Impact Gun Recommendations
Discussion in '1st Gen Tundras (2000-2006)' started by Griff04, Dec 2, 2023.
  1. Dec 26, 2023 at 10:13 PM
    #91
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Masterforce (Chervon manufactured, Skil plant) hasn't done me wrong and keeps going, but then again, I only work on my own stuff around my own house and vehicles, fine for my needs thus far. My impact driver is their original from when they launched their Flex 20V and I can't help but wonder if a newer one would be a little stronger for the occasional rusty bolt or two, but I do have a nice 4ft breaker bar regardless.
  2. Dec 27, 2023 at 2:56 AM
    #92
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Before I got my new free tool, Ridgid had to escalate to TTI, and the tool was in fact shipped direct from TTI.
  3. Dec 27, 2023 at 6:01 AM
    #93
    hpark21
    hpark21 New Member
    06 Black Tundra TRD Access cab 2WD 4.7L
    You often can get Ridgid high torque 1/2" impact with battery & charger for roughly $190 or so from HD with a little hack.
    You can do it right NOW, for $183 and it will come with 2 4Ah batteries.
    Just go to this link:
    https://www.homedepot.com/p/RIDGID-...Ion-Batteries-and-Charger-R86212KSB/325264378
    On top right hand corner, there is "Free gift with purchase". Press "+" button there.
    If you are not interested in any of the tools there, then just pick one that is highest value ($189 one right now).
    Add both to the cart.
    You will see that HD splits the prices to match $299 total. In my case, it was $183 for impact and $116 for blower.
    Do store pickup which is easier, (but you can also do ship to home) show up to pick up, after picking it up, just return the blower with receipt and get $116 back.
    shifty`, jimf909 and The Black Mamba like this.
  4. Dec 27, 2023 at 7:21 AM
    #94
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I have one question, and it is a simple one. Which one will take the 22mm crankshaft pulley bolt off without making contact with the AC radiator?
  5. Dec 27, 2023 at 10:13 AM
    #95
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    I was able to remove the crank pulley with the Ridgid high-torque. I had removed the coolant radiator and the tool just fit between the crank pulley and the condenser. If I unscrewed the bolt too much I couldn't get the driver out, i.e. it would loosen the bolt and then I had to remove the driver to fully unscrew the bolt.
    I bet the mid-torque (a bit smaller) would remove the bolt no problem (I think that was mentioned in this thread). It'd be interesting to see if the subcompact could get in there to loosen it w/out removing the radiator.
    ATBAV8[QUOTED] and ZappBrannigan like this.
  6. Dec 27, 2023 at 11:16 AM
    #96
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    Earlier this year I bought my first impact. Good grief. I've been wrenching on things for almost 30 years in rusty Kansas and I don't know why I didn't do this sooner.
    Since I have a lot of 20v yellow household tools, I picked up the DCF900. It's a 1/2" drive with up to 1400 ft-lbs of break away torque. It is a beast of a tool and heavy as hell. I've grown to like this big impact so well I am looking to get a compact 3/8" for general disassembly and assembly of parts!
    jimf909 and ZappBrannigan like this.
  7. Dec 27, 2023 at 8:06 PM
    #97
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Hercules. $49.99 @ HF. Lifetime warranty. Drop it in a puddle, beat a rabbid raccoon witg it...return in box, they never question the return. I work in big fuel processing plants and zip of 1" sae flages all day. 50 bolt manways ect...i would get these again. ( they are not *Fuel nice. But if you drop in a 600gal cone of diesel fuel...meh. fish it out, spray some Axe on it and return lol.
    FirstGenVol likes this.
  8. Dec 28, 2023 at 3:44 AM
    #98
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have the same one, Big Donnie. After using a Subcompact unit, I doubt Donnie is going to get much use. Little Ricky is so much easier to hold. I used him yesterday to drive new lag bolts into my walls.
    The full size impacts are overkill for most jobs and don't fit in tight spaces. I wish I had started with the mid torque Rigid.
    jimf909 likes this.
  9. Dec 28, 2023 at 12:11 PM
    #99
    jimf909
    Washington or Idaho
    Yeah, if I do get the subcompact I'd like to walk around and do a Pepsi-challenge between the high-torque and it. Find all of the ugliest, nastiest bolts and nuts and try the sub-compact on them to see what it can't loosen. Then hit it with the high-torque to see if it hammers 'em off.
    Your tool names are funny, cute and probably helpful. My wife calls the 1/4" driver the zoop-zoop and we immediately know what she means. "Should I use the zoop-zoop for the screws in the chicken coop?" "Yep, the zoop-zoop is the right tool for that.":rofl:
