If you could tell the Chief Engineer who designed your Tundra to add one feature or accessory
Discussion in '3rd Gen Tundras (2022+)' started by eddiefromcali, Dec 29, 2023.
  1. Jan 16, 2024 at 5:58 PM
    #121
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    @PNW Tundra Mike
    I've noticed my Fresh Air button is off, but so is the Recirc Air button. Do you (or anyone) know if both are off, where is the air being pulled from? I can press one and it lights up, but not sure what the default is if NEITHER is lit.
    pyoung62 likes this.
  2. Jan 16, 2024 at 6:19 PM
    #122
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    That’s what she said.
  3. Jan 16, 2024 at 6:52 PM
    #123
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    What he said!
    Black widow TRD likes this.
  4. Jan 16, 2024 at 6:54 PM
    #124
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    I miss the huge floor space in my F150. So make it removable.
    sandiegosteve and Spartanfam like this.
  5. Jan 16, 2024 at 7:51 PM
    #125
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    My 1794 is like this as well. But then again, so have all the cars I’ve owned with heated steering wheels. If you leave it on long enough, eventually it all heats. But when it’s real cold and you first turn it on, there is a real big difference between the outer and inner part of the wheel.
  6. Jan 16, 2024 at 8:23 PM
    #126
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I believe it blends both fresh and recirculated air when neither is lit. If it’s cool outside and neither is lit, the vent air gets much cooler when you select Fresh Air On. Likewise if you select Recirculate when it’s cool outside the vent air gets warmer. Our Venza, Tacoma, and now Tundra have all acted the same.
  7. Jan 17, 2024 at 6:14 AM
    #127
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    If that is so, how would you get back to that mode? Once you press one of the buttons, pressing it again doesn’t turn the light off, and pressing the other just turns that mode on. If that it what is happening, it’s a pretty crappy design to 1) not explain that in the manual, and 2) not provide any way to get it back to that mode other than by turning the truck off and then restarting it.
  8. Jan 17, 2024 at 7:49 AM
    #128
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    thank you for this.
    no mention of using Toyotas Full Time 4wd system feature ?
    assuming this is because Toyotas full time system is on all the time and affects mpg?
    ryanwgregg[QUOTED] likes this.
  9. Jan 24, 2024 at 8:48 AM
    #129
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    Here’s another one for the list…
    Change the DTE mileage and gas gauge so that 0 means really 0 and E means empty. And the low fuel light comes on before then. Those should not be subjective terms. I don’t want DTE to be 0 miles to some indeterminate and highly variable reserve. And E means empty, not anywhere from 2-8 gallons left. The low fuel light should not come on after I hit 0-20 miles and the gauge is on E. It should come on when I have their definition of reserve, and the DTE should reflect how much more I can go before that’s gone. I understand the argument about keeping the fuel pump cool. But we’re not stupid. If the DTE says 20 miles and the gauge is touching E, the low fuel light should have already come on like every other car.
    ElectricMan likes this.
  10. Jan 24, 2024 at 8:59 AM
    #130
    18" TRD Off Road Wheels
    The buffer is there because people ARE stupid. Crawl under the truck and look how long the fuel tank is. If the fuel pickup is at one end and an incline tilts the fuel away from it, like a steep driveway or mountain pass, I guarantee there'd be some idiot blasting Toyota that the truck died with fuel in the tank. It prevents fuel starvation in "worst case" scenarios, and prevents the headache that idiots would cause for Toyota if it were down to the wire. Read your manual. The low fuel light tells you the approximate gallons that it will activate on, and they have the gauge and DTE set to try and prevent the stupid. They are idiot proofing for the lowest common denominator, not for people who have common sense. Why? Because commons sense people know that running that low is less than ideal in the first place, never hit 0 DTE, E on the needle, or see the fuel light purely because they are not wanting to push to the limit to see how stupid stuff can get.
    Mattedfred and ryanwgregg like this.
  11. Jan 24, 2024 at 9:05 AM
    #131
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    I don’t think so. The Manual says on page 516 that it’s 3.4 gallons. But people on this forum with lots of Toyota experience have said it adjust to 10-20% of capacity based on your mileage. I consider that “highly variable”. The last time I filled up, DTE said 20 miles, the low fuel light had NOT come on yet, and I put in just over 30 gallons.
  12. Jan 24, 2024 at 9:14 AM
    #132
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    I get what you’re saying, and that’s why we have idiot lights. They're there to get your attention. But 0 means 0 and E means E. And I have read my manual. Page 516 says the low fuel light comes on at 3.4 gallons left. You go below that, you’re on your own…you’ve been warned. But I can’t trust that when on my last fillup, the gas gauge was touching E, DTE said 20 miles, the idiot light was NOT on, and I put just over 30 gallons in. I just want the idiot light to come on before 0 and E, not after. Like nearly every other car.
