I'm at my wits end- Master Cylinder issues..
Discussion in '1st Gen Tundras (2000-2006)' started by Stats, Feb 11, 2019.
  1. Feb 11, 2019 at 7:33 PM
    Stats
    Stats [OP] New Member
    2005 Tundra LTD
    I have a 05' Limited, dbl/crew cab 4.7l ....no stabilizer control
    The master is leaking into the brake booster.. there is a "extra part" that I cannot find anywhere.
    The configuration I have is like the picture (see below) of which typically goes on an 04 Tundra.. it's the assembly on the left side of the master cylinder-lighter colored part... a "slave" cylinder??? No one sells that part..that I can find.
    I have the component on the right the side... of which is called the master cylinder per ordered part description... which does not include the left side component.
    Evidently Toyota made a few of these 05's with the 04 master cylinder parts pictured.
    Cardone doesn't have any rebuilds.
    Called about 10 other major parts companies, Rock Auto, PartsGeeks, etc... nada
    This part number is 11-3300... but my service advisor say this is the master only.... not the other part as shown...
    Part number 47210L ...is what the dealership has for the entire brake system (master and booster) replacement part number.
    Dealership wants 5K to replace the master and brake booster.. $3800.00 for this configuration alone... yeah.. googled it and others are showing similar prices....as Toyota only sells the entire assembly.. not parts/components.
    at 430K miles... the truck is not worth 5K.. to me it's priceless.
    Summit Racing has led me on for over a week saying they can get the part... and didn't deliver. That's another story.
    Anyone have ideas for a cheaper option as I'm out of time.. and don't have time to search for a pick n pull part in the Ft. Worth, Tx area. I'm in a dealership rental for 10 days now trying for a cheaper alternative.... ANY help will be greatly appreciated.
  2. Feb 11, 2019 at 8:21 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Maybe look at car-part.com?
    YardBird likes this.
  3. Feb 11, 2019 at 8:58 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    junk yard maybe
  4. Feb 11, 2019 at 9:01 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    See if a newer year sells the piece you need with slight or no configuration changes..
  5. Feb 12, 2019 at 3:05 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    The unit shown is the master only, and if it's leaking there would be no reason to replace the booster unless something else happened, but I doubt it. I looked at Rock Auto for a while and did not see that configuration. How about a picture of the one that is actually in the truck. Also, if all else fails take it to a hydraulic build shop and have them put some new O-rings in it. Or DIY. It's not a nuclear reactor. The reason I'm not in the business no more, rip off.
    Corndog123 likes this.
  6. Feb 12, 2019 at 4:49 AM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if you could convert it to the other style.
    landphil likes this.
  7. Feb 12, 2019 at 4:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Or just man up and go old school. Delete power brakes. Manual style. Give them legs a work out.
  8. Feb 12, 2019 at 6:52 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    If you'll shoot me your VIN, I can look up the OEM part for you. It'll be expensive, but not quite as expensive as your local dealer.
    Booney, Sangre Kid, 15whtrd and 3 others like this.
  9. Feb 12, 2019 at 6:56 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    If you have a decent local hydraulic shop, they may be able to rebuild it for you as well. I've had some really weird off the wall auto and motorcycle stuff done this way in the past. Something to consider.
  10. Feb 12, 2019 at 9:27 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
  11. Feb 12, 2019 at 3:08 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    My 06 had that same assembly on it before I removed my abs and I’m not aware of anyone who makes the front distribution block. I’d try reusing the stock one with the new master cylinder.
  12. Feb 14, 2019 at 3:02 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Your truck probably has that electronic brake thingy magigy I read about, or fancy ABS. You can always go old school and put in a regular master cylinder and forget all the fancy stuff. The most important part you want to pay attention to when swapping brake masters is the rod inside and how deep it sits in back of the master. It's adjustable for a reason. You might not have to mess with it, but measure and make sure the new master has the same depth as the old one.
  13. Feb 17, 2019 at 4:19 PM
    BigBone001
    BigBone001 BigBone!
