Improvements to the OEM LED headlights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jwong1208, Jan 3, 2025.
  1. Jan 3, 2025 at 8:27 PM
    Jwong1208
    Jwong1208 [OP] New Member
    2020 Cavalry Blue Tundra CM TRD Sport
    While I am thankful I have the OEM LED headlights (2020 Tundra CM with the sport package), I found that compared to my wife’s 2021 4Runner (also OEM LED headlights with projectors), the LED headlight output is quite weak in comparison.
    Does there exist anything out there that increases the output of the OEM LED headlights without buying an aftermarket unit?
  2. Jan 3, 2025 at 8:33 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    You need yourself a set of these, they blow oem leds out of the water!!!
    https://www.tundras.com/threads/retrofit-headlights-2014-2021-2-5-gen.112185/
  3. Jan 3, 2025 at 8:39 PM
    Jwong1208
    While I appreciate the work gone into these, they aren’t my style of headlights ):. Do these integrate with the headlight leveling switch in the car? I do load the car a good amount and I like to be able to adjust this in the car. I really do like the look of the OEM LED’s.
  4. Jan 3, 2025 at 9:16 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    Yes they do work with the OEM headlight adjustment switch!!! Everything is factory!
  5. Jan 4, 2025 at 5:06 AM
    You can't compare the output of the 4Runner to the Tundra. The 4Runner uses projectors and the Tundra uses reflectors. Two completely different outputs.
    1lowlife likes this.
  6. Jan 4, 2025 at 7:09 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    If you use your fog lamps while driving at night, why just upgrade your stock fogs lamps to Diode Dynamics or Baja - huge difference vs stock LED fogs.
  7. Jan 4, 2025 at 7:23 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  8. Jan 4, 2025 at 7:35 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Huh....
  9. Jan 4, 2025 at 8:55 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    What part of 'those are ugly' confuses you?:confused:
    panicman, Makoy339 and jayhawknavy02 like this.
  10. Jan 4, 2025 at 9:29 AM
    jayhawknavy02
    jayhawknavy02 New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    5 alive!
  11. Jan 4, 2025 at 6:40 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
  12. Jan 4, 2025 at 6:43 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    Agreed! I did the OEM LED headlights upgrade to my 17. Was still not happy. Got a set of Ridgid fog and mich better. If I was to do it again, I would have gone diode dynamics, even better output.
    I have some koito OEM LED projectors I plan to swap into my original halogen headlights here soon though.
  13. Jan 5, 2025 at 8:33 AM
    seydou
    seydou Distinguished Member
    LOL Everything is certainly not factory.
  14. Jan 5, 2025 at 12:45 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    Meaning the headlights are plug and play and work with the factory headlight adjustment switch on the dash.
