ICS FAB 2014+ Dash Mount- ram mount compatible
Discussion in '2.5 Gen Tundras (2014-2021)' started by L3TT3RS, Jan 23, 2019.
  1. Jul 2, 2019 at 7:16 PM
    #61
    Zero One Actual
  2. Jul 2, 2019 at 7:52 PM
    #62
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    these work in gen 2
  3. Jul 2, 2019 at 8:13 PM
    #63
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Lower price...$10 less.
    I still haven't installed mine and I just realized there's a plate for better support.
  4. Jul 3, 2019 at 4:34 AM
    #64
    coTony
    Tony
    Montrose, CO
    I have a 6" RAM arm coming out to hold my iPad over the edge of the dash just above the Stereo and it does not block my view. However this is not the most sturdy set up. Will it be a problem? Don't know but I do know the plates on the inside of the dash really beefs up the rigidity of the dash. For instance if I have my set up installed without the plate and hold the RAM arm and move it you can see the dash moving (110 degrees here in Arizona now) but you put that plate on under and it really makes it a lot more stiff.
    This is by no means fault of ICS's product, this is awesome! It is just my requirement of needing a longer arm which will always amplify any and all play you may have in the system. ICS_Plate-1.jpg
  5. Apr 15, 2020 at 4:32 PM
    #65
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    What length arm would you reccomend to get it over the dash to mount my phone?
  6. Apr 15, 2020 at 4:41 PM
    #66
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    I’d be curious if someone could leave some measurements for this product. I own a Gen 2 and have been thinking of trying this mount out in the space on the dash on the Gen 2.
  7. Apr 16, 2020 at 6:07 AM
    #67
    coTony
    Tony
    Montrose, CO
    The longest one they have. I removed mine because of the vibration40BDD2C4-7D69-4BB3-9F01-EB941485676A.jpg
    Sumo91[QUOTED] likes this.
  8. Apr 16, 2020 at 2:58 PM
    #68
    Sumo91
    TN
    You removed the ICS mount or the long ram arm? I want the rago mount like yours but I'm only getting this mount to hold my phone.
  9. Apr 17, 2020 at 6:55 AM
    #69
    coTony
    Tony
    Montrose, CO
    Both, once I replaced the ICS mount I no longer needed the long arm. Whichever you decide on is an expensive choice just for a phone holder. Hondo Garage has holders that mount to the vents that are a fraction of the cost
    Blue Thunder likes this.
  10. Apr 17, 2020 at 7:14 AM
    #70
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Don't go RAM. It's garbage. The vibration Tony talks about comes from the arm to rubber ball interface. A friend of mine bought the 67D arms after we complained to each other about the shaking on trails. It's worlds better. 67D is metal to metal, so there's no deflection of any rubber. I will buy 67D arms, but there are more pressing truck needs right now.
    coTony likes this.
  11. Apr 17, 2020 at 7:29 AM
    #71
    Blue Thunder
    Washington
    Thanks for the reminder about the Hondo...I just ordered one. Pretty slick option.
    coTony[QUOTED] likes this.
  12. Apr 17, 2020 at 7:40 AM
    #72
    coTony
    Tony
    Montrose, CO
    Yes they are much better. Already had the Ram’s but looking at the mounting options there is nothing close the the edge of the dash. That is what caught my attention to the Rago path
  13. Apr 20, 2020 at 6:18 AM
    #73
    -G-
    -G- New Member
    Grayson
    Philly 'Burbs
    2021 Cavalry Blue
    @azTony - any issues with the Rago mount not having a support plate under the dash?
  14. Apr 20, 2020 at 6:51 AM
    #74
    coTony
    Tony
    Montrose, CO
    Post #64 here shows my under the dash mounting plate from my ICS setup I used to have. It just modified it to use the same hole pattern
  15. Apr 20, 2020 at 7:02 AM
    #75
    -G-
    -G- New Member
    Grayson
    Philly 'Burbs
    2021 Cavalry Blue
    Yes - saw that thanks. Didn't know if you ran the Rago without it to begin with. Regardless - I plan on doing the same and have the plate coming from ICS now. Thanks.
  16. Feb 16, 2021 at 9:44 AM
    #76
    typeone
    typeone about time I realized you could change this...
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Anyone have a CB mounted to this? And if so does it leave any room for a ball to be mounted for something else? Or is the surface just not that big
