Illuminated ignition ring
Discussion in 'Lighting' started by Jaydawg, Jan 2, 2016.
  1. Jan 15, 2020 at 5:56 PM
    #241
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Damn, I ordered mine from Roman, hopefully it will work on mine, or else im returning it, someone had a 2017 and his worked I think it was @stlfan . If you dont mind me asking @stlfan when you installed yours was it pnp and the pn you got was the 06021. Thanks
  2. Jan 15, 2020 at 6:17 PM
    #242
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    I opened it up to test it and these are the 2 pins that power the led
    Rica25 likes this.
  3. Jan 15, 2020 at 6:33 PM
    #243
    Ely010606
    SPARKS, NV
    Have you tried it again
    Rica25 likes this.
  4. Jan 15, 2020 at 6:40 PM
    #244
    Darren509
    Darren
    Dayton NV
    Tried it again? Installed on my truck yes, and tested with 9v battery
    Rica25 likes this.
  5. Jan 15, 2020 at 6:45 PM
    #245
    Ely010606
    SPARKS, NV
    What did you have to do for it to make it work, just in case i run to that issue. Thank you
    Rica25 likes this.
  6. Jan 15, 2020 at 7:02 PM
    #246
    Darren509
    Darren
    Dayton NV
    Pop black plastic cover off with screwdriver. Attack alligator clips to 9v battery and to any small probes that are conductive, the touch the 2 pins. Note that they are different configurations so the 2 pins on mine might differ from others so start one pin at a time until you find the ones that light it ip
    Toyotoholic, Rica25 and Ely010606 like this.
  7. Jan 15, 2020 at 7:07 PM
    #247
    Ely010606
    SPARKS, NV
    Thanks for the visual that helps out. Thats just to test it, right.
    Rica25 likes this.
  8. Jan 15, 2020 at 7:08 PM
    #248
    Darren509
    Darren
    Dayton NV
    Yes
    Rica25 likes this.
  9. Jan 15, 2020 at 10:54 PM
    #249
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Mine is a 2018 so it uses a different p/n than yours. Have you checked to see if the mating connector has same matching wires and pins? Mine only had 2 wires vs the 4 wires that seem to come on most trucks so I had to splice off the power from the footwell bulb to provide power to the illuminated ring. See posts #105 and #107 for examples.
    Rica25 likes this.
  10. Jan 16, 2020 at 11:29 AM
    #250
    Darren509
    Darren
    Dayton NV
    My connector has 4 wires. Im in the middle of a remodel on my place and its winter so I did not want to take on any projects even small ones. Was hoping to have this plug n play from ebay work. I do not have a footwell lamp either
  11. Jan 16, 2020 at 6:30 PM
    #251
    Ely010606
    SPARKS, NV
    Do you have to disconnect the battery to do the swap, or it’s not necessary. Thanks
    Rica25 likes this.
  12. Jan 16, 2020 at 6:58 PM
    #252
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I didn't disconnect the battery. Mine was just plug and play.
  13. Jan 16, 2020 at 6:59 PM
    #253
    Ely010606
    SPARKS, NV
    kool, appreciate the reply. Thank you
    Rica25 likes this.
  14. Jan 16, 2020 at 7:27 PM
    #254
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
    Sorry for late reply, that is the correct part number and yes it was PNP. My model is SR5, not sure if model of truck is issue or not?
  15. Jan 16, 2020 at 8:09 PM
    #255
    Ely010606
    SPARKS, NV
    No prob , Sweet, i have an SR5 so hopefully it should work also.
    Thanks for the reply.
  16. Jan 24, 2020 at 2:15 AM
    #256
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    danz75...Have you some how wired yours to make it work? I also have 2 wires on my 2020 SR.
  17. Jan 24, 2020 at 9:12 AM
    #257
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    I wired mine off the footwell light so that it illuminates when the door is opened. You can either get the contacts that Toyota sells or purchase contacts online. After doing a little searching online I think on TW, i found out that the TE 1123343-1 is quite close to the factory crimp contact so that's what I used. The contacts that you get from Toyota is already crimped with a short length of wire so you will need to splice in a longer wire to reach the footwell bulb.
  18. Jan 24, 2020 at 9:49 AM
    #258
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Thanks for sharing. So 1 wire goes to the footwell light and the other wire is to ground. Is that how you wired it?
  19. Jan 24, 2020 at 10:15 AM
    #259
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    You could but the wire i used was paired so i just tapped both off the footwell light harness.
  20. Jan 28, 2020 at 6:24 AM
    #260
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Thanks danz75
    Rica25 likes this.
  21. Feb 16, 2020 at 9:06 AM
    #261
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    Wow pretty easy just got it done probably under 10 min worked great on 2019 sr5
  22. Feb 16, 2020 at 9:08 AM
    #262
    NCTundra1980
    Stephen
    2019 SR5
    I left the old one and a screwdriver in my center console just in case the next week guess I’m paranoid lol
    georgiey22 likes this.
  23. Feb 16, 2020 at 10:06 AM
    #263
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My swap was done in December, no issues to here. One of the most helpful mods I’ve done.
    NCTundra1980[QUOTED] likes this.
  24. Feb 16, 2020 at 10:21 AM
    #264
    NCTundra1980
    Stephen
    2019 SR5
    It’s pretty cool little upgrade I am looking forward to tonight to check it out
  25. Mar 21, 2020 at 5:25 PM
    #265
    DeLandSkyjumper
    DeLandSkyjumper New Member
    2020 Black Tundra SR5 CrewMax
    Running boards and Drivers side grab handle
    After a week of having my truck (2020 SR5) and fumbling trying to get the key in, I wanted an illuminated ring then stumbled on this thread.
    Ordered part# 89782-0E010 yesterday and just installed, well it no worky. I’ve pretty much read every reply/post in here, think one of you installed on a 2020 and same thing, never lit up but never saw what the fix or issue was.
    Any help would be greatly appreciated. Btw, I did read where one member tied into the floor build wire harness and then grounded the other wire, could this be the alternative fix?
  26. Mar 21, 2020 at 5:29 PM
    #266
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Your 20’ has push button start. What exactly did you replace?
  27. Mar 21, 2020 at 5:30 PM
    #267
    DeLandSkyjumper
    Actually it uses a key.
    My neighbors ‘20 Platinum is push start.
  28. Mar 21, 2020 at 5:32 PM
    #268
    DeLandSkyjumper
  29. Mar 21, 2020 at 5:45 PM
    #269
    Danman34
    Danman34 New Member
    Danny
    The part number you ordered is not compatible with 2020 Tundras. Don’t think there has been any confirmed one that does work since 20’s with key ignition only have 2 wires and you need a 4 wire pin from the harness.
  30. Mar 21, 2020 at 5:50 PM
    #270
    DeLandSkyjumper
    Well that sucks, it was a 2 pin on my harness, purple and green wire and plugged rite into the new illuminated ring. The new ring even had a purple mark on it that corresponded to the connector from the harness.
    Edited to ad.... wondering now if the other end of the harness is actually even connected for a power source.
