In a 2019 Tundra, how to change Outside temperature unit from Fahrenheit to Celsius?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sal_160, Jan 9, 2020.
  1. Jan 9, 2020 at 6:55 PM
    Sal_160
    Sal_160 [OP] New Member
    2019 Tundra Platinum
    I want to change the Outside temperature unit from Fahrenheit to Celsius in my 2019 Tundra and I can’t find how. I looked everywhere without luck.
  2. Jan 9, 2020 at 7:19 PM
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    Should say in your manual
  3. Jan 9, 2020 at 7:35 PM
    P-Factor
    P-Factor New Member
    If I remember correctly there is a "settings app" on your audio/display system. Press the apps button to find.
  4. Jan 11, 2020 at 6:20 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    On mine, I think you can set the units in the driver's info centre. Scroll through with the buttons on the steering wheel until you find the settings.
  5. Jan 11, 2020 at 7:15 AM
    timsp8
    NY
    I think you have to be in park to get to the settings. At least in mine there are more options when in park.
  6. Jan 14, 2020 at 4:01 PM
    Sal_160
    Please let me clarify that I am trying to change the driver’s display and not the touch screen radio/ navigation display. It has an Outside Temp indication in top of the multi-function driver display.
  7. May 22, 2021 at 9:00 AM
    HarrazH
    HarrazH New Member
    Hany
    2019 Platinum Tundra
    TRD Pro Intake TRD Pro exhaust system Tail gate lights and lock LEDs everywhere 295/55-R20
    Hi,
    Have you found out how to do so?
