If anyone has any questions about water quality improvement - I can help.
Discussion in 'Off-Topic Discussion' started by Rex Kramer, Jan 12, 2020.
  1. Nov 12, 2020 at 4:58 AM
    #181
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    They are adjustable, and filter tanks work best when the pressure never drops below 40 psi. Also, you may want to account for the 4 psi of pressure drop each tank results in.
    Mountun Goat likes this.
  2. Nov 12, 2020 at 6:01 AM
    #182
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    The farthest, upstairs toilet now flushes properly without having to hold the handle down :fistbump: and it doesn’t take a half hour to fill the tub! Thanks
  3. Nov 18, 2020 at 4:48 PM
    #183
    jmac30
    jmac30 New Member
    2018 platinum
    Hi Rex thanks for doing this! On well water and water quality good! Have a secondary feed from "city" water that I haven't hooked up yet - quality has been iffy so would like to put in a whole house filter - what would you recommend for this? Will be putting in a couple of double back flows one on each feed to prevent cross contamination. Any other recommendations - ph a little low 6.69 @ last test! Thanks
  4. Nov 18, 2020 at 5:59 PM
    #184
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    @Rex Kramer I live in AZ where the water is pretty hard. I recently had a plumber out to fix a few things, and he tried to sell me on an electric water softener system (I currently have a salt system). Thoughts on the electric one? Do they actually work?
    Apologies in advance if this was covered earlier in the thread, I haven’t gone through every page yet...
    glowblue likes this.
  5. Nov 19, 2020 at 6:47 AM
    #185
    Rex Kramer
    Georgia
    A whole house carbon filter and softener plus a U.V. light may be all you need, but keep an eye out for blue green stains where water drips. I f you see blue green stains, you will also need an acid neutralizer.
    jmac30[QUOTED] likes this.
  6. Nov 19, 2020 at 6:49 AM
    #186
    Rex Kramer
    Georgia
    I have yet to find any method that actually softens water without using resin and salt, stick with what you have.
    Bob_Wiley[QUOTED] likes this.
  7. Nov 27, 2020 at 1:44 PM
    #187
    Rex Kramer
    Georgia
    Death by Iron.
    This afternoon's service call involved replacing a 27 year old RainSoft softener with a modern metered softener that has High mesh resin to better handle the Iron.
    I can normally repair these valves locally, but this one was beyond repair.
  8. Dec 20, 2020 at 7:01 AM
    #188
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    @Rex Kramer I'm not sure if this type of unit has been discussed, have you heard of Pentair Pelican? If so would you recommend it? TIA.
  9. Dec 20, 2020 at 7:12 AM
    #189
    Rex Kramer
    Georgia
    I am a Pentair dealer, but I don't deal in their lower end products - that's not the segment of the market I cater to.
    saybng[QUOTED] likes this.
  10. Dec 20, 2020 at 8:27 AM
    #190
    saybng
    Gary
    Ventura CA
    Definitely don't want lower end..
  11. Dec 20, 2020 at 8:30 AM
    #191
    Rex Kramer
    Georgia
    I have found that the Fleck 2510 SXT control valve on a Vortech tank is the best combination for your money.
  12. Dec 22, 2020 at 6:49 AM
    #192
    saybng
    Gary
    Ventura CA
    Good morning, we are looking into different options for water softener, this company Pacific Water solutions is offering a system with Clack premium control valve..have you heard of it? Thank you.
  13. Dec 22, 2020 at 6:54 AM
    #193
    Rex Kramer
    Georgia
    Clack is decent... I still prefer Fleck 2510 SXT
    saybng likes this.
  14. Dec 22, 2020 at 7:10 AM
    #194
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    I just added this valve for filtered water because our fridge only makes ice.
    Works really good and only cost $33.00
    Rex Kramer[OP] likes this.
  15. Dec 22, 2020 at 7:16 AM
    #195
    Toptalktoyota
    2020 DC SX
    This is the filter I use for ice and water. Is it adequate?
  16. Dec 22, 2020 at 7:54 AM
    #196
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Hi,
    we developed a leak in our water softener over the weekend and thought I would bring it up here.
    We have the GE GXSF40H02 water softener - probably a lower end unit based on some previous posts I've read.
    Its leaking water from what appears to be the water softener valve body, best I can tell.
    From some online trouble shooting, it appears a seal kit might correct the problem.
    Just wanted to see if you have ran into this before or may suggest something different.
    Thanks for your time.
  17. Dec 22, 2020 at 8:24 AM
    #197
    Rex Kramer
    Georgia
    I prefer an NSF certified (53) carbon block filter, but what you have is better than nothing at all.
  18. Dec 22, 2020 at 8:25 AM
    #198
    Rex Kramer
    Georgia
    A clear picture or two would be very helpful.
    Dry it off, then photograph where the water is leaking from.
    purplenova[QUOTED] likes this.
  19. Dec 22, 2020 at 8:38 AM
    #199
    purplenova
    Tom
    Ohio
    I will try and get some pics tonight - thank you
  20. Dec 22, 2020 at 9:23 AM
    #200
    purplenova
    Tom
    Ohio
  21. Dec 22, 2020 at 9:28 AM
    #201
    grichg
    grichg New Member
    rich
    What under sink system do you recommend for one person for drinking water that won't break the bank? Prefer buying on Amazon if possible and not overly complicated to install.
    Is that too much too ask for LOL
    thanks and great Post
  22. Dec 22, 2020 at 9:32 AM
    #202
    Rex Kramer
    Georgia
    That is the seal between the tank and valve... it may even be a cracked tank. Bypass the filter.
    This video should show you how to remove and reinstall the control valve.
    https://youtu.be/sH0o71luLX0
  23. Dec 22, 2020 at 9:33 AM
    #203
    Rex Kramer
    Georgia
    https://www.athenswater.com/MulTi_Pure.htm
  24. Dec 22, 2020 at 9:46 AM
    #204
    saybng
    Gary
    Ventura CA
    Just got a text from one of the companies that will be giving me a quote, they use fleck 5600..
  25. Dec 22, 2020 at 9:50 AM
    #205
    Rex Kramer
    Georgia
    5600 works, just make sure it has the SXT digital controls.
  26. Dec 22, 2020 at 11:23 AM
    #206
    purplenova
    Tom
    Ohio
    Thank you - Im sure this will help me..
  27. Dec 23, 2020 at 9:13 AM
    #207
    Toptalktoyota
    2020 DC SX
    Thanks for the recommendation. Wife has been saying she doesn’t like the taste of the water from our existing filter. Ordered this setup last night. Hoping it will give great tasting water.
  28. Dec 23, 2020 at 10:16 AM
    #208
    Rex Kramer
    Georgia
    Excellent!
    Did you use Distributor # 114579 ?
    There is still time to call Multi-Pure and give them that ID number.
  29. Dec 23, 2020 at 10:29 AM
    #209
    Toptalktoyota
    2020 DC SX
    No I didn’t. Will that give you credit for referring?
  30. Dec 23, 2020 at 10:34 AM
    #210
    Toptalktoyota
    2020 DC SX
    I just called them and gave your distributor number.
    Thanks again!
    I’ll let you know how the wife likes it.
