Incomplete coolant flush but new pink coolant isnt mixing with old green
Discussion in '1st Gen Tundras (2000-2006)' started by Dustbox, Nov 23, 2024.
  1. Nov 23, 2024 at 12:38 PM
    Dustbox
    Dustbox [OP] New Member
    Southern Utah
    2000 Black AC 4.7l V8 4x4 SR5
    285/75/r16 tires on stock suspension Tubed Bumpers
    When I bought the truck a few months ago I noticed the coolant was green, so two weeks ago I flushed my coolant 5 times using distilled water. I didn't use the block drains, seemed like too much of a pain so I used the hose that connects to the oil filter. After the fifth flush, I was satisfied and put around 2 - 2.5 gallons. I left that bottom hose open when I started filling my coolant so it would push any old coolant or water out, but it didn't, just straight aisin pink. So I know that the remaining fluid (2-3 quarts if my math is right) is green. My plan was to drive it for a week or two letting the coolants mix and then I'd drain/flush and refill with fresh and do that until no green was left.
    But it has now been two weeks and a few hundred miles, and when I drained the coolant both from engine and radiator, it does not appear to have mixed at all.
    I thought that by now I'd have some mixing, the pink coolant I pulled out is barely darker than when it was new. I never drained or flushed the heater core as I was unsure of procedure and it had been two long weekends of working on the truck. I'm assuming that the remaining 2-3 quarts of green are maybe stuck in the heater core, but my heat and AC work perfect, so I doubt its clogged. If I actually did manage to get all the old green out then my new coolant would be mixing with distilled water, but it doesn't appear to be diluted at all.
    Any advice? I know that the mixing coolant can cause some serious headaches that I'd like to avoid.
  2. Nov 24, 2024 at 2:00 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Continue flushing with distilled water, and use all available drains
    shifty` and KNABORES like this.
  3. Nov 24, 2024 at 11:07 AM
    shifty` I'm having daydreams about night things
