If anyone has any questions about water quality improvement - I can help.
Discussion in 'Off-Topic Discussion' started by Rex Kramer, Jan 12, 2020.
  1. Dec 23, 2020 at 11:03 AM
    #211
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    Yes, and thank you!
  2. Dec 24, 2020 at 9:36 AM
    #212
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    One of the salesman offered an option to rent the units @35 p/month with 2 free bags of salt every month or I can go with a regeneration unit..which should I prefer? Or I can buy outright..
  3. Dec 24, 2020 at 9:45 AM
    #213
    Rex Kramer
    Georgia
    Rentals are only as good as the company installing & servicing the system.
    Are all repairs & maintenance included, and how long do you plan to stay in the house?
    saybng likes this.
  4. Dec 24, 2020 at 9:47 AM
    #214
    saybng
    Gary
    Ventura CA
    Comes with 15yr warranty if something goes wrong, the company has been in business for 30yrs, they are a local company,, as far as staying in this house prbbly longer then anticipated..
  5. Dec 24, 2020 at 9:56 AM
    #215
    Rex Kramer
    Georgia
    Sounds good.
    City or well water, and what is the piece of equipment you get for $35 per month?
  6. Dec 24, 2020 at 11:09 AM
    #216
    saybng
    Gary
    Ventura CA
    Pentair with fleck 5600..non digital unit..also is it bad to cook with soft water? City water.
  7. Dec 24, 2020 at 11:15 AM
    #217
    Rex Kramer
    Georgia
    The 5600 is a lower priced work horse, I always like to put a back-washable carbon filter ahead of a softener on city water to strip out chlorine, byproducts of chlorination / dissinfection and other chemicals that may be in the water. Cooking with this water should bot be a problem.
    nowayout and saybng like this.
  8. Dec 24, 2020 at 1:09 PM
    #218
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Got the seals installed and put back together and so far no leaks. Think the video you provided took care of me - thank you.
    I ran through a regen cycle, happening now and still no leaks.
    During regen, does all the that was put into the tank, get sucked out? How much should remain, if any?
    Water level is at salt level 1 in the pic.
    Salt level is also at 1 directly below the water line.
    Thank You.
  9. Dec 24, 2020 at 2:48 PM
    #219
    Rex Kramer
    Georgia
    You are welcome, I'm here to help.
    I would allow the salt to run completely out, then clean out debris. After it's cleaned out, force it to regenerate one more time... the valve will add a measured amount of water, now add just one bag of salt pellets - whatever the water level is at that point in the process is your normal water level.
  10. Dec 24, 2020 at 2:51 PM
    #220
    purplenova
    Tom
    Ohio
    Nice. Will do sir.
    Merry Christmas
  11. Dec 24, 2020 at 4:12 PM
    #221
    Rex Kramer
    Georgia
  12. Dec 30, 2020 at 7:05 PM
    #222
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    I installed the filter yesterday and today got the wife’s blessing on it. Great tasting water.
    Thanks for the recommendation
    Rex Kramer[OP] likes this.
  13. Dec 31, 2020 at 5:16 AM
    #223
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I’m assuming this can this be installed in the basement as opposed to under the sink. Or do you recommend a different system for this type of install? I would be feeding a new drinking faucet at sink and change the fridge over as well. Thanks!
  14. Dec 31, 2020 at 5:19 AM
    #224
    Toptalktoyota
    2020 DC SX
    My inexpert opinion would be that you could place it wherever you want. Just need longer lengths of 1/4 and 3/8 tubing.
    SOB likes this.
  15. Dec 31, 2020 at 5:44 AM
    #225
    Rex Kramer
    Georgia
    Correct.
    The filter can be installed just about anywhere, and you can T off to a 2nd faucet or the ice maker.
    When it comes to ice makers, these filters have a flow rate of .75 to 1.0 gpm - make sure your ice maker is compatible.
    SOB[QUOTED] likes this.
  16. Dec 31, 2020 at 6:34 AM
    #226
    Rex Kramer
    Georgia
    If you are ordering a Multi-Pure filter please use Distributor # 114579
    Thank you!
  17. Feb 11, 2021 at 4:49 PM
    #227
    TRDZ28
    TRDZ28 New Member
    Southern California
    2014 Tundra TRD 4X4 BRM
    @Rex Kramer Thank you for sharing your knowledge. Based on reading your recommendations in this thread and doing some research, seems like the best route to go is Fleck 2510sxt with vortech tank. I'm in Southern California and looking to reduce hard water. Trying to get a softener before I install the tankless water heater I bought. Water hardness per report of Municipal water is 148 for groundwater and 104 for surface water so it confirms what I see around the house.
    Hard to find that combo you mentioned aside from the following link http://www.glasswatersystems.com/fl25elmeonde2.html
    I upgraded to the stainless steel bypass and that's about it. Any other recommendations or vendors? Family of 5 if that helps.
  18. Feb 11, 2021 at 4:53 PM
    #228
    TRDZ28
    TRDZ28 New Member
    Southern California
  19. Feb 11, 2021 at 5:05 PM
    #229
    Rex Kramer
    Georgia
    That Fleck unit with the stainless bypass looks good... if the water is chlorinated, you need to upgrade the resin to chlorine resistant. And/or you can install a 2510 xst Vortech carbon filter ahead of the softener.
    Is the water hardness measured in grains per gallon (GPG)?
