Info on BxFx OBD Dongle Engine Gauges Monitoring 1st Gen Only
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Aug 14, 2020.
  1. May 4, 2021 at 1:19 PM
    #121
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Unsure on the Veepeak, but on the BxFx you can read the codes that the engine throws. Its a basic code reader. Does not dive deep like a $4k unit can do. Yes you can reset. Read the product reviews for a better understanding. BxFx had like 18k reviews last years which gives a good understanding.
  2. May 4, 2021 at 4:54 PM
    #122
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Sounds great, thanks. Read through the thread and didnt see anyone had used the "BlueDriver" so because I like the idea of what you guys did I figured i'll guinea pig that one and see how the all in one scanner & app work together, especially for our year of trucks.
    it is currently on order
  3. May 10, 2021 at 6:14 AM
    #123
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Something's awry...I'm usually 3 mph off @30 and 7ish off at 70. That's with a gps speedo app on phone...so about 10%.
  4. May 10, 2021 at 11:29 AM
    #124
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Did you select GPS speed in torque?
    What size tires/gears do you have?
  5. May 10, 2021 at 7:42 PM
    #125
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    When I had 265/75/16, my speedometer was off 2mph no matter what the speed was according to Torque. Now with even bigger tires, it’s almost 4mph off. I’ll check it again against my phone app speedometer.
  6. May 11, 2021 at 4:09 AM
    #126
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Gears unsure of as I believe it was probably regeared for 35 inch tires. I may have just selected cpu. 305/70/17.
    I expect it to be off but more consistently compared to before I had this dongle
  7. May 12, 2021 at 4:48 AM
    #127
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Why isn't this in the info dump page? I'd hate for this to fade away.....
    @ColoradoTJ can you link this in the info dump page?
  8. May 12, 2021 at 5:17 AM
    #128
    Done. :thumbsup:
  9. May 12, 2021 at 4:12 PM
    #129
    tyler-brown
    Canada, B.C.
    New toy arrived.
    Super easy to pair and set up and tons of options. You can scan your truck codes on varying levels. Check for misfires, smog check (if that sort of thing matters to you) but it didn't readily recognize the toyota (not supported by Toyota? Maybe just my year) but once I put in either my Vin, or just year and truck, it was all good.
    I moved the dongle over to my 2014 cummins because I just recently had a service 4x4 light come up on the dash and the dongle recognized the truck no problem, and offered a bunch of solutions and even offered me prices from different websites. And told me what part was wrong (front axel lock disconnect actuator) replaced the part and light went away.
    It's not overly large, I think you would need to do some serious maneuvering and freaking out to hit it with your foot/leg.
    I like this dongle (not having used ANY others) because It offers me ease to move it from vehicle to vehicle and check codes and diagnose easily (and friends and family vehicles)
    It has a long list of supported gauges to choose from for your live screen.
    I haven't driven anywhere as this truck just sits and waits to get beaten up in the bush. So just sitting in the yard and starting it and watching Temps & dials move. Haha20210512_155857.jpg 20210512_155921.jpg 20210512_155908.jpg
  10. May 16, 2021 at 4:23 PM
    #130
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Anyone else have a problem getting veepeak to pair? Mine did at first now it's showing up just not letting me select it...I've tried disconnecting it and reconnecting it in an acts the same. I go to connected touch the screen and nothing happens.
  11. May 16, 2021 at 6:52 PM
    #131
    SouthPaw
    2000 Limited 4x4 AC
    I use the VeePeak mini and it’s never given me any issues. I can leave it plugged in or disconnect and it always auto connects to my phone.
  12. Jun 24, 2021 at 10:07 AM
    #132
    Hand Protectors
    Less than a year later the Bafx Dongle has become glitchy when reading the Coolant and Transmission Temps. Been a while since using and today plugged it in and she worked for a little while but became stuck on certain temps. Had to unplug and replug after a few glitchy stickies. Will try the Unit again and report back if this continues.
  13. Jul 3, 2021 at 9:49 PM
    #133
    SouthPaw
    2000 Limited 4x4 AC
    For those who don’t know, you can set up audible alarms on Torque App to monitor activity. I have recently setup an alarm for volts since I have been noticing spikes lately. This allows me to pin point RPM’s, speed, engine temp, etc when I am seeing a spike. You can setup multiple alarms for almost anything. This is the video I used to set mine
    https://youtu.be/x7ZuXT-C0aM
    KNABORES likes this.
  14. Sep 12, 2024 at 9:29 AM
    #134
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    Been a while now,so presuming peeps here are very satisfied w/these OBD dongles.
    Presuming this is as close as FGTs will get to a CANBUS system that can feed data to latest gen of radio HeadUnits. So then this will be the most cost effective way to realize that data [also presuming the OBD dongles cant feed their output to the latest HU's]. ?
    Given all that, I've read this thread in its entirety but dont remember all the i & t's and hoping someone could please short-cut me to the right OBD tool to use that would work for my 06 Tundra as a dynamic engine data display and logger, AS WELL as a simple code reader for my 2020 Corolla HBk.
    On the Corolla side I'm not as interested in dynamic engine data as much as I am interpreting "Maintenance Required" messages [oil, brakes, fuel/air filtration].
    On the Tundra side, dont really need videocam recording; more interested in fuel burn, block & trans temps, alternator/battery monitor. I have an old samsung cell I can dedicate to the Tundra but likely use the same unit for intermitent Corolla checks.
