2020.
  1. May 16, 2020 at 10:41 AM
    #61
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I’m still very curious about your long tube install. How is your exhaust set up behind the long tubes? Example: 2.5” pipes going into an xpipe into (insert brand) mufflers and then going out of the back of the truck.
  2. May 16, 2020 at 10:46 AM
    #62
    revtune
    revtune New Member
    Dane
    Houston Texas
    It looks like it’s pointing towards the block. Or I’m just seeing it wrong:cool: How does it look compared to the drivers side? Do you think you’d be able to back it out and change it?
  3. May 16, 2020 at 10:49 AM
    #63
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yeah as long as there is physical room to remove it outward, it’s all about the right tools
    revtune[QUOTED] likes this.
  4. May 16, 2020 at 10:53 AM
    #64
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I'll give it a shot but that's the only issue I could see is not physically being able to back it out.
    It does face the block.
    I'll report back when I put the cat back on.
  5. May 17, 2020 at 9:22 AM
    #65
    tyler-brown
    tyler-brown [OP] New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    JBA long tube headers, JBA Y pipe, JBA exhaust and muffler. No resonator, no cats.
    Had to cut some flanges off the Y pipe and add some chunks of stainless to have it all match up and such
    revtune[QUOTED] and FrenchToasty like this.
  6. May 17, 2020 at 9:29 AM
    #66
    imDementeD
    Any pics?
  7. May 17, 2020 at 9:54 AM
    #67
    tyler-brown
    Canada, B.C.
    I do not. Currently raining and gross outside. When it gets nice and if there's still interest I can
  8. May 17, 2020 at 11:07 AM
    #68
    Youngfrankenstein
    Youngfrankenstein New Member
    2015 4x4 CM SR5
    Great header write up Tyler Brown. Love your answer (something about spending $100 on BBQ sauce for yummy pork). I wonder if the 2006 & earlier trucks take some real miles for the gains to be felt. One write up particularly, on a 3rd gen., talks about how after quite a few miles, a great teal of power was felt. I will find it and link it.
    Thank you for the nice write up.
    https://www.tundratalk.net/threads/...thorley-long-tube-headers.101555/#post-652380
  9. May 17, 2020 at 12:30 PM
    #69
    tyler-brown
    Canada, B.C.
    I had my battery unhooked for the whole process. Since these trucks are suppose to "learn". So I dont know if over time has any side effect in this instance. But I suppose we shall see.
    I did the timing belt, water pump, changed air filter, spark plugs, dirtydeeds 12 hole injectors and the exhaust. I figured unhooking the battery and trying to have a "fresh restart" would be beneficial with the things I did.
    FrenchToasty likes this.
  10. May 17, 2020 at 3:17 PM
    #70
    revtune
    revtune New Member
    Dane
    Houston Texas
    Hmm, no cats and no resonators? How’s the cab drone?
  11. May 17, 2020 at 7:06 PM
    #71
    tyler-brown
    Canada, B.C.
    [QUOTgE="revtune, post: 1751380, member: 27132"]Hmm, no cats and no resonators? How’s the cab drone?[/QUOTE]
    Fine. That was an issue with me. I never wanted a loud truck. And thankfully it's not. I can hear the valve train more now than I could with the stock exhaust. And when I do floor it, it's got some nice notes. I do get some weird harmonic that rarely happens, which is as easy as lifting my foot and resuming speed and it's gone.
  12. Dec 31, 2020 at 6:47 AM
    #72
    Professional Hand Model
    Hand Protectors
    How’d the removal go on the Pass side o2 Sensor? Easy access without removing the header?
  13. Dec 31, 2020 at 6:51 AM
    #73
    imDementeD
    I never got around to do this. I will see if I can do that this weekend.
  14. Mar 31, 2021 at 8:06 PM
    #74
    tyler-brown
    Canada, B.C.
    Just an update.
    After installing magnum o2 sensor simulators, that were way to expensive and only lasted a few months. I've finally bought 2 new o2 sensors, & bungs from the auto parts store, and ordered some o2 simulators (spacers) off of Amazon. Marked where I wanted them mounted, Pulled the one side of my exhaust off so I didn't have to pull my whole exhaust off, and welded the bungs on, and drilled some holes. Re-installed, cleared my codes, and everything seems to be good so far! No CEL.
    Will update when I drive the truck more. (Being the offroad truck it sits unused for long periods of time)
    5N0W808 and Darkness like this.
  15. Sep 17, 2021 at 6:43 PM
    #75
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    Still no codes? Assuming those are A/F sensors in front of 02 sensors? What is the thought process for placing them in the mid pipe and with a defouler? My JBA LT headers came with ports at the very end that can be reached easily. Did you ever find wiring harness extensions? Michigan Motorsports has them at a good price.
    tyler-brown[OP] likes this.
  16. Sep 17, 2021 at 6:48 PM
    #76
    tyler-brown
    Canada, B.C.
    The bungs in the long tube headers is where the A/F sensors went. There were no other bungs for the o2 sensors anywhere else on my new exhaust. And since I cut my cat & resonators out with the old exhaust that's just where I opted to put them in for future easy access. AFTER trying the magnum o2 sensor simulators. They worked for a couple months...than stopped.
    And no, no longer harness, just ended up making them my self. I'll check out that Michigan motorsports though. Thanks!
    Darkness likes this.
  17. Sep 17, 2021 at 6:53 PM
    #77
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    These are both your 02 sensors?
  18. Sep 17, 2021 at 7:23 PM
    #78
    tyler-brown
    Canada, B.C.
    That is correct.
    Since I tried the magnums first this route was an after thought. Drivers side of the exhaust I could take out just a section of it and drill and weld. IF I wanted to do passenger side I would have had to remove pretty much my whole exhaust. So. Figured why not put em both on one side
