Icon Vehicle Dynamics 3.0 Series Remote Reservoir CDCV Coilover
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Feb 22, 2018.
  1. Jan 13, 2020 at 12:53 PM
    coTony
    Tony
    Montrose, CO
    It comes with the Icon front 3.0's and is adjustable as you can see in the pic
    KevinK and Rica25 like this.
  2. Jan 17, 2020 at 6:38 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    i have a poping sound when im backing and turning at same time
    not every time is this normal
  3. Feb 24, 2020 at 9:02 PM
    kylerocker10
    kylerocker10 New Member
    Any particular brands of aftermarket sway bars that you have been looking at? Sounds like an interesting idea, curious about cost.
    Also, I still have clearance issues with the spring cups rotated and after messaging Icon_Adrian apparently the alignment is also very important for clearance. Is anyone running the 3.0’s with a sway bar and no clearance issues? I’m curious what the alignment specs would need to be.
    A33C1C1C-E986-40A1-AF73-9468688686B8.jpg 6904BBC4-155A-4265-AD32-5F2D018BEAA9.jpg 816FBD91-7752-4653-A23A-C3D88DA566F0.jpg
  4. Feb 25, 2020 at 3:12 AM
    coTony
    Tony
    Montrose, CO
    It would be different if the install directions tell the installer the problem with the sway bar and what to expect which is to remove the sway bar.
    The only after market sway bar I know of is like a $1800 route and that is too much for a freaking sway bar
  5. Feb 25, 2020 at 4:06 AM
    Theonlyway
    Theonlyway New Member
    User
    I’m trying to decide today if I should got the 3.0 route but seems some have issues, is this issue only on those who have sway bars? I’m either going stage 9 or stage 9 with 3.0 front
  6. Feb 25, 2020 at 8:17 AM
    kylerocker10
    The 3.0’s are awesome if you don’t mind ditching your sway bar, those are the only issues I’ve had with mine. They ride great off road without the sway bar but far too much body roll on road for my taste.
    TheBeast likes this.
  7. Feb 25, 2020 at 10:36 AM
    coTony
    Tony
    Montrose, CO
    I would think that @Icon_Adrian 's truck he drives should be the ultimate setup and he would not have any sway bar issues at all since he has provided me with the information "if the front end alignment is correct" but what that "correctness" is must be a secret because absolutely nothing I have found on Icon or SDHQ's site (Adrian is a huge SDHQ fan and says they can set you up correctly). This must be why the other lift companies do not offer a 3.0
    What say you Adrian?
  8. Jan 8, 2022 at 5:39 PM
    Cheston
    Cheston Rocky Mountain Tundra
    Redcloud
    2020 Platinum
    Icon 3.0 C4 front and rear bumper
    Anyone here add a winch and bumper up front? I’m sitting way too low on my 3.0’s and need to lift it back up
    coTony likes this.
  9. Jan 9, 2022 at 6:30 AM
    coTony
    Tony
    Montrose, CO
    This is the reason I do not have a winch on the front. You cannot even get 3” of lift out of this kit so why add more weight up front?
  10. Jan 9, 2022 at 11:54 AM
    Cheston
    Redcloud
    2020 Platinum
    Problem is I’m way to retarded to not have winch.
  11. Aug 17, 2023 at 8:31 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Has anyone ever gotten extended and compressed length measurements? If not, I'll reach out to ICON directly.
