Idle up switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by HaydenF, Feb 17, 2020.
  1. Feb 17, 2020 at 7:13 PM
    HaydenF
    HaydenF [OP] New Member
    Hayden
    2016 Limited Tundra Crewmax
    3.5 Zone Lift, 35x12.5x18 Nitto Ridge Grapplers, 18x9 Fuel hostage 3 Grey
    I have been reading past threads about adding a idle up switch to our tundras. I was winching some large 30-50ft trees out of a ditch for firewood and my battery couldn’t keep up without cutting power to interior devices. (Yes my battery needs to be replaced. It’s still the factory OEM) increasing the RPMs to 1k was my work around for about 4 hours worth of tree removal. Since then I have ordered a Northstar 27F AGM battery that should be arriving this weekend. I know this will solve my issues, but having a dedicated switch would still be nice. Any ideas on how to do this? I saw a thread that someone put a 10k resistor in-line with the thermostat causing the truck to idle higher..
    NewImprovedRon likes this.
  2. Feb 17, 2020 at 7:21 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  3. Feb 18, 2020 at 4:32 AM
    coTony
    Tony
    Montrose, CO
    I had a manual throttle lock for the accelerator pedal that I used during airing up the tires to keep the air compressor happy at all times and I miss that with that Tundra. I can sit inside and watch the sensors on the dash while the air up/down system is working and I can push the accelerator but not the same.
    This would be a great mod for the Tundra
  4. Feb 18, 2020 at 4:48 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I used a Chevy diode to increase voltage for my northstar 27f. $3.00 mod I found on this forum.