    Charles
    fayetteville NC
    2001 Tundra sr5 extended
    Big brakes front, hid modded headlamp, led modded foglamps, bar lamp inside front bumper, bass box under seat, 2k liftsprings, dimming mirror, dual battery, steering filter
    The part you are referring is between the master cylinder and the brake booster? It also has ONE line from the master going in and the rear brakes connecting on the output? I had an issue with a customer about this before..... Toyota or No one sells it by itself...( at least I haven’t found yet) that part comes as a complete set from Toyota (dunno why)
    In the attachment I scanned the Toyota part numbers (47210L)
    traneld likes this.
  14. Feb 17, 2019 at 6:04 PM
    Stats
    2005 Tundra LTD
    Yes.. I have that part assy dwg as well.
    Hydraulic parts/rebuild house said it had oddball gaskets.. so that idea was out.
    I have picked up a salvage part assy from a '05 w/ 135K miles on it.
    That will go on tomorrow.
    I'll have my assy rebuilt as a back up.
    It cost me a week of rental for ordering, delivery, scheduling in the dealership workflow.
    It was in a yard 4.5 hours away.
    Didn't want to go that route, but had to as this is a "Unicorn" configuration.
    Thanks to all for your inputs.
  15. Feb 26, 2019 at 4:22 PM
    Bqe
    Bqe New Member
    2005 tundra
    I'm having the exact same issue as OP, same year and model. Was waiting on cardon 11-3300 from summit on an overnight delivery as I'm stuck in a rural town 300 miles from home...never showed up. I know that the cardone 11-3300 includes the balancer part that bolts to the booster as I replaced it 8 months ago and it's leaking into the booster again. Hopefully another attempt from advance Auto should be here in the morning. And if not maybe open to see if it can be repaired with new seals.
  16. Feb 26, 2019 at 5:11 PM
    Stats
    2005 Tundra LTD
    I wouldn't be too excited as "I" waited 10 days and NOTHING showed up even when they (Summit-Cordone) said one was on the way...11 days later. Totally useless of a company in my book of experience.
    Cost me $350.00 in rental fees for a broken promise... NEVER will I do business w Cordone-Summit again... Period. The 11-3300 (extra assy) was not part of any assembly I ordered. It was the master cylinder only. There is no part number for the "Unicorn part" I had to order a whole master w/ the "Unicorn part" from a salvage yard.... have 20+ days rental fees for broken promises. 30 days in rental costs total.
    New seals.. Waahhaaaaaaa.... A large hydraulic shop (35 years) said seals were an oddball diameter. O rings no problem. Seals.. Problem.
    I would be sourcing a salvage yard part ASAP as I called EVERY rebuild-mater cylinder supply on the google searches... wrong configuration of master.... or no "unicorn part" supplied.. master cylinder only.
    I sincerely hope it works better for you than it did me..
    Keep us posted on the outcome.
  17. Feb 26, 2019 at 5:20 PM
    Bqe
    Bqe New Member
    2005 tundra
    I'm positive that the 11-3300 from cardone includes the unicorn part as I already had two delivered via summit racing 8 months ago.
    Did u try dissembling the unicorn part at all?
    Problem is cardone offers only 12$ for the core so there's no real incentive to return them. Which is the problem as they have zero cores to rebuild and sell.
  18. Feb 26, 2019 at 5:23 PM
    Bqe
    Bqe New Member
    2005 tundra
    Cardone also offers a service where u send your master in and it's rebuilt and returned. This service needs to go thru a retailer of cardone parts like advanced auto
  19. Feb 26, 2019 at 5:25 PM
    Bqe
    Bqe New Member
    2005 tundra
  20. Feb 26, 2019 at 5:28 PM
    Stats
    2005 Tundra LTD
    Yep.. basically a coupla shafts, washer type seal.. When I talked to Summit a few 3 weeks ago, they told me it would be middle of March before they had any to send out. And that was after they said one was on the way .. then it wasn't on the way because they never received any cores to rebuild. I HATE liars. Yea still a little (lot) pissed at their business ethics. That's ok. I just voted w/my wallet n feet.. moved on.
