Install interior led lights
Discussion in 'Lighting' started by deez00, Aug 13, 2022.
  1. Aug 13, 2022 at 4:20 PM
    deez00
    deez00 [OP] New Member
    MD
    2020 White CM Tundra SR5 TRD Sport
    2020 CM
    I’m having issues installing Brishine interior led lights from Amazon. I was able to remove the dome lights but can’t get the led lights in. So I tried to put the original bulbs back in and can’t get them back in. What an i doing wrong? Tried following others from YouTube that makes it look easy but not working out for me.
    Pls help….
  2. Aug 13, 2022 at 5:32 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Make sure the bulbs are oriented the correct way for the socket. Look at the base of the bulb. It has to go into the socket correctly otherwise you are pushing the bulb base against the socket prongs.
    BravoDeltaRomeo likes this.
  3. Aug 13, 2022 at 11:42 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Hi there, WELCOME!! I replaced mine a while ago, glad I did! Make sure the replacement bulbs are the same length... This the shape of my dome bulb...
    The springs that hold this type of bulb are VERY tight in my truck... I really had to apply a bit O pressure to snap them in! Just don't over do it... ouch! I ended up taking a stout needle nose pliers, bent them a bit more open, The bulb now goes in easier, but is still snugly clamped in place!
  4. Aug 31, 2022 at 11:08 AM
    suburban_dad
    suburban_dad New Member
    Jim F
    I dont know if it was just cheap ebay and Amazon bulbs but it has been a headache. Some have lasted others have been through several. The led components are just cheap Chinese parts and dont last. I almost regret switching. I do like the color change from incandescent to white led. It has been almost 5 yrs since my swap.
  5. Aug 31, 2022 at 1:22 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    All the OP's interior lights are 194 bulbs.
  6. Aug 31, 2022 at 1:27 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    The 'sockets' for the bulb are very delicate.
    It doesn't take much to bend them to where the bulb won't stay in.
    The front console is held in with 4 screws.
    One may have to take it down and bend the contacts back into shape.
    Whatever you do, DO NOT REMOVE THE FRONT REFLECTORS.
    You'll never get them back in correctly..
    The rear dome light just pulls down from the rear..
    That reflector will pop in and out.