  20. Feb 11, 2021 at 6:54 PM
    #230
    TRDZ28
    TRDZ28 New Member
    Southern California
    It's calcium carbonate measured in mg/L (milligrams per liter). Divided by 17.1 would give you a gpg of 8.65 for ground water and 6 for surface water.
  21. Feb 11, 2021 at 6:56 PM
    #231
    Rex Kramer
    Georgia
    Excellent - that's moderately hard water, and the Fleck system will serve you well.
  22. Feb 12, 2021 at 10:03 AM
    #232
    TRDZ28
    TRDZ28 New Member
    Southern California
    How much would you oversize a system? Based on 5 people which is one more than I currently have, I would need a 25,000 grain system. 5 people x 80 gallons per day x 9 gpg x 7 days a week. If you get a smaller system, is it a matter of adding more grains to upsize it?
  23. Feb 12, 2021 at 10:09 AM
    #233
    Rex Kramer
    Georgia
    a 10x44 Vortech holds about 1 cubic foot of resin, that and a metered 2510 sxt control valve is all you need.
  24. Feb 19, 2021 at 10:29 AM
    #234
    Rex Kramer
    Georgia
    You either have a filter to adsorb the chlorine, or you are the filter that adsorbs chlorine or inhales the gas when showering.
    Pour two clear glasses of unfiltered chlorinated tap water, put 3 drops of OTO in one glass and watch the water change color to yellow or orange indicating the presence of chlorine. Now stick two of your fingers as deep as you can in the other glass, keep them there for about a minute... remove your fingers and add 3 drops of OTO, there should not be any chlorine left to react with the OTO because it has been adsorbed into your skin.
  25. Feb 20, 2021 at 9:34 PM
    #235
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Hey @Rex Kramer ,
    Really appreciate you doing this. It’s a huge help to this forum! I’d also like to jump on the bandwagon and ask some questions.
    Some background on our situation:
    We just bought a place north of DFW out in the country. Water supply is apparently a “co-op”, which I am told means we get half from municipal and half from a well <- this is a new term for me, please correct me if I am wrong. After being here for a couple of weeks, I noticed that there is a slight slimy feel to the water. No abnormal smell, but when I wash my hands, it feels like i can’t rinse the soap off my hands. Also, water tastes like shit. Hard to explain, but its fairly metallic. Started doing some digging around and the toilet tanks are coated in a brownish/reddish type film and there is what appears to be sediment in the dishwasher. I initially assumed it was related to hard water, but Culligan was here today and they said our water isn’t hard. They measured our water and got the following:
    Water test, at least according to the paper they left:
    • Ph: 7.5
    • TDS: ~300ppm
    • Hardness: 0 gpg
    Their recommendation to address what we have:
    • Under sink RO system with 9gal tank - I have a large fish tank, this makes it easy to do water changes. I am open to other options though.
    • Sediment pre-filter, which I assume is a cartridge style filter. See pic
    • A catalytic carbon whole home filter, Model # RO6, which i presume is like the pic below.
    Before I spend $4k with these people, could I get a second opinion? My “salesman” wasn’t very good and couldn’t explain in detail to what we were getting and since their website is hot garbage, this is what I have been able to put together. Any input is appreciated!
    Thanks!
  26. Feb 21, 2021 at 12:46 AM
    #236
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    Probably been asked but i have a simple one. I have 3 sinks in my house that i would like to put a water filter on (cold side for drinking water). What would you recommend? One has a filter on it now but it lasts like 3 months and the water takes like 12 years to get cold for some reason lol.
  27. Feb 21, 2021 at 5:24 AM
    #237
    Rex Kramer
    Georgia
    Save your $4K !!
    The dual source water supply is not all that strange, and your test results indicate that you have soft water. Soft water is the cause of the slick feeling, use less soap, conditioner, detergent, etc.
    For your drinking water, I recommend a Multi-Pure MP750 that is mentioned in the reply below.
    I would install a spin down sediment filter that treats the whole house, Rusco is the brand I use... it has a clear housing, it is flush-able as well as cleanable. Just make sure you install a cut-off valve on either side of it. http://www.rusco.com/index.php/product1/spin-down-and-sediment-trapper-filters
    The best value in drinking water filters is a solid carbon block filter from Multi-Pure. The MP750 can supply two, sometimes three separate dedicated cold water faucets, and you change the filter cartridge one a year. You can also install a filter for each sink. Read about them here http://athenswater.com/MulTi_Pure.htm and be sure and use my Distributor # 114579 so I receive credit for the sale - thank you.
  28. Feb 21, 2021 at 6:37 AM
    #238
    coTony
    Tony
    Montrose, CO
    Anyone have experience with H2O Concepts that is saltless system? A lot of claims but wondering why they are not advertised that much if they are what they claim
  29. Feb 21, 2021 at 6:49 AM
    #239
    Rex Kramer
    Georgia
    "scale prevention"
    Don't waste your money.
    Ion exchange is the very best way to soften household water.
  30. Feb 22, 2021 at 8:26 AM
    #240
    coTony
    Tony
    Montrose, CO
    Is there a way to locate where I can buy
    “a metered 2510 sxt Fleck control valve on a 10x44 Vortech tank for the softener”
    All of my searches to find such a setup comes up empty and nobody can help me. According to you I can you ship it to me but you said I can get it cheaper locally. Where?? That is the help I am looking for, these are not like going to a store and picking out your valves and tank and tell the place that is what you are looking for. If there is a way to do that PLEASE a let me know. Would really like to get my soft water installed
