Icon RXT Tundra Leaf System
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Feb 26, 2018.
  1. Oct 30, 2021 at 11:44 AM
    #211
    Arminius
    Arminius New Member
    2019 Tundra Crewmax Limited OffRoad
    2.5 Kings OEM, no adjusters, ICON RXT Leaf Pack - Option 1, Fuel wheels, 285/60/20 Nitto Ridge Grapplers E load rating Light Truck, TRD duel exhaust, TRC cold air intake, TRD Pro grill
    I’m going to take off my RXT springs next weekend and put my stock suspension back on. I’m also going to take my 2.5 King shocks, and Camburg UCA’s off next weekend and bring my truck back to factory suspension. I have about 600 miles on the Kings and UCA’s, and about 200 miles on the ICON RXT’s. Never been off pavement and never hauled or towed anything. I’ll be posting everything up for sale here and on OfferUp next weekend. Since I’m not an off-roader I don’t think this setup was the best choice for me.
  2. Nov 2, 2021 at 10:29 AM
    #212
    eSkittles
    eSkittles New Member
    2021 Tundra Amy Green 1794
    one from 4WP! can’t remember what it’s call but it’s around 100
  3. Nov 4, 2021 at 2:39 PM
    #213
    Arminius
    Arminius New Member
    So I e now had the chance to drive it around with no load and with a constant 200 lbs load. The ride quality is noticeably better with a constant load of 200 lbs and the weight causes the bed to sit at least 1 inch lower than an empty bed. Hope this helps.
  4. Nov 25, 2021 at 11:14 AM
    #214
    Arminius
    Arminius New Member
    I removed the RXT leaf pack and put a used set of Toyota OEM TRD Pro springs on it and now the truck rides much better. If I had to do it all over again and buy aftermarket springs I would go with something else with a right and left side that sits level. The ICON springs also made noise which bugged me. Maybe that's something that would have gone away with time and I should have been more patient.
  5. Jan 13, 2022 at 8:38 PM
    #215
    sigh824
    sigh824 New Member
    That's interesting to me, you never off road and never off pavement, what made you steer to KINGs for shocks? Just curious, not bashing or anything
  6. Jan 14, 2022 at 7:45 AM
    #216
    Arminius
    Arminius New Member
    I do go off road occasionally just not the kind where I’m doing jumps or anything hardcore. I wanted to put bigger tires and to do so you need to lift your truck. I didn’t just want to put spacers and blocks so I thought it was better to do it the right way. Well little did I know the ride comfort on the street would be so bad it made driving my truck something I dreaded each time. Le$$on learned!
  7. Jan 20, 2022 at 6:05 PM
    #217
    Arminius
    Arminius New Member
    So did that satisfy your curiosity?
  8. May 3, 2022 at 10:29 AM
    #218
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I have Option 3 installed and one thing to not is the leaf that is inserted into the pack, where they instruct you to install it is shorter and doesn't conform with the leaf pack's "shortest to longest" stacking of the leaf. I
    I've reached out to Icon numerous times over the last 2 years, no one seems to know the right answer here. I now have terrible sag when I hook my boat up to the truck. I wonder if its due to this configuration. It specifically states, insert extra leaf between #2 and #3 leafs. It looks like it should go between #3 and #4. I've never seen a pack stacked like this, and fear this is what is ruining my load carrying capacity.
  9. May 4, 2022 at 6:28 AM
    #219
    coTony
    Tony
    Montrose, CO
    You have had this problem for two years and Icon has yet to rectify the problem?
  10. May 4, 2022 at 6:42 AM
    #220
    1BadTundra
    Clinton
    Too Much to List
    I've called their tech support, I've called numerous off-road shops that deal with Icon... I've emailed just about everyone in the Icon organization with ZERO help!! No one knows why they would set it up this way, or even if this is the proper way to run them. Off road shops say they would stack the leafs in order, forget what Icon says... But for some reason Icon will not address this. I still have them set the way the instructions show. The leaf is clearly shorter than the ones before and after it.
    Stranger yet, I cant seem to find anyone that is actually running the full leaf pack, just to see how they are set up.
  11. May 4, 2022 at 10:52 AM
    #221
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I noticed this when I installed mine. It didn’t make any sense so I just stacked them by length.
  12. May 4, 2022 at 10:57 AM
    #222
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I am planning to add the extra leaf in at some point this week/weekend to go with option 3. Their instructions don’t give much advice on how to do this?l. Could someone help me out and provide a little step by step on how to go about. Is it as simple as using a couple clamps and slowly backing everything off and back on. Thanks in advance!
