Infotainment Screen Bubbles
Discussion in '3rd Gen Tundras (2022+)' started by samschwarzlose, Feb 16, 2022.
  1. Feb 16, 2022 at 9:33 PM
    samschwarzlose
    samschwarzlose [OP] New Member
    Sam
    2022 Tundra Platinum Long Box
    Tonneau cover
    Is there a film I am supposed to remove, or is it an anti-glare protective screen? Mine has a few bubbles and I am wondering if it is something I should remove or leave alone.
    RickyBobbysTundra likes this.
  2. Feb 17, 2022 at 12:13 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Do you have a picture? My screen had a pull tab on the plastic cover that clearly indicated to pull it off.
  3. Feb 17, 2022 at 7:11 AM
    samschwarzlose
    Sam
    Tonneau cover
    on the top right
  4. Feb 17, 2022 at 7:25 AM
    Looks like a protective screen that should be removed after the vehicle is sold.
  5. Feb 17, 2022 at 7:38 AM
    nuclear
    nuclear New Member
    this
  6. Feb 17, 2022 at 8:07 AM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Definitely a screen protector. Enjoy removing the plastic to show a nice crisp screen. I saw someone here buy a glass screen protector like the ones available for phones, so I will probably do that and only pull the plastic off once I have my protector in hand.
    RickyBobbysTundra and dekeman like this.
  7. Feb 17, 2022 at 8:10 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    I'll go somewhat against the grain and warn that if it doesn't come easy then don't force it. A lot of modern monitors have anti-glare films applied to them that are NOT supposed to be removed (the monitor itself is designed/calibrated around the film staying on permanently & the film is 'glued' because of this).
  8. Feb 17, 2022 at 10:23 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    rizico, Mattedfred and Tundrastruck91 like this.
  9. Feb 17, 2022 at 11:37 AM
    samschwarzlose
    Sam
    Tonneau cover
    I tried to peel it from the corner, and it felt like it might be a thicker protective cover rather than just a film. I will try again to maybe separate the two. Thinking it might be a thin film covering over a protective glass like the one you showed. If I wreck it, I will be sure to replace with the screen protector you showed. Thanks!
  10. Feb 17, 2022 at 1:22 PM
    Rwaters
    Rwaters New Member
    That doesn’t look like the screen film I pulled off of both radios in my truck. Kind of looks like the anti glare is messed up.
  11. Feb 17, 2022 at 2:52 PM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    I would strongly recommend taking it to your dealership and showing them the defect before you pull it off. If it's a defective anti-glare film application - it's on them. If it's a yanked off anti-glare film - it will be on you.
    Edit: and an anti-glare film (if that's what it is) is not simply a screen protector. You will mess up your screen removing it & putting a screen protector on to replace it will not help.
  12. Feb 17, 2022 at 3:16 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    To the Dealer Batman!
    ThePolak likes this.
  13. Feb 17, 2022 at 5:06 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
  14. Feb 17, 2022 at 6:26 PM
    maverick129
    maverick129 New Member
    2022 Gray Tundra Limited
    Mine has four small bubbles along the very
    Bottom black portion. Only visible in the right light but frustrating.
  15. Feb 18, 2022 at 9:28 AM
    samschwarzlose
    Sam
    Tonneau cover
    I pulled the trigger. Just a flimsy film.
  16. Feb 18, 2022 at 12:59 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    While adding the screen protector linked above, realized mine still had the factory plastic on it — it was that good and free of bubbles.
    The whole touchscreen is far more responsive now that the plastic is gone. The protector is excellent.
  17. Feb 18, 2022 at 9:13 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I bet that was a relief the second you realized...whew, I'm not messing it up worse! If I had a dollar for every time I was in that situation, am I helping or hurting this situation, lol. I tell people I can fix anything until it's broken.
    Henry1jg and PomDad like this.
  18. Feb 18, 2022 at 9:19 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Noooo!! Now your passenger side turbo wastegate is going to fail.
    Kidding. EVERYONE CALM DOWN
  19. Feb 19, 2022 at 7:31 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    No, but now there will be wind noise through the info screen :rofl:
  20. Feb 19, 2022 at 4:24 PM
    Krayzie11Six
    Krayzie11Six New Member
    Hi guys, new to the Tundras forum.
    I don’t have the truck yet, I’m looking to get the TDR Pro or SR5 Sports. Got couple questions.
    First I was wondering is there any screen protector that is tempered glass that will fit edge to edge?
    Second question anybody know the measurements edge to edge. I couldn’t find any info.
    It looks like the UI is 14”. I found some site that do custom size but I need the dimensions for edge to edge.
    Thanks!
  21. Mar 2, 2022 at 6:21 PM
    samschwarzlose
    Sam
    Tonneau cover
    The Spigen Tempered Glass Screen was too small to fit from edge to edge. It also had a notch for a laptop camera. I sent it back and ordered this.
    https://www.etsy.com/listing/1170014341/2022-toyota-tundra-matte-finish-14?click_key=ec11206d02cfa52139c13753bc495db974628680:1170014341&click_sum=254988df&ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=toyota+tundra+accessories&ref=sr_gallery-1-3&frs=1&bes=1
    I will let you know if it works, but by the looks of the video, it should be perfect.
  22. Mar 3, 2022 at 9:00 AM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    TheOCDPlugShop, that's what I went with, fits well, works well, and makes me happy......
  23. Mar 3, 2022 at 2:17 PM
    samschwarzlose
    Sam
    Tonneau cover
    How was the application process? Was it a soapy mess?
  24. Mar 4, 2022 at 8:33 AM
    Buckeye88
    Buckeye88 New Member
    Nate
    22 Tundra Limited
    I feel like mine may also still have factory plastic. I don't see bubbles but it isn't quite as responsive as I'd expect. Did yours have a pull tab anywhere for removal?
  25. Mar 4, 2022 at 8:43 AM
    samschwarzlose
    Sam
    Tonneau cover
    It did not have a tab. But if you remove it, I would suggest getting a screen protector like the one I posted above. I did notice a couple of small scratches that happened between pulling off the old film and applying the new one. Also the matte finish on the new screen protector prevents any smudges or finger prints.
  26. Mar 4, 2022 at 11:06 AM
    Buckeye88
    Nate
    22 Tundra Limited
    Thanks for the quick response. I ran out at lunch and pulled the plastic off mine. The glass behind feels 100% better while navigating the menus. I agree that an additional screen protector will be a wise investment.
    3rd Gen Tundra buyers - Check for that film! It looks like a lot of dealers are leaving the film on and it impedes screen use (even if it doesn't have bubbles)
  27. Mar 4, 2022 at 11:31 AM
    samschwarzlose
    Sam
    Tonneau cover
    6DB1D978-9584-4B40-A1FC-3B7BDE07501D.jpg BTW the screen protector from OCD plug company fits perfect and functions great as anti-glare and anti-fingerprint. Thumbs up.
  28. Mar 5, 2022 at 3:20 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    Getting some irritating glare from the Spigen protector, will probably swap for the OCD.
  29. Mar 8, 2022 at 2:18 PM
    maverick129
    Was this hard to install? Any issue with screen brightness or touch sensitivity? I am about to pull the trigger on this!
  30. Mar 8, 2022 at 3:09 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I'm sure going to upset a lot of people, but damn that looks like shit!!!!
    TundraLaw likes this.
