Illuminated ignition ring
Discussion in 'Lighting' started by Jaydawg, Jan 2, 2016.
  1. Jan 29, 2019 at 4:03 AM
    #121
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That makes $114 sound much more attractive...;)
  2. Jan 29, 2019 at 8:50 AM
    #122
    @danz75
    I was wrong, there are 4 wires.....sorry :bowdown:
    Wynnded likes this.
  3. Jan 29, 2019 at 11:56 AM
    #123
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Thanks for the confirmation. I will probably just have to tap the power for the LED from another light source like I did for the switches for my light bar. This makes me feel better knowing that pins 2 and 3 are indeed powering the LED. So it looks like anyone with a 2018 SR5 that is considering doing this mod will not have the wires to make the light work.
    NewImprovedRon likes this.
  4. Jan 29, 2019 at 11:58 AM
    #124
    Tap into the light down by the emergency brake, it functions just like the ring.
    NewImprovedRon and Wynnded like this.
  5. Jan 29, 2019 at 12:03 PM
    #125
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Thanks for the tip, that makes more sense. I have my LED footwell lights already tapped from that bulb.
  6. Jan 29, 2019 at 12:39 PM
    #126
    :thumbsup:
  7. Jan 29, 2019 at 1:38 PM
    #127
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    So for sure it won’t work on a 2018 sr5 ?
  8. Jan 29, 2019 at 2:06 PM
    #128
    2 options,
    Contact @Roman with your VIN#
    Remove 2 screws and unclip to see if you have 4 wires......very very simple to do.
    Roman likes this.
  9. Jan 29, 2019 at 4:13 PM
    #129
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    thanks I will probably do first option first since its going to be around -60 windchill the next 2 days
    ccdawnpatrol likes this.
  10. Jan 29, 2019 at 4:17 PM
    #130
    I would send him a PM now, so he will reply by mid day tomorrow.
  11. Jan 29, 2019 at 4:19 PM
    #131
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks I will send him it in a few
  12. Jan 29, 2019 at 4:22 PM
    #132
    :thumbsup:
  13. Jan 31, 2019 at 9:21 AM
    #133
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Just realized I need some crimp contacts to add the wires to the connector. Does anyone know what type of crimp contacts will fit in this connector?
  14. Feb 2, 2019 at 2:50 PM
    #134
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Finally got warm enough for me to attempt to install without cracking plastic.
    2018 Crewmax Sport with Navi.
    Ordered part #: 89782-0E010
    I had 4 wires. Plug and play. It worked.
    After swapping them out, I dis-assembled the non-illuminated ring.
    The frame-work is the same. 4 receiving pins are present.
    The only difference is the addition of the circuit board and acrylic clear cover.
    I stole Jims photo and highlighted the +/- lead in posts in red from the connector.
    I Popped the tabs on both sides (Red) with a eye glass screwdriver and slide the cover off (blue)
    Above is the non-illuminated base with pins present.
  15. Feb 2, 2019 at 2:53 PM
    #135
    I thought those fingers looked familiar. :rofl::rofl::rofl:
    stuckinohio[QUOTED] likes this.
  16. Feb 2, 2019 at 5:39 PM
    #136
    gs1197tx
    gs1197tx New Member
    TX
    Just installed on a 19 SR5 and works perfect.
    Part # 89782-0E010 $30.73 shipped from Cool Springs.
  17. Feb 4, 2019 at 5:39 PM
    #137
    4RunnerKid
    4RunnerKid New Member
    Oceano, CA
    '19 Cement CM SR5 4x4
    TRD Pro Bilsteins w/ single CB shim, 285/75-17 Falken AT3, Method 701, debadged, ceramic coated, Husky liners
    Same here, works great on my 2019 SR5
  18. Feb 4, 2019 at 5:56 PM
    #138
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Interesting that my 08 SR5 has an illuminated ring, never really noticed honestly but it’s there. Crazy that Toyota took so many features out of the newer Tundras that were there in the beginning. Weird
  19. Feb 4, 2019 at 6:33 PM
    #139
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Did you ever get it to work ??
  20. Feb 4, 2019 at 7:41 PM
    #140
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Not yet. I have a plan but need to find the part number of the connector so that i can buy the correct contacts to power the LED. Didn't have time to take a closer look this weekend.
  21. Feb 4, 2019 at 7:51 PM
    #141
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Sorry if this question has already been answered, but I’m confused as to whether the $30 part #89782-0E010 will plug and play on my 18 CM TRD OFF RD. I see some are having issues with the amount of wires etc., maybe just SRs.
  22. Feb 4, 2019 at 8:06 PM
    #142
    PM @Roman with your VIN# and if so you can get the part from him.
    Roman likes this.
  23. Feb 4, 2019 at 8:07 PM
    #143
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nabbed mine from the Post this eve. Stoked, so I swapped it out while still in the lot.:p Doesn't work. My truck has four wires at the connector that plugs into the back side of the ring. I'll remove it (tomorrow I hope, time) and put a voltage to the ring, and see if the two center wires have anything there. I may have to see if my wiring diagram sheds any insight.:angrygirl:
  24. Feb 4, 2019 at 8:09 PM
    #144
    What part # did you get?
    How much did you pay?
  25. Feb 4, 2019 at 8:13 PM
    #145
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    89783-06021 for 07-17. $112
  26. Feb 4, 2019 at 8:16 PM
    #146
    Strange, I thought at first you bought the wrong one.
    Do you know if that one had 4 pins or 2? The one for the 2018 has 4.
    I would PM @Roman he would know better than me, I'm just brainstorming.
    Go to post #126. Did it look like that?
  27. Feb 4, 2019 at 8:22 PM
    #147
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The ring I removed has seven pins in the receptacle, I never checked the new one. I was in too much of a rush. There are only the for wires though. I'll dig into it, just have to make the time.
  28. Feb 5, 2019 at 11:52 AM
    #148
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    I just dropped the panel on my '18 SR5, took a look and mine has 4 wires in the connector. So, I assume it would work. Granted, I have the SR5 Upgrade package and XSP package, not sure if either would have added the extra wiring that other SR5s don't seem to have?
  29. Feb 5, 2019 at 12:15 PM
    #149
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    @Roman just confirmed it will work for mine
  30. Feb 5, 2019 at 12:52 PM
    #150
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    There are differences in the parts between the 2007-17 and 2018+. From what I can tell, 2018+ all seems to be plug and play. I do not know why one trim level would work and one wouldn't, or what the differences would be.
