Icon Rxt springs
Discussion in 'Suspension' started by Hbjeff, Jan 21, 2019.
  1. Feb 2, 2022 at 2:37 PM
    #61
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    Thank you for your info. How is the ride quality on Option 3?
    My springs get delivered Monday…and I ordered Coachbuilder +1 shackles.
    Currently I have factory leaf’s with +3 shackles just like you had.
    I am very undecided on which shackles and what “option” to go with!
    SAGE63[QUOTED] likes this.
  2. Feb 2, 2022 at 2:44 PM
    #62
    SAGE63
    San Diego County
    So far the ride is good. have not been offroad yet. better than the stock springs. just feels comfortable. yeah not a good description... remember for me it is bed load weight >500lbs toss in tools recovery gear and a cooler....gets >650 real fast
    GreatWhiteGax likes this.
  3. Feb 2, 2022 at 2:59 PM
    #63
    Weavin Pro
    SAGE, thanks for all the info…I have a cap, rack, expedition one rear bumper with spare tire swing out…so I’m looking around 650 lbs too!
    I am running 35” tires.
    One last question…what lift are you running in the front? 3” I assume?
  4. Feb 2, 2022 at 3:25 PM
    #64
    SAGE63
    San Diego County
    yes 3".bilstein 6112 at top setting cb shims 2 driver 1 passenger... rear is 5160's
  5. Feb 3, 2022 at 2:04 PM
    #65
    SAGE63
    San Diego County
    Ok so I went and measured today appx 24 center hub to fender up front and appx 27 in back. So about plus 1.5 inches in the rear and minus 1 up front with C4 bumper, warn evo vr 12ks and lights. guess I need to replace my front coils with something with a higher spring rate....
  6. Feb 3, 2022 at 4:54 PM
    #66
    Weavin Pro
    Ok, so at option 3 with 500 lbs, 1.5” from springs, 1.5” from +3 shackle.
    As mine stands 24” in front, 25” in rear.
    Hoping with Westcott I gain an inch in front…and need about 2” in back, which could work out with option 3 and Coachbuilder +1. Looking for about 1.5” of rake.
  7. Feb 3, 2022 at 4:57 PM
    #67
    SAGE63
    San Diego County
    cool glad that helps. what are you doing with westcott
  8. Feb 3, 2022 at 4:59 PM
    #68
    Weavin Pro
    Doing the Westcott 1.5” front lift for the stock 2020 PRO FOX suspension…hope it kind of compensates for my C4 bumper???
    Yotax109 likes this.
  9. Feb 3, 2022 at 5:01 PM
    #69
    SAGE63
    San Diego County
    ah got ya what comprises the Westcott 1.5" lift
    I have the Westcott roof rack for the tundra. Mine is the one on his website for the tundra roof rack...
  10. Feb 3, 2022 at 5:18 PM
    #70
    Weavin Pro
    The lift is a preload spring collar and a top shim, for 1.5” total lift
    I have the Coachbuilder PRO kit now…only got .75” of lift…then down to .25” after C4 bumper.
  11. Feb 3, 2022 at 5:33 PM
    #71
    SAGE63
    San Diego County
    cool. have that kit for the Bilstein but not installed
  12. Feb 3, 2022 at 5:55 PM
    #72
    Weavin Pro
    Nice! It’s about 15 degrees here with 6” of ice and snow…just waiting for a warm up to 30 to install lol
    SAGE63 likes this.
  13. Feb 4, 2022 at 2:36 PM
    #73
    Weavin Pro
    So I took measurements today…I am 24” in the front…24.5” in the back. I understand that’s “level”, but it looks like it’s drooping.
    Let’s shoot for 25 front and 26.5 in rear!
    SAGE63 likes this.
  14. Feb 9, 2022 at 5:55 AM
    #74
    thumper_racer
    thumper_racer Not a New Member
    TN
    2012 MGM Rock Warrior
    Has anyone else experienced the driver side settling more than the passenger side? On mine, the driver side is about 1/2" lower than the passenger. I am running the pack the way they came (option 1).
  15. Mar 1, 2022 at 6:19 AM
    #75
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Yea my experience has been 3/4” drivers side lean in front and about 1/2” in the rear. Gas tank?
    COTundra23 likes this.
  16. Mar 1, 2022 at 6:38 AM
    #76
    SAGE63
    San Diego County
    Lost 1.25" of front lift with the C4 bumper, BD 30" S8 light bar and the Warn EVO VR 12s winch.. ugh
    Btw 1 Coach Builder shim on driver front will level the tundra lean. also I understand the lean is designed in to compensate the road crown....fwiw
  17. Mar 3, 2022 at 7:40 AM
    #77
    thumper_racer
    TN
    Glad I'm not the only one. I don't remember the OEM leafs being off that much, I wonder if you could put a 1/2" block for the driver's side leaf. Guess I should also mentioned, I am running coilovers and have the front very close to being even (probably ~1/8 off).
