[Info Dump] 2022 Tundra Customizable Parameters Info From TIS
Discussion in '3rd Gen Tundras (2022+)' started by Brums, Jun 13, 2022.
  1. Jun 13, 2022 at 3:02 PM
    Brums
    Brums [OP] New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    Trying to get my moneys worth out of TIS before my subscription ends, attached below you will find the customizable parameters that are shown to be available for the 2022 Tundra Gas and HV AS OF 6-13-2022
    Links inside the PDF's WILL NOT WORK, unless you have an active TIS subscription and are currently logged in.
    looking through them, most are only able to be completed with the Techstream, but there are a few that you can do from the gauge cluster / steering wheel buttons
    Hope this helps anyone looking for information, I'm not a Toyota mechanic, I currently don't even have a truck yet to be able to test out any of these.
    Thanks
    1. CUSTOMIZE POWER TILT AND POWER TELESCOPIC STEERING COLUMN SYSTEM
    2. CUSTOMIZE ACTIVE NOISE CONTROL SYSTEM
    3. CUSTOMIZE INTUITIVE PARKING ASSIST SYSTEM
    4. CUSTOMIZE PARKING SUPPORT BRAKE SYSTEM
    5. CUSTOMIZE BLIND SPOT MONITOR SYSTEM
    6. CUSTOMIZE SAFETY CONNECT SYSTEM
    7. CUSTOMIZE POWER DOOR LOCK CONTROL SYSTEM
    8. CUSTOMIZE WIRELESS DOOR LOCK CONTROL SYSTEM
    9. CUSTOMIZE SMART KEY SYSTEM (for Entry Function, HEV Model)
    10. CUSTOMIZE SMART KEY SYSTEM (for Entry Function, Gasoline Model)
    11. CUSTOMIZE SMART KEY SYSTEM (for Start Function, HEV Model)
    SEE 9. CUSTOMIZE SMART KEY SYSTEM (for Entry Function, HEV Model) SAME INFORMATION
    12. CUSTOMIZE SMART KEY SYSTEM (for Start Function, Gasoline Model)
    SEE 10. CUSTOMIZE SMART KEY SYSTEM (for Entry Function, Gasoline Model)
    13. CUSTOMIZE THEFT DETERRENT SYSTEM
    14. CUSTOMIZE MY SETTINGS SYSTEM
    15. CUSTOMIZE LIGHTING SYSTEM(INT)
    16. CUSTOMIZE METER / GAUGE SYSTEM.
    17. CUSTOMIZE HEADUP DISPLAY SYSTEM
    18. CUSTOMIZE FRONT POWER SEAT CONTROL SYSTEM (w/ Memory)
    19. CUSTOMIZE SEAT HEATER SYSTEM
    20. CUSTOMIZE CLIMATE CONTROL SEAT SYSTEM
    21. CUSTOMIZE REAR SEAT REMINDER SYSTEM
    22. CUSTOMIZE SEAT BELT WARNING SYSTEM
    23. CUSTOMIZE AIR CONDITIONING SYSTEM (for HEV Model)
    24. CUSTOMIZE AIR CONDITIONING SYSTEM (for Gasoline Model)
    25. CUSTOMIZE POWER WINDOW CONTROL SYSTEM
    26. CUSTOMIZE SLIDING ROOF SYSTEM
    27. CUSTOMIZE PANORAMIC MOON ROOF SYSTEM
    28. CUSTOMIZE POWER MIRROR CONTROL SYSTEM (w/ Memory)
    29. CUSTOMIZE POWER MIRROR CONTROL SYSTEM (w/o Memory)
    30. CUSTOMIZE WIPER AND WASHER SYSTEM
    31. CUSTOMIZE LIGHTING SYSTEM (EXT) (w/ Headlight ECU)
    32. CUSTOMIZE LIGHTING SYSTEM (EXT) (w/o Headlight ECU)
    33. CUSTOMIZE PRE-COLLISION SYSTEM
    34. CUSTOMIZE DYNAMIC RADAR CRUISE CONTROL SYSTEM (for HEV Model)
    35. CUSTOMIZE DYNAMIC RADAR CRUISE CONTROL SYSTEM (for Gasoline Model)
    36. CUSTOMIZE LANE TRACING ASSIST SYSTEM
    37. CUSTOMIZE ROAD SIGN ASSIST SYSTEM
    38. CUSTOMIZE AUTOMATIC HIGH BEAM SYSTEM
    SEE 31 OR 32 SAME INFORMATION
    PGW85706, tronz151, Rcflyersd and 5 others like this.
  2. Jun 13, 2022 at 3:44 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    What I am seeing here is #30 the Auto Wiper operation is available in the HV only? Hmmm.
  3. Jun 13, 2022 at 5:31 PM
    Brums
    Bethel, OH
    looks like its platinum and up trim regardless of gas or hybrid
    ryanwgregg and Maharisc[QUOTED] like this.
  4. May 23, 2023 at 8:55 PM
    ArmyGreen2022
    ArmyGreen2022 New Member
    Many thanks for posting all the options available through the techstream
  5. Jan 25, 2024 at 9:18 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS, HUD, RB
    Is the TIS data and settings shown above valid for the 2024 models? If not, is the TIS data for 2024 Tundras available at a convenient link?
  6. Jan 25, 2024 at 9:19 AM
    ryanwgregg
    ryanwgregg 45,000 miles & counting...
    DFW, TX
    VXKA75L-PSUZZA
    .....OEM+ Mods..... ..I DO NOT WORK.. ....FOR TOYOTA....
    https://techinfo.toyota.com and purchase a subscription...
    IdahoRay likes this.