  21. Feb 26, 2019 at 5:34 PM
    Stats
    2005 Tundra LTD
    I get it... no one had THAT configuration ( your pictured part) and I ordered from TWO different companies that said they had that exact part pictured.... I only received the master cylinder.. in both instances...not the Unicorn part pictured
    Buyer beware...seriously.... start sourcing a salvage yard part... make them show a picture of the EXACT part as I had 2 yards say they had it.. and they didn't.. lying bastages...A-gain.
  22. Feb 26, 2019 at 5:37 PM
    P-Factor
    P-Factor New Member
    Stats,
    Not sure if this applies to your vehicle but it's worth looking into:
    Toyota dealers will replace the brake master cylinder at no cost. Owners of the involved vehicles will be notified by late January. Earlier this week, Toyota announced a safety recall of some Corollas, Sequoias, Tundras and Lexus SC vehicles. About 65,000 vehicles, model year 2002 to 2005 are involved.Dec 15, 2018
    https://myfox8.com/2018/12/15/toyota-recalls-pickups-suvs-to-fix-air-bag-brake-problems/
  23. Feb 26, 2019 at 5:38 PM
    Bqe
    Bqe New Member
    2005 tundra
    Imagine how I'm feeling....stuck 300 miles from home in a motel for the second night with few options on getting this thing fixed. Summit is a reputable company....they're refunding me the full amount for the 11-3300 part that was installed 8months ago. Problem is that cardone has zero pieces to rebuild.
    I also found just the master from centric and confirmed that it was just the front piece without the back unicorn balancer. The one I linked to from summit is both pieces for sure. Cardone is the only one to sell it complete
  24. Feb 26, 2019 at 5:43 PM
    Bqe
    Bqe New Member
    2005 tundra
    Thanks for that...got my hopes up and plugged my Vin in at the nhst web site with no luck
  25. Feb 26, 2019 at 5:58 PM
    Stats
    2005 Tundra LTD
    I did have the dealership install a "new" used salvage part, new booster (O'rileys auto part) and repair other brake warranty items.. and a new alternator. all saind n done.. 1K for rental, 1K for the alternator 800.00 for labor. yeah... 2800.00 vs 6 thousand for my total bill.... didn't talk about the alternator issue til now..
    BQE... this whole mess started because the dealership wanted Five THOUSAND FRECKKIN' dollars to replace the master and booster.. it ONLY comes as a whole assy.
    That can be an option..... I did have someone from this board offer to sell a new assy.. not 5k.. but never did need that option.
    If you need that contact.. let me know... I'll look up the email. I'll have to search it though.
  26. Feb 26, 2019 at 5:59 PM
    Stats
    2005 Tundra LTD
    Recall... No joy here either.... Noothinnnnng to see.. move along..
    thought for a minute I could get a refund...DAMBIT!
  27. Feb 26, 2019 at 6:05 PM
    Bqe
    Bqe New Member
    2005 tundra
    F the dealer.
    I'm going sue Toyota in small claims court. I lost my fuggin brakes on the Thruway....I'm lucky I'm alive. Isn't that what recalls are about?
  28. Feb 26, 2019 at 6:12 PM
    Stats
    2005 Tundra LTD
    YEP... I'm with ya... will be pursuing it as well with this new intel of a recall.
    I have to take the truck back as it's making a squealing noise now.. RPM related.. I hope it's not a bearing on sumpthin' else..
    REALLLLLY don't want to buy a new truck as they don't make this configuration,.. 4 full doors w/ a longer bed.
    430K miles on it... got my muuuuny's wurf' and to spend 50-55K to replace it. Uggggh. sticker shock.
    My tipping point is if I have to spend 5K or more a year maintaining it. .. I'm almost there .... Thinking it's time to turn it.
    Pucks18 likes this.
  29. Feb 26, 2019 at 6:29 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    15whtrd likes this.
  30. Mar 9, 2019 at 4:18 PM
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    Sorry to post to an old thread but...Gave up and sent mine to Cardone to get rebuilt through Oreilly's Auto Parts.
    Summit racing did the same to me. Took my order and didn't say that the part was not actually in stock. They just kept bumping my order back. When I called they said, yep the next date show is the correct date. and then that day came and went and so on.
    my thread on this. https://www.tundras.com/threads/losing-brake-fluid.35583/
