Installed Bilstein 6112s - Love it!
Discussion in 'Suspension' started by MistrRoboto, Dec 18, 2017.
  1. Jan 5, 2018 at 3:52 PM
    #91
    Zero One Actual
    Just wait sir. The shocks and technology aren’t changing anytime soon nor is the Tundra.
    If you put them on now, you will be charged labor. Then a few weeks from now you will be charged again for labor to move the same exact part you could have done once all at the same time to get it right and level.
    SouthBoundSteve likes this.
  2. Jan 6, 2018 at 3:50 PM
    #92
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I ordered the 6112s kit , installed on the 16th....question....I’m having them set at 1:92....Can that be easily adjusted later?
    DaBoro54 and Casper3 like this.
  3. Jan 6, 2018 at 4:11 PM
    #93
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Yes Steve, here ya go.
    HEIGHT ADJUSTMENT
    It all levels out.
    Multiple OEM specified snap ring grooves are featured on select off-road shock absorbers for quick and easy adjustment to your vehicle’s ride height. Shock absorbers with snap-ring ride height adjustment technology are an affordable and better alternative to coil spring spacers when leveling out the front end of your light truck or SUV.
  4. Jan 6, 2018 at 5:51 PM
    #94
    Zero One Actual
    Wait, I thought you had to remove them to adjust them though unlike others where you can adjust them while installed? (King, Icon). I could be incorrect though. But when removed the adjustment is easy as described above.
  5. Jan 6, 2018 at 6:03 PM
    #95
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    They'll have to be removed to place the snap ring in a different groove on the shock body.
  6. Jan 6, 2018 at 6:48 PM
    #96
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Adjusted yes, easily no. Icon, King, Toytec Boss, etc, can be adjusted while on the truck. The 6112 would have to be removed and the spring compressed. Personally, I would add a shim or two to get more lift before I had the entire thing re-assembled.
    -Jim
    Zero One Actual likes this.
  7. Jan 6, 2018 at 7:18 PM
    #97
    rons23
    Ron
    Kill Devil Hills
    Or you can just set @ max height. :transformer:
  8. Jan 10, 2018 at 4:29 PM
    #98
    rons23
    Ron
    Kill Devil Hills
    Ok figured I would continue in this 6112 thread. Ordered 6112's @ max height. Also ordered 1 CB Shim and CB bump stops to replace factory. 5100's for the rear and Low Range 1" block for rear. :D:D:D
    Me and a experienced buddy of mine are gonna do the work. As far as installing coilovers:facepalm: he's good, but don't think he's messed with bump stops.
    Few questions for anyone.
    1st ,What's involved with that, easy or pia?
    Second, will I be ok driving my Tundra around 90 miles back home without getting alignment. I plan on getting alignment when I have new tires and spacers installed. Thanks for your time. :thumbsup:
    SouthBoundSteve and Stulloh like this.
  9. Jan 10, 2018 at 4:50 PM
    #99
    rons23
    Ron
    Kill Devil Hills
    Steve I gave you a clue back a while, but it sneaked pass you. I will lay them out and post pics. I hope to be a club member soon. Just working out a date and time for install. Thanks
  10. Jan 10, 2018 at 4:59 PM
    #100
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I get mine installed Tuesday....super psyched
  11. Jan 10, 2018 at 6:28 PM
    #101
    Zero One Actual
  12. Jan 11, 2018 at 3:29 PM
    #102
    MistrRoboto
    Virginia Beach, VA
    Install isn't bad at all. Just follow a guide. I used the first few pages of this for the front coils.
    http://www.trdsparks.com/install/PTR13-34140inst.pdf
    Only trick is make sure to loosen both the front and back of the LCAs cams from the front of the vehicle facing bolt. It will make sense if you try the rear ones and 100000lb of torque doesn't budge them.
    I found loosening those to lower the LCA out of the way made things very easy. Get those adjustment cams marked before loosening else you can really throw alignment off. Retighten really well else the LCAs will knock.
    90 miles isn't too bad, but you will add some wear to the outer edge of the tire. Doubt you notice.
  13. Jan 11, 2018 at 4:26 PM
    #103
    rons23
    Ron
    Kill Devil Hills
    Thanks bro, after some thinking , I might just have a local shop do it. Getting quote tomorrow. If doable I will have everything done in 1 shot. I am beating myself in the head over what tires. ST Maxx vs Nitto Ridge Grappler. Nitto is $60 more a tire, but is it worth the extra $240 vs ST.Maxx. I have heard great things about both tires. The Grappler being a little more quieter. I have heard the ST Maxx was a little suspect on wet roads. Gotta get my shit together, got to order by this Sat. :annoyed::help:
  14. Jan 11, 2018 at 4:58 PM
    #104
    MistrRoboto
    Virginia Beach, VA
    I'd go Ridge Grapplers in a heartbeat. I had the Trail Grapplers on an FJ and got nearly 90k miles out of them. Not sure about wear, but I've read great things about them and plan to get 285/70/18s when I can.
