Idler and tensioner pulleys, and belt
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, May 19, 2020.
  1. May 19, 2020 at 10:45 AM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    I'm getting the squeal from the serpentine belt and planning to replace. I'm considering replacing the tensioner and idler pulleys while I'm in there. Anyone have any recommendations for aftermarket pulleys or belt? Just wondering if there's something better out there. Thanks.
  2. May 19, 2020 at 10:51 AM
    kevine0001
    Kevin
    very good idea....thank you!!
  3. May 19, 2020 at 11:14 AM
    Gates belt
    kevine0001[OP] likes this.
  4. May 19, 2020 at 11:20 AM
    kevine0001
    Kevin
    Just called NAPA. With my AAA membership, about $10 cheaper than OEM.
  5. May 19, 2020 at 11:23 AM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
  6. May 19, 2020 at 11:25 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Rotating the pulleys by hand with the belt removed will not emulate the squeak. The belt tensioners are a known issue. I would replace..
  7. May 19, 2020 at 11:51 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Replace the tensioner.
  8. May 19, 2020 at 11:53 AM
    kevine0001
    Kevin
    I just realized that I have an extended warranty on my CPO 2017. Just left message with dealer for a call back, to see if it might be covered. Easy to do myself, but why spend the money if they'll do it. My only concern is dealer will likely ONLY replace the belt and send me on my way...which means, I'll buy the Gates kit and replace the pulleys once I get it home.
  9. May 19, 2020 at 11:55 AM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    I just installed the Gates kit that comes with the pulley, tensioner, and belt. Looked like great quality.
  10. May 20, 2020 at 4:24 AM
    Crunch527
    Iowa
    Not sure if the tensioner is a Toyota 3/36 warranty item...it wasn’t for the Toyota Platinum warranty I have.
    I do know that the part is relatively cheap and not very hard to install. I had the dealer do it at 5k mi due to squealing and I think all-in it was under $300. I have the S/C but its the same tensioner with a longer belt.
    Hardest part is dropping the skid plate (harder if you have the TRD Pro Skid) and rerouting the belt...if you can call that “hard”. A few bolts and the tensioner swaps out.
    Change the oil while you are there.
    Good luck!
    kevine0001[OP] and Luckydog like this.
  11. May 20, 2020 at 6:36 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I won’t call it an ‘issue’, but the tensioner pulley will start to squeak every few years depending on environment/ driving conditions.
    After much research a couple years ago, I replaced my belt with a ‘Gatorback’ belt. It used to be made by Goodyear and was called Gatorback. It’s now made by Continental...I think they call them Elite, Poly V.
    Best belt ever imo. It has angled cross sections that allow the belt to better deal with the various arcs/ curves of the pulley system.
    If you really want to save money;
    If your current belt is in good shape, I’d keep it.
    While you could just replace the pulley, if the seals are okay, I’d just open it up and repack it with some quality grease.
    So long as it’s not a worn out belt that’s loose, I’d just about guarantee the squeak is coming from the pulley b/c the grease around the ballbearings is worn down or out.
    Good luck with it!
    kevine0001[OP] and yoshi82 like this.
  12. May 20, 2020 at 8:08 AM
    kevine0001
    Kevin
    I'll be taking it to the dealer next Tuesday. I got the extended warranty for my CPO 17 when I bought it less than a year ago. So it's all covered. Only thing I'd have to pay for is cost of the belt, if it's worn due to age/use. Pulleys will be covered. If they want to charge me for anything more, I'll just take my truck back and order the kit off of Rock Auto and do it myself for $112
  13. May 20, 2020 at 8:14 AM
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    I just replaced everything due to a sequel when it was humid or after a rain. The OEM stuff is made by Dayco. I got the Dayco idler, tensioner, and belt for half the price of what the dealer quoted me. Looks exactly like the OEM parts I took off. The OEM tensioner I removed has DAYCO stamped on the back of it. Bought my truck brand new in 2016, had about ~44k miles on it when I did the replacements
    The tensioner was what was causing the squeal for me, but I replaced it all as I was removing it anyways
    No issues so far, but only have had it for ~3 weeks or so.
