Idatalink Maestro Info
Discussion in 'Audio & Video' started by smooosh, Jan 12, 2018.
  1. Jan 12, 2018 at 1:32 PM
    smooosh
    smooosh [OP] This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    When you change out your head unit a lot of the higher end head units allow hook up with the
    Idatalink Maestro. The Idatalink Maestro allows you to map your steering wheel controls but also hooks into other functionality to give you more information about your truck. Here is the things you lose and gain when you change out your head unit.
    Lose
    Eco graph. You still have he center console average miles per and the current miles per gallon but you lose the head unit graph which shows a minute by minute MPG graph.
    You lose the navigation tab and the music tab in the "heads up display" so you lose the next turn for gps (if you had gps), the
    compass and the current song.
    Gain
    You dont really lose the compass. You lose it in your "heads up display" but you still have it in your mirror and will gain it on your head unit depending on the one you have.
    Tire Pressure and temperature. Mine is not set correct right now. Left is the front tires and right is the back.
    Battery voltage.
    Door open close
    Drive position
    Check engine and if you have a check engine light you can click on it and view whats wrong without having to hook up a check engine reader.
    Gauge info MPH, RPM, Fuel level, Intake temperature and load.
  2. Jan 12, 2018 at 1:40 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Hmmmm....on my install I was able to keep Everything. Wonder if it’s due to the model of headunit? I have the Kenwood DNX994S803D4382-84FA-4B17-A0F4-DAB9F633D17B.jpgC64253D5-F3E6-4AB4-BBF2-84208E6854FF.jpgE46A0990-1C20-4E37-87CA-0813023F7B4E.jpg
    When I don’t use apple CarPlay whatever is playing is shown on the center display
    Watt maker, Stroke250 and BuckWallace like this.
  3. Jan 12, 2018 at 1:46 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Nice. Thanks for sharing. I want an aftermarket radio for this reason. Is the obc connection tapped or do they make a pnp connector?
  4. Jan 12, 2018 at 1:49 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    I believe its plugged into the OBD. Can be easily unplugged for any kind of code troubleshooting/diagnostic work at the dealer and then simply plugged back in.
  5. Jan 12, 2018 at 1:50 PM
    smooosh
    Ongoing project
    strange. I have the same head unit. The mpg that you show is the one that's there. Its the graph that was on the head unit that of course is not there. I will have to see why i dont have those 2 things.
  6. Jan 12, 2018 at 1:52 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Oh gotcha....I forgot about that other graph on the headunit...was thinking center display. I know that my installer had to remap some of the buttons. When it was first hooked up the steering wheel controls would only work if the center display was on the radio display....a few minutes later he had it corrected and all working the way it did from the factory.
  7. Jan 12, 2018 at 1:54 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    The maestro module is a great product....now I'm curious about my tire pressures as well. How did you go about finding out which tire is which on the display?
  8. Jan 12, 2018 at 1:55 PM
    smooosh
    Ongoing project
    yeah we had to do the buttons too. being an 18 my steering wheel had more buttons then they expected. Its all working though.
    Vendeta2k[QUOTED] likes this.
  9. Jan 12, 2018 at 1:56 PM
    smooosh
    Ongoing project
    I compared it to the one in the center console.
    I have to go back to get my front camera fixed and they do wheels and tires so im going to have them fix it when i do that. They have to deflate the tires and re pump them up to set them up correct
  10. Jan 12, 2018 at 1:59 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Kenwood DNX994S....we both have the same HU!
    GNTundra likes this.
  11. Jan 12, 2018 at 1:59 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Yeah, my installed had to do the same thing....way more buttons to deal with on our 18's!
  12. Jan 12, 2018 at 2:50 PM
    smooosh
    Ongoing project
    Just double checked. Those screens are blank. Not sure why you have them and I don’t. Are you hooked to the factory amp at all?
  13. Jan 12, 2018 at 3:00 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Anything else needed besides the TO2 and Toyota USB harnesses?
  14. Jan 12, 2018 at 3:06 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    I believe I am still running the rears off the factory amp. My guess is something in the maestro module isn’t set to display that....should be an easy fix for whoever programmed your maestro
  15. Jan 12, 2018 at 3:54 PM
    smooosh
    Ongoing project
    I wonder if any of that is coming from the factory amp. I bypass the factory amp totally and the only setting that is not checked is factory amp in the set up.
  16. Jan 12, 2018 at 3:57 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    Hmmm....no clue.......next time I talk to my installer (close friend) I’ll see if he has any info if you don’t get it figured out by then.
  17. Jan 12, 2018 at 4:01 PM
    smooosh
    Ongoing project
    We tried to use the sto2 also which uses the factory gps antenna but it did not work so yes the 2 things you listed are needed.
    Y0TA PR0 likes this.
  18. Jan 12, 2018 at 4:02 PM
    smooosh
    Ongoing project
    Yah let me know. Going back next Saturday
  19. Jan 12, 2018 at 5:22 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Cool thanks Gino.
  20. Jan 12, 2018 at 5:27 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    I’m getting mine (DNX994S) install in couple weeks.
    So the st02 won’t work with our xm radio antenna? I’m sure a member here used the st02 on he’s sr5 and it worked.
  21. Jan 12, 2018 at 5:42 PM
    smooosh
    Ongoing project
    I did not install the xm. It did not work with the gps like it was supposed to. Xm might have but i did not want it
    Y0TA PR0[QUOTED] likes this.
  22. Jan 20, 2018 at 1:04 PM
    smooosh
    Ongoing project
    As @Vendeta2k said compass and audio tab works and is now working on my truck.
    So all you lose is the minute by minute eco graph that was on the old head unit and the mantence reminder on the head unit. I have not reach an interval yet to know if it will still show in the heads up display.
    Vendeta2k likes this.
  23. Jan 20, 2018 at 1:32 PM
    ninjajay
    Spoolston, TX
    was it just a matter of making sure the right firmware is installed on the Maestro RR?
  24. Jan 20, 2018 at 2:16 PM
    smooosh
    Ongoing project
    The first time they installed it they could not get the st02 to work. Now they did and for some reason the audio screen needs hook up to the factory gps antenna.
    ninjajay likes this.
  25. Jan 20, 2018 at 3:11 PM
    ninjajay
    Spoolston, TX
    Thanks, I was going to skip the sat-to2 since my HU didn't have nav, but I'll pick it up just for that
  26. Jan 20, 2018 at 3:50 PM
    smooosh
    Ongoing project
    Checked on the way home. You also retain turn by turn nav in the center console.
  27. Feb 20, 2018 at 3:29 PM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    @ninjajay did you end up needing the st02 with the 4200nex? I am in the process of installing my 4200nex and wasn't sure if I needed that or not.
  28. Feb 20, 2018 at 8:18 PM
    ninjajay
    Spoolston, TX
    no STO2 needed
  29. Feb 21, 2018 at 5:46 AM
    smooosh
    Ongoing project
    Did you keep all the center console screens?
    You dont need the STO2 unless you want to keep everything and use the factory GPS and XM antenna.
  30. Feb 21, 2018 at 7:07 AM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    I would like to keep nav, but don't think I'll be able to do so.
