If you had $3,500 Spend on a 3 inch Lift
Discussion in 'Suspension' started by HighonFirewood, Feb 15, 2020.
  1. Feb 15, 2020 at 6:35 AM
    HighonFirewood
    HighonFirewood [OP] Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    What would it be?
    There is so much info on lifts but not on pricing of most. I would like Coilovers, new UCAs, and rear shackles. Toytec is about 50 miles from me, and several local 4x4 shops. My budget is 3,500.
    Currently have Ray10s, 18x9 +25 offset. And will be moving up to a 35” tire.
    Rica25 likes this.
  2. Feb 15, 2020 at 6:45 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    If $3500 is your budget, then just pick your favorite color... kings, icons, elka, etc. What are you going to use the truck for the most? Is the lift and 35” tires for off-roading? Or more for looks with occasional off-roading?
  3. Feb 15, 2020 at 7:03 AM
    Zero One Actual
    Bilstein 6112s assembled from Boss 4x4 at top setting.
    Coachbuilder shims to even it out to 3in up front
    UCAs of your choice for budget
    Coachbuilder +3 shackles for rear
    Bilstein or Icon rear shocks.
    3 inches and leveled and will work for off-roading and daily driving capabilities.
    Will work with those wheels and tires.
    Minor flexing or trimming of plastic in wheel well and you will have extra money left over.
  4. Feb 15, 2020 at 11:38 AM
    HighonFirewood
    2019 Tundra
    Off roading every weekend. I am always somewhere on a dirt road in the mountains. But I’m not Baha’ing either. This includes install as Kings are out of my price range and I wouldn’t use them to their full potential (which may happen with any of them)
    Rica25 likes this.
  5. Feb 15, 2020 at 11:39 AM
    HighonFirewood
    2019 Tundra
    I thought 6112’s only get me to 2.5...but appreciate the info. I moved in from 6112s thinking they wouldn’t get me to 3”
    Rica25 likes this.
  6. Feb 15, 2020 at 11:43 AM
    Hhtundra
    Hhtundra New Member
    Icon has some good packages, for 3500 all in, i would check out toytec or bilstein. dont cheap out on uca’s, spend the money on a nice set of ucas, you should be able to do the install yourself, take your time and wd40 all bolts, i broke off a bolt along the rear suspension and had to order theough toyota, pia!!
    Rica25 likes this.
  7. Feb 15, 2020 at 11:46 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings are absolutely in your reach with that budget
  8. Feb 15, 2020 at 11:48 AM
    Hhtundra
    Hhtundra New Member
    Icon also will do 25% off throughout the year, i called them up after a sale passed and was able to get the discount.
  9. Feb 15, 2020 at 11:50 AM
    Grumpy Uncle
    Pat
    CO
    Complete OME with Dakars and SPC's.
    MTRock, Rica25, Black Wolf and 2 others like this.
  10. Feb 15, 2020 at 1:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The best thing to consider is what type of off-roading you are doing. For example if you’re just driving logging roads at 20mph then adjustable res shocks might be overkill. If you want to bomb in the wide open desert/plains then the bigger shock the better.
  11. Feb 15, 2020 at 1:40 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    State48overland
    ask for Erick, he can get you all set up!
    Olson, Rica25 and HighonFirewood[OP] like this.
  12. Feb 15, 2020 at 1:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Does that 3500 include tires or is that a separate budget?
    Rica25, HighonFirewood[OP] and Hbjeff like this.
  13. Feb 15, 2020 at 1:52 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
  14. Feb 15, 2020 at 1:55 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Icon Stage 4, and then just switch out the multi leaf pack for the shackles you want. And then grab some UCAs of your choice... then buy a bunch of meat and beer and find some local Tundras.com folk that can help you install that. The cost to install will destroy your budget. If you have the tools and a full day to work on the truck, definitely go they route. The install of these parts is pretty simple
  15. Feb 15, 2020 at 2:36 PM
    Zero One Actual
  16. Feb 15, 2020 at 2:40 PM
    You're only 50 miles from Toytec and the local experts on CO wheeling. What's the hold up? :thumbsup:
    Adam, HighonFirewood[OP] and Toyokuhl like this.
  17. Feb 15, 2020 at 3:24 PM
    SC_TRD
    Colin
    Round Rock, Tx
    monaco730 and HighonFirewood[OP] like this.
  18. Feb 16, 2020 at 5:22 AM
    HighonFirewood
    2019 Tundra
    Tires would be a separate budget. I do want to say, if I don’t have to spend that much I would love to spend the least amount possible for the best bang for the buck.
    Rica25 likes this.
  19. Feb 16, 2020 at 5:24 AM
    HighonFirewood
    2019 Tundra
    I reached out to them via this forum. I need to go down there some weekend.
    Rica25 likes this.
  20. Feb 16, 2020 at 5:29 AM
    HighonFirewood
    2019 Tundra
    I am hoping to have my truck ride better, but I haven’t had enough experience getting to feel a fox vs icon vs anything else other than Bilstein. So I was hoping for a magical solution (I guess?)..but install locally is atleast 1k-1200ish. I haven’t ever installed shocks so I didn’t want to take it on especially since it’s my daily driver and I have kids in tow..
    Rica25 and Black Wolf[QUOTED] like this.
  21. Feb 16, 2020 at 5:36 AM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    Find someone in your area with Kings, and another with Icon. Ask them to let you ride or test drive the truck. This will give you a good idea on how they ride.
  22. Feb 16, 2020 at 6:58 AM
    I'm about 10 minutes from Toytec.
    @Toytec Lifts has their own install facility and tech. You really need to call them. Tell them your budget. They are local and will do you right based upon your needs. The full OME setup is certainly doable with your budget. There is a forum discount. Call David or Hugo.
  23. Feb 16, 2020 at 7:21 AM
    HighonFirewood
    2019 Tundra
    Appreciate that!
  24. Feb 16, 2020 at 7:32 AM
    The OME ride is good . I had OME coilovers on my 07. @Grumpy Uncle has the rear DAKAR leaf pack too. @Toytec Lifts
    carries the full setup.
  25. Feb 17, 2020 at 11:11 AM
    rustytoys
    rustytoys New Member
    If I had $3500 for a 3" lift then I would probably buy a 4" lift...
  26. Feb 17, 2020 at 11:49 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    OME BP51 for that kind of $
    HighonFirewood[OP] and Rica25 like this.
  27. Feb 17, 2020 at 1:24 PM
    No money left for install.
    HighonFirewood[OP] likes this.
  28. Feb 17, 2020 at 4:49 PM
    HighonFirewood
    2019 Tundra
    Haha..yeah. I started out wanting a level...then it creeped to a 1.9, 2.5, now 3. If I keep going I’ll be at 6 then just go full blown monster truck.
    Toyotoholic, Darkness and Rica25 like this.
  29. Feb 17, 2020 at 4:54 PM
    HighonFirewood
    2019 Tundra
    Yeah, I planned to lift my 4Runner, then Tacoma, and at this point I’m going for it..and not gonna pinch pennies but I gotta have a budget and 3500 is it. Black Wolf, what shocks are you on currently? Appreciate all the info
  30. Feb 17, 2020 at 5:11 PM
    rustytoys
    Haha, gotcha, but if you plan to run 35's then a 4-4.5" lift will give you a little more fender gap and less of that stuffed look.