  13. Jan 24, 2024 at 9:26 AM
    #133
    I still don't understand the issue. The DTE, E, and idiot light are not there for the non idiot. Why do you care when it comes on unless you are pushing it to the limit? Now that you know what it does; is it that hard for you, as a non-idiot, to just drive and fuel accordingly? If you have an idiot in your family/household that drive to E/light/DTE of 0 would you not rather that the truck covered their stupid and encouraged them to fuel before running out, or would you rather have to run a gas can out to said idiot?
  14. Jan 24, 2024 at 9:28 AM
    #134
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    In every car I’ve owned that had an idiot light, it came on before the gauge pegged E.
  15. Jan 24, 2024 at 9:34 AM
    #135
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    My biggest concern is that the idiot light didn’t come on before my last fillup, and I had less than 2 gallons remaining. What makes more sense is to have it come on when there’s a set amount of fuel remaining (manual says 3.4g), have the gas gauge reflect that, then use your average mileage to set the DTE.
  16. Jan 24, 2024 at 9:37 AM
    #136
    That's how it should function. If it's not, take it in for a check up. There was a TSB for inaccurate gas gauges IIRC. You might just need a SW update to get it working like you want.
    windblown101 likes this.
  17. Jan 24, 2024 at 9:37 AM
    #137
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    Actually, I’m trying not to. And I appreciate the discussion and different viewpoints. But on my 2023, my gas gauge shows E before the reserve light comes on.
  18. Jan 24, 2024 at 9:42 AM
    #138
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    Yeah, I do, which was the whole point of bringing it up. I just disagree with them using DTE and the gas gauge to reflect the point where I hit the reserve, and not the estimated miles until I’m empty and the actual fuel remaining.
  19. Jan 24, 2024 at 9:46 AM
    #139
    The light should be based on the fuel in the tank, nothing else. If that's not how yours is working, get it looked at.
    Mattedfred likes this.
  20. Jan 24, 2024 at 9:47 AM
    #140
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    Do you happen to know the TSB number? I just tried searching and all I found was a reference to a TSB for inaccurate fuel gauge when on an incline. I haven’t experienced anything like that with my truck. I just had the truck in for the EPB reprogramming and they didn’t find any other outstanding recalls or TSBs for my VIN.
  21. Jan 24, 2024 at 10:03 AM
    #141
    I do not. I just remember it being discussed a while back. Might have been the incline one. Still, the light should come on before you drop below 3 gallons, so it's not functioning correctly. You may be the one that gets that new TSB rolling for it!
  22. Jan 24, 2024 at 10:09 AM
    #142
    And there's our Toyota TSB guru to the rescue. LOL
  23. Jan 24, 2024 at 10:23 AM
    #143
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    August 2023 build date. Dammit.
    And I’ve been around long enough to anticipate the frustration of bringing a vehicle in to the dealership with a “new” problem for which there’s no bulletin on. Especially something that can’t be fixed with a wrench. I can see the invoice now…”customer states…” and “unable to reproduce issue”.
    GODZILLA likes this.
  24. Jan 24, 2024 at 10:30 AM
    #144
    I do not envy the position you're in. Bring your own lube. :sorry:
    ElectricMan and Mattedfred like this.
  25. Jan 24, 2024 at 10:43 AM
    #145
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    “if I'm gonna hurt that much, I'm gonna do it to myself”
    -Lewis Black
  26. Jan 24, 2024 at 10:48 AM
    #146
  27. Jan 24, 2024 at 2:07 PM
    #147
    R100rs
    R100rs New Member
    2022 sr5 off road
    Brighter Interior Lights, old eyes cant see $h*t with these lights. SR5 off road
    22whatwedo likes this.
  28. Jan 24, 2024 at 2:49 PM
    #148
    I think having a "reserve" is awesome. Twice now in the past seven years I ran up on 1.5 gallons of fuel left in the tank while towing heavy. Some things I can't control is traffic and weather. Both times these two things were the culprit.
    I had a buddy replace his 26 gallon tank in his F-250 with a Titan 50 gallon, so I one upped him with a 62 gallon replacement tank. We no longer run low on fuel while towing.
  29. Jan 24, 2024 at 2:51 PM
    #149
    Doesn't Toyota do roadside assistance as well for like two years? This would hopefully stop owners from eating a big bowl of dumbass for breakfast and not having to come service a vehicle that ran out of gas.
    GODZILLA and ryanwgregg[QUOTED] like this.
  30. Jan 24, 2024 at 3:23 PM
    #150
    Spartanfam
    West Michigan
    I would highly doubt that as my ‘24 interior lights are damn near useless.
    Thatonec4 likes this.
