Icon RXT Tundra Leaf System
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Feb 26, 2018.
  1. Aug 26, 2019 at 5:17 PM
    kylerocker10
    kylerocker10 New Member
    How would these springs handle riding around empty most of the time and then loading up with a couple dirt bikes and camping gear on the weekend? Option 2 seems like a decent compromise but looks like a lot of lift if the bed is empty.
  2. Aug 26, 2019 at 6:11 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    It is 3” over stock unloaded.
    Bigboitundra and Icon_Adrian[OP] like this.
  3. Aug 26, 2019 at 7:33 PM
    kylerocker10
    I have looked at their website, looking for some real world experiences. How is ride with option 2 and ~600 lbs, how is ride when empty.
  4. Aug 26, 2019 at 8:04 PM
    shellshock
    Iowa
    2019 TRD PRO
    My empty is still +400 lbs, loaded is 500-600 total.
    Not sure I’ve seen anyone running option 2 unloaded.
    Even option 1 is going to be better than the factory. This leaf pack is way beefier than the stock one. Personally, I’d start on 1 and switch to 2 if 1 isn’t enough after some miles. Changing the pack isn’t that difficult.
    kylerocker10[QUOTED] likes this.
  5. Oct 9, 2019 at 8:32 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    Anyone have any onsite on how option 1 is unloaded????I'm normally empty unless I tow
  6. Oct 9, 2019 at 9:03 PM
    shellshock
    Iowa
    2019 TRD PRO
    im running option 2 with 400-500 lbs constant load. I think option 1 with no extra weight would be great. I’m a huge fan of this leaf pack and you can change it down the road if you need to.
  7. Feb 1, 2020 at 5:15 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Does anyone have the shorter spring clips and a couple spare shims? (mine was missing some) I bought the truck on option 3 and want to take it back to option 2, Icon lists the hardware kit as 158509H but I don't see that for sale anywhere.
    And to those who said it's "easy" I don't know about that! It's a fun job for sure.
  8. Feb 1, 2020 at 6:09 PM
    Shelbie67
    Blake
    NorCal
    You thought about calling Icon? They are super helpful
    blackoutt[QUOTED] likes this.
  9. Feb 1, 2020 at 6:13 PM
    blackoutt
    NWA
    OEM+
    Yes but it's 9pm on a Saturday and I want to go camping next weekend! Haha, fine I'll learn to have some patience and call them up on Monday.
  10. Feb 1, 2020 at 6:42 PM
    Shelbie67
    Blake
    NorCal
    You could install as is and add a shim later
  11. Feb 2, 2020 at 11:30 AM
    blackoutt
    NWA
    OEM+
    Next question, one leaf in this pack is thicker than the rest, set at option 3 with all 9 leafs in. Is that the leaf I pull to make it into option 2 or does that make it option 1? It is the third from the top just under the two wrapped end springs. Pulled the thick one and lost 3" of lift from option 3.... this is with coach builder +1 shackles as well. Leafs are now flat static with bumper weight.
    I did solve the shim problem though. Still need shorter spring clips.
    4x4WarriorOfRocks likes this.
  12. Feb 2, 2020 at 11:53 AM
    shellshock
    Iowa
    2019 TRD PRO
    The thin leaf is option 1
    The thick leaf is option 2
    Both leafs are option 3
  13. Feb 2, 2020 at 12:02 PM
    blackoutt
    NWA
    OEM+
    Yep. Thank you! Confirmed with previous owner. The directions read well going from 1 to 2 to 3 but going backwards from 3 to 2 you pull the 4th leaf down since you've already added the extra thick leaf.
    Looks like I accidentally option 1'ed my truck. Back to it tomorrow to get it right.
  14. Feb 2, 2020 at 12:18 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I have the RXT leaf pack and cannot get an answer from anyone regarding placement of the extra leaf. I am using "Option 3"... I put it exactly where the instructions say to, but its a little shorter than the next one under it, making it look like it doesn't belong there, but one under it. Can you clarify this placement is correct?
  15. Feb 2, 2020 at 12:43 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Im in option two that is what it says in the instructions. If you message Adrian from icon on here or SDHQ I’m sure they can verify. Also what lift do you have in front
  16. Feb 2, 2020 at 2:02 PM
    shellshock
    Iowa
    2019 TRD PRO
    I stacked mine by length. Also make sure they are facing the right direction, I had one in backwards at first. The count in the instructions was goofy if I remember right from when I did mine.