  13. May 4, 2022 at 11:31 AM
    #223
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't have Icons but I did an AAL on my Alcans. It's actually as simple as you stated. I used a screwdriver to keep the holes on each leaf lined up. Make sure the leaf doesn't hit or rub any rivets on the leaf directly above it and ensure your pack keeper brackets can accommodate the added thickness.
    Mater[QUOTED] likes this.
  14. May 4, 2022 at 12:51 PM
    #224
    1BadTundra
    Clinton
    Too Much to List
    I should have, but didn't because I figured Icon designed them this way, there must be a reason... Now I'm not so sure.
  15. May 4, 2022 at 3:09 PM
    #225
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I remember having this same problem when I was setting up option 2 on my set. I set them up by length as well and haven’t had any problems with the
    shellshock likes this.
  16. May 5, 2022 at 6:12 AM
    #226
    shellshock
    Iowa
    2019 TRD PRO
    That’s what I did. Just clamped it, removed the center nut and slowly backed out the clamps.
    reassembly is a little more difficult cuz you need to get them all to line up as you clamp them together. We used a long screw driver and it wasn’t too bad.
    these are the clamps I used
    IRWIN QUICK-GRIP C Clamp, 6-Inch (225106) https://www.amazon.com/dp/B0000CCXVU
  17. Sep 25, 2022 at 9:03 AM
    #227
    Sheepdog2018
    Sheepdog2018 New Member
    Ron
    Alabama
    2018 SR5 DC 4x4
    6” Maxtrac Lift 35x12.5r18 Atturo M/T Vision Rocker 18x9 +12 Tech 12 volt Sound Borla Cat Back
    Time to replace leaf springs immediately. Looking through this thread it looks like I’ll be headed for option 1 or 2 as I haul rock, tractor and other things regularly. My packs are apparently shot, flat and starting to invert. My question is can I get rid of the 4” block in the rear if I go with these springs? Also, which option would you all go with? I’ve got some 2.5 shackles I can install if needed that I ordered from Pro Form Fab awhile back.
  18. Sep 25, 2022 at 9:06 AM
    #228
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can totally design a pack to accommodate the lift height you want with Alcan springs. Not sure about any others.
    I'm at 7.5" and have no blocks
  19. Sep 25, 2022 at 9:17 AM
    #229
    Sheepdog2018
    Ron
    Alabama
    2018 SR5 DC 4x4
    Thanks texasrho83, I’ve seen them mentioned quite a bit but never considered because of no prices on their website. I just emailed them for a quote on my setup.
  20. Sep 25, 2022 at 9:22 AM
    #230
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lew Weldon owns it and quotes everything. He's very knowledgeable and responsive. They offer a small vet discount too.
  21. Sep 25, 2022 at 9:33 AM
    #231
    Sheepdog2018
    Ron
    Alabama
    2018 SR5 DC 4x4
    Great I’ll definitely use the discount
  22. Sep 26, 2022 at 4:51 PM
    #232
    Sheepdog2018
    Ron
    Alabama
    2018 SR5 DC 4x4
    Got my quote pretty quick for some 4” lifted 300lb over springs. Curious about what you went with on yours since you got a 7” lift. You running shackle to make up height without the blocks?
  23. Sep 26, 2022 at 5:20 PM
    #233
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well mine was a little unconventional due to the fact I went by measurement only and didnt take it to the scales. I'm pushing 480 lbs over stock weight. He originally built a 5" pack but it wasn't enough and I had a solid 1" reverse rake. He sent me 2 AALs and that squared me away.
    I have 2" CB shackles.
  24. Sep 26, 2022 at 5:31 PM
    #234
    Sheepdog2018
    Ron
    Alabama
    2018 SR5 DC 4x4
    Great, you think I’ll be good with the 4” or do I need the AAL’s? I’d really hate to end up with the reverse rake like I’ve got now due to the flat springs. If anything I don’t mind a 1” positive rake.
  25. Sep 26, 2022 at 5:33 PM
    #235
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    As long as you've given him accurate data with measurements and weights (loaded), I'd trust his judgment.
    Sheepdog2018[QUOTED] likes this.
  26. Sep 26, 2022 at 5:34 PM
    #236
    Sheepdog2018
    Ron
    Alabama
    2018 SR5 DC 4x4
    Thanks for all the help. Great looking DC you got!
  27. Sep 26, 2022 at 5:34 PM
    #237
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    He also has shackles that go with the leaves in case you really want everything to be copasetic
  28. Sep 26, 2022 at 5:45 PM
    #238
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks bud. You too.
