Idle speed question
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bgriffn67, Sep 9, 2019.
  1. Sep 9, 2019 at 3:22 AM
    Bgriffn67
    Bgriffn67 [OP] New Member
    Bruce
    2016 Crewmax
    Hello all,
    I just bought a 2016 SR5 4wd crewmax. I have never owned a Tundra before and I absolutely love this truck. My question is that the idle speed seems to be high at start up, usually around 1500. Is this normal? Even after the truck has warmed up it idles around 850 rpms. Thanks
  2. Sep 9, 2019 at 3:27 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    2019 pro
    First start it give a wake up call that its alive.
    Wife said it sounds like you're waking up a hungry lion.
    15whtrd, Blueknights75 and iHacker like this.
  3. Sep 9, 2019 at 3:57 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Normal. This is to warm the motor up faster. The ecu combats any issues by dumping excess fuel to keep the cylinders cool while the aluminum motor has time to absorb the heat. This is why it’s common to see higher condensation out the tailpipe on cold starts due to high levels of combustion.
    Perfectly normal
    Blueknights75 likes this.
  4. Sep 9, 2019 at 5:01 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Also to begin pushing oil and developing oil pressure. If you're running the recommended oil weight then you're starting off with 0 weight oil. Hardly any oil pressure. For that reason alone I would tell you DO NOT start the Tundra from cold, jam it into gear and then take off.
  5. Sep 9, 2019 at 5:46 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  6. Sep 9, 2019 at 6:23 PM
    Bgriffn67
    Bruce
    2016 Crewmax
    Thanks all