    1BadTundra[QUOTED] likes this.
  17. Feb 2, 2020 at 2:23 PM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    A2882FEF-1CAB-4ACC-A3AE-1BF2A858FB59.jpg D30CD7B6-DB44-4912-89C0-317BD0DF6123.jpg 49D95877-B0D9-4CDA-972A-51C71F7FE3BC.jpg I had the dealer replace my under warranty with icon leaf pack options 3
    Ran with stock shocks for a year then replaced with RXT shock
    Decked system loaded is between 5-600 lbs
    Sometimes I feel a little hoppy in back but the load capacity ride is definitely worth it
    Bed hop happens try and not drive on those roads
    Don’t know if this is any help
    I love how it drives
    DECKEDUSA likes this.
  18. Feb 7, 2020 at 9:56 AM
    1BadTundra
    Clinton
    Too Much to List
    I'm on the RC 6" with full length shocks and a 3/8" shim on top.
  19. May 29, 2020 at 8:58 AM
    #49
    Ad4mmd
    Ad4mmd New Member
    2012 Toyota Tundra TRD DC
    Camburg UCA Fox shocks TRD Front/Rear SwayBars TRD Air-box Intake Mod KN Air filters EBC Brakes TRD 3rd Gen wheels/tires JL Subwoofer 700watt PIONEER Nav HU Focal speakers 3way Dynomat Center Console Safe Led Interior Lights
    Does anyone have a review of these leafs on an empty bed offroad ?
  20. May 29, 2020 at 9:04 AM
    #50
    1BadTundra
    Clinton
    Too Much to List
    I run them on the beach in OBX. They are firm, but not hateful. I like them, they do still flex giving it a decent ride. To me its just right, not too firm, but not mushy either.
    4x4WarriorOfRocks and Ad4mmd like this.
  21. May 29, 2020 at 9:05 AM
    #51
    1BadTundra
    Clinton
    Too Much to List
    I should have, I followed the directions, and they came out looking a little weird. They're definitely oriented right, just not in the correct order IMO
  22. May 29, 2020 at 9:27 AM
    #52
    Ad4mmd
    Ad4mmd New Member
    Right now, Im on stock leafs at 100k. I have upgraded to fox and camburg UCA and Shocks and really don't haul to much. So I was very intrested in this set; Since it seems to be adjustable to weight later on. Thanks for the reply. I mainly use my truck as a daily and offroad with under 400 pounds of weight.
  23. May 29, 2020 at 9:44 AM
    #53
    shellshock
    Iowa
    2019 TRD PRO
    Yeah we had to restack them a couple times until we figured out how they actually should be
  24. Jun 2, 2020 at 8:48 AM
    #54
    1BadTundra
    Clinton
    Too Much to List
    Did it chnge the ride quality at all? I'd liek to reorganize mine but if its for no real gain, other than looking right, I can put it off for a little while.
  25. Jun 2, 2020 at 12:53 PM
    #55
    shellshock
    Iowa
    2019 TRD PRO
    with the added weight I have, I’d say it rides stock like. I definitely notice the weight way less than before I did them
  26. Jun 3, 2020 at 7:37 PM
    #56
    SilentSteven
    SilentSteven New Member
    2020 Platinum
  27. Jun 3, 2020 at 8:41 PM
    #57
    Tundra9831
    Tundra9831 New Member
  28. Jun 3, 2020 at 8:50 PM
    #58
    SilentSteven
    2020 Platinum
    ah you’re right. They sell them individually.
    Tundra9831[QUOTED] likes this.
  29. Jun 5, 2020 at 5:46 AM
    #59
    1BadTundra
    Clinton
    Too Much to List
  30. Jun 7, 2020 at 8:20 PM
    #60
    typeone
    typeone about time I realized you could change this...
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Just went from option 1 to option 3 yesterday. Was a super PITA. Didn’t realize you needed a new pin through the center of the leafs? I used whatever one was in there. Also realized the place I had do the install like 3 years ago used my old Toyota u bolts. No idea where the icon ones are now. Need to get them ASAP. Is that pin an issue?
