Improving MPG on brand new Tundra?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by troyle, Nov 9, 2017.
  1. Nov 9, 2017 at 6:32 PM
    troyle
    troyle [OP] New Member
    Cement Tundra TRD PRO
    I just bought a 2017 tundra trd pro and i saw on the display it only has like 6.7 MPG and when i drive it my 'distance to empty' drops like a rock. it has a K&N intake i don't know if its because of that or something else, but with that too low MGP thats kinda freak me out.
    Any susgestions pls? im a new member by the way.
    ColoradoTJ likes this.
  2. Nov 9, 2017 at 6:42 PM
    ToyotaTundraMike
    2015 Tundra
    Drive it more! How many miles?
  3. Nov 9, 2017 at 6:47 PM
    Welcome from Texas!
    GNTundra likes this.
  4. Nov 9, 2017 at 6:53 PM
    Welcome from Ohio!! We like pictures.
    :worthless:
    Watt maker likes this.
  5. Nov 9, 2017 at 6:54 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado. Was the battery disconnected when it was installed? Maybe needs to reset :notsure:
  6. Nov 9, 2017 at 7:04 PM
    troyle
    it had 6700~ miles when i bought it and it already had the intake, but i dont think the intake makes decrease the MGP.
  7. Nov 9, 2017 at 7:07 PM
    troyle
    what if it needs to reset, do i have to reset the battery and the MPG or just MPG? if it won't work i'm gonna pass out lol..
  8. Nov 9, 2017 at 7:11 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    Depends on how heavy your foot is... my mpg dropped initially, but recovered a bit once a eased up at stoplights. That is really low though :notsure:
  9. Nov 9, 2017 at 7:17 PM
    troyle
    i did drive like normal but it didn't change much.:boom:
  10. Nov 9, 2017 at 8:57 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Sounds like the exact same thing I had when I got mine. I figured it to be the new intake and the dealership doggin' it around in quick stop/go traffic.
    Have you check the filter/box assembly?
    I've got the S&B filter system...similar to K&N. Shortly after bringing it home I cleaned the air filter and MAS. I went 8.4 to 13.2!!
    I also do this at every oil change.
    1.) Disconnect the battery
    2.) Unplug the MAS
    3.) Remove, Clean, dry and re-oil filer
    4.) Disconnect the tube between the filter assembly box and the intake.
    5.) Put some painters tape over the intake to keep out any debris
    6.) Get some CRC MAS cleaner. IMO you only need about 10-15 secs worth of spraying, in 5 sec bursts with a 5-10 secs in between. No matter how much you spray, ALWAYS spray in the direction of the air flow.
    7.) Reassemble in reverse order
  11. Nov 10, 2017 at 3:16 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, on idling. My MPGs take a big hit sitting in stop and go traffic. Have you reset the display?
  12. Nov 10, 2017 at 8:36 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    That's way low. Maybe the previous driver towed a lot and you haven't reset the MPG? Either way, hand calc it for a couple of tanks then compare it with the computer.
  13. Nov 10, 2017 at 9:13 AM
    Daze823
    Daze823 New Member
    Donnie
    Fayetteville, NC
    2015 White TRD Pro
    Toyo all weather mats
    The computer shows 2.5mpg more than I actually get, so yours may be reading lower, but my miles remaining seem to be pretty accurate, so not sure. Before I try and fix a problem, I'd make sure you have one, by filling up, reset your mpg reading and one of your trip odometers. Next time you fill up, compare them, and go from there.
    Just for comparison, my 2012 platinum got 13.5 mpg when I lived in stop&ago traffic in ft. Laud., jumped to 15 when I moved to NC. Now my 2015 pro gets 14 in NC, stock.
  14. Nov 10, 2017 at 10:36 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    My computer has been off on the high side by about 3 tenths every time I check against odometer. I only check it manually when I know I have not towed anything.
  15. Nov 10, 2017 at 6:37 PM
    troyle
    thank you so much guys, i really appreciate it!
  16. Nov 10, 2017 at 7:02 PM
    Welcome to the forum.
    My suggestion is to find religion
  17. Nov 10, 2017 at 7:02 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    My miles remaining were zero on last fill up and I only put in 31 gallons
  18. Nov 10, 2017 at 7:23 PM
    troyle
    how do i clean the filter? do i have to oil it after?
  19. Nov 10, 2017 at 7:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @troyle
    First thing is that display on your dash is notorious for being inaccurate. Run a couple tanks and calculate mileage by hand to see what the mpg really is.
    Second, welcome to the forum from AZ!
  20. Nov 10, 2017 at 7:28 PM
    troyle
    thank you i'll do it!
  21. Nov 10, 2017 at 7:38 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon!
  22. Nov 10, 2017 at 8:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Welcome bud. First clear the mpgs. Scroll to the mpg screen and hold down the disp button. Next do a manual calculation after your next fill up.
    Filthy13 likes this.
  23. Nov 10, 2017 at 9:20 PM
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    Great advice so far. I'd start with low hanging fruit as suggested with clearing mpg screen and calculating by hand.
    Then I'd clean the MAF and ditch the K&N for a paper filter. I've seen K&N oil residue literally drip off of MAF's when I sprayed them with MAF Cleaner and where very fine particle dust is concerned like those of us who spend a lot of time on gravel roads, tests have shown the K&N's don't catch it all.
    71_340 likes this.
  24. Nov 11, 2017 at 5:53 PM
    troyle
    thank you so much!
    ccdawnpatrol and joonbug[QUOTED] like this.
  25. Nov 11, 2017 at 5:54 PM
    troyle
    thank you so much!
  26. Nov 11, 2017 at 5:55 PM
    troyle
    and i've just found out that the DRL is not working, do you guys know how to fix it?
  27. Nov 11, 2017 at 8:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    K&N sells a filter cleaner. I usually make a soaking solution with Simple Green. Whatever method, rinse with gentle water flow from hose, opposite airflow! The idea is to move debris out, opposite way it came in.
    I usually let it dry 12-24 hours, before re-oiling. I then let the oil set for a few hours before reinstalling.
    If your filter is designed to be an oiled filter, then yes....you need/should oil it.
  28. Nov 14, 2017 at 6:17 PM
    troyle
    both of them.
  29. Nov 15, 2017 at 6:42 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Dripping off the MAS? That's way too much!!
    It sounds like that time at band camp when we learned how to change the oil in our cars....
  30. Nov 15, 2017 at 7:13 PM
    troyle
    i wonder why? cause mine is the same as yours.
    does your truck have it on?
