Idling the truck for extended periods
Discussion in 'General Tundra Discussion' started by Jackstraw, Aug 7, 2021.
  1. Aug 9, 2021 at 7:29 PM
    Sorry, missed your quote.
    I agree with what you said. Modern diesels have high idle for "wet stacking" or "cylinder wash" and for the most part works well in cold weather due to grid heaters/glow plugs. I have seen engine damage/excessive wear from my days back when I worked part time in a Cummins shop from extended idle. Some had under 70K miles. When doing leak down tests, having low cylinder pressure and no injector/maintenance issues it's hard to say extended idle times didn't have something to do with it.
    When using a PTO, obviously load is being put on the motor to keep cylinder temps up. I have diesel trucks at work that have some serious run hours vs mileage without any issues.
    I think the article is pretty spot on.
  2. Jan 13, 2024 at 6:13 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    I’m resurrecting this thread. My one owner 2017 has an aftermarket remote start and was listed as a company vehicle - so I presume it was idled heavily as a construction rig. Now, I’ve done 12k trouble free miles but how do I find out my engine hours on a tundra? Thanks
  3. Oct 16, 2024 at 8:50 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Trying again to resurrect this. ^ same question as above. Still wondering if there is a way to find out how many engine hours are on my truck
  4. Oct 16, 2024 at 12:09 PM
    tundras00
    tundras00 New Member
    There is a reason why people like me avoid at all costs all corporate, rentals, fleet, and even leases. None of these brackets care for longevity of the vehicle.
  5. Oct 16, 2024 at 12:11 PM
    tundras00
    I thought we had engine hours in the small menu in the dash. I have a 2015, so I know it's there.