  15. Jan 11, 2018 at 5:10 PM
    #105
    rons23
    Ron
    Kill Devil Hills
    Yeah both Discount Tire reps suggested them too. Buy Once Cry Once right. Hahaha
  16. Jan 11, 2018 at 10:44 PM
    #106
    clay7160
    clay7160 New Member
    what was the guy pushing instead? ready lift , rough country or pro comp?
  17. Jan 12, 2018 at 2:36 PM
    #107
    rons23
    Ron
    Kill Devil Hills
    So my buddy that was gonna help me with install, the brains of the operation is going TDY ( Work Travel). So I called the shop who originally installed leveling kit to get a quote. So work that needs to be done. Install 6112's and 5100's. Install shim (driver side), CB bump stops. Install 1" tapered block in rear. Install wheel spacers, mount&balance tires, still haven't made decision if I'm going St Maxx or Nitro Ridge Grap, then alignment. Total cost out the door:rockband: $ 415.00. :kona::jellydance::taco::dancingbacon::broccoli::bananadance:. :thumbsup:
  18. Jan 12, 2018 at 4:34 PM
    #108
    MistrRoboto
    Virginia Beach, VA
    That's an insanity price. Nice find.
  19. Jan 12, 2018 at 5:12 PM
    #109
    rons23
    Ron
    Kill Devil Hills
    Yeah I'm stoked. And by the way I opened the box to see if all parts were there. Them 6112's are knucking huge. Pictures don't show the true size of these behemoths. :eek:
    757TUNDRA and SouthBoundSteve like this.
  20. Jan 12, 2018 at 5:20 PM
    #110
    Zero One Actual
    Ya, I got mine already assembled at the top setting and they are like three feet long and beastly.
    SouthBoundSteve and rons23 like this.
  21. Jan 13, 2018 at 4:36 PM
    #111
    MistrRoboto
    Virginia Beach, VA
    Yeah man, they are massive. Thought the same thing when I opened the box.
  22. Jan 13, 2018 at 8:53 PM
    #112
    clay7160
    clay7160 New Member
    My tacoma ones are massive also - almost out of proportion.
    Zero One Actual and rons23 like this.
  23. Jan 22, 2018 at 11:28 AM
    #113
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Hey guys! I have 6112's being delivered tomorrow, I am stoked! I had them assembled at 1.9" has anyone had experience adding CB shims to both sides? Positive or negative feedback would be appreciated.
  24. Jan 22, 2018 at 11:38 AM
    #114
    MistrRoboto
    Virginia Beach, VA
    You are in for a treat! Mine feel even better now than when I first installed. No shims yet but that is what I would do if I wanted another.5 in.
    pschiller86[QUOTED] likes this.
  25. Jan 22, 2018 at 11:45 AM
    #115
    pschiller86
    Paul
    Temecula, CA
    are both driver/passenger sides still about level? Have you experienced any Tundra lean?
  26. Jan 22, 2018 at 11:46 AM
    #116
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Have the same setup but only shimmed on the drivers side, no issues
  27. Jan 22, 2018 at 12:15 PM
    #117
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I have no shims and its perfect. i didnt adjust headlights...seems mine were too low anyways and this corrected that
  28. Jan 22, 2018 at 12:54 PM
    #118
    MistrRoboto
    Virginia Beach, VA
    Not yet. My FJ got some lean after a while, but I just ignored it. As I sit today, it looks perfect.
  29. Jan 22, 2018 at 3:31 PM
    #119
    rons23
    Ron
    Kill Devil Hills
    My 6112's are installed, unfortunately I'm waiting to get tires on. Mechanic forgot to put shim on driver side. I asked him for tape measure and measured center of wheel to top of fender wall. With the installation it took out most of the lean. Difference is less 1/4". :thumbsup:. No need for shim.:D.
    Casper3 likes this.
  30. Jan 22, 2018 at 5:54 PM
    #120
    Zero One Actual
    I have the 6112s set at top setting. 5160s for the rear. Coachbuilder shackles and extra shims if necessary. @Coachbuilder1 was an incredible resource and help when it came time to order the proper parts for running this setup at the top setting. Obviously I will post pics and feedback once everything is installed.
    Casper3, Biff_Elwood and rons23 like this.