  18. Mar 3, 2022 at 9:52 AM
    #78
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I've been running RXT's in 2 for a few weeks, including a 500 trip with our teardrop on the back.
    I typically run about 250 or so pounds in the bed, but it's all congregated at the front. Right now my truck measures a true 2 inch over stock following the Toyota FSM measuring procedure. With a couple hundred pounds of tongue weight it still had probably 1 inch of rake, should support my bed rack and RTT perfectly.
    As to the Tundra- lean, that's pretty common. The only way to fix it is coil overs or varying shims up front. I currently have my driver side coil over + 3/8”, and I'm 1/8” low on the driver side front and back. I plan to let the Leafs settle a little bit more before I do a final adjustment and level the truck side to side with 1/2 tank gas.
    As to shock length asked above, these leafs definitely have more droop. I measured approximately 2 ½” more droop than my Fox piggybacks allowed. The right way to correct that would either be limit straps or longer shocks. I have some RXT clickers on order and someone else posted that king 2 1/2's are very similar lengths and should fit.
  19. Mar 8, 2022 at 9:17 PM
    #79
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Anyone have pictures of Icon rxt option 3 with toytec shackles set at 1 inch?
  20. Mar 9, 2022 at 7:59 PM
    #80
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Just ordered this looking forward to seeing how it works for now. At least until my LT kit comes to fruition.
  21. Mar 9, 2022 at 8:10 PM
    #81
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Let us know what you think! I thought the ride was fantastic but couldn’t stand the spring slapping sound it made off-road. I’m hoping that was just an issue confined to my one spring but please let me know what your experience is overall
  22. Mar 9, 2022 at 8:18 PM
    #82
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Will do!
  23. Apr 2, 2022 at 8:16 PM
    #83
    Weavin Pro
    Just installed today. Wescott in front, RXT on option 3 with Coachbuilder +1 shackles.
  24. Apr 2, 2022 at 9:45 PM
    #84
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    What would be the benefit of the RXT over the add a leaf kit Icon offers?
  25. Apr 3, 2022 at 2:09 AM
    #85
    Weavin Pro
    My factory leaf springs were toast! They just can’t carry the weight that I’m carrying.
    SAGE63 likes this.
  26. Apr 12, 2022 at 11:55 AM
    #86
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    so if i use a stage three rxt leaf spring, it will keep the same height in the back of my truck as it sits right now? It is sitting on stock leafs with a 4 inch block on top of them.
  27. Apr 12, 2022 at 12:16 PM
    #87
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I got 5 1/5" over stock with this setup.
  28. Apr 13, 2022 at 6:56 AM
    #88
    Weavin Pro
    I am almost 4"and carrying 600 lbs
    SAGE63 likes this.
  29. Apr 27, 2023 at 12:00 PM
    #89
    Manhoorn
    Manhoorn New Member
    Utah
    2012 Regilular Cab 4.6L 4wd
    Bilstein 2in level
    Reviving an old thread.
    I've been running the rxt leafs on my 2012 Tundra. I've gone back and forth between options 2 & 3 and thought I'd share some observations.
    The instructions refer to replacing or adding the 3rd leaf (counting from the top down). For example, option 3 says to place the aal between leafs 2&3. However, doing so puts the aal (in my opinion) at the wrong place in the pack. The progression of leaf length isn't maintained and the plastic friction pads don't make contact.
    If you place the aal between leafs 3&4 the progression of leaf length is better and all the plastic pads make contact. See pictures below.
    I'm curious if, the first two leafs in the pack should be counted as 1, seeing they are more or less attached by the military wrap. With that theory, I would then be adding the aal between 2&3.
    I've chosen to go with that thinking/method as it "looks correct" regardless of the instructions.
    Perhaps this thinking could be applied to option 2 as well
    SAGE63 and GreatWhiteGax like this.
  30. May 3, 2023 at 8:23 AM
    #90
    GreatWhiteGax
    GreatWhiteGax New Member
    2016 SR5 Silver
    Leveling Kit, Wheels & Tires
    Just got my springs yesterday! Gonna run option 3. Hopefully set up the pack this weekend and install the following.
    The 2nd pic on the bottom looks like the right configuration to me. That would be my interpretation of the install instructions also, (add a leaf between #2 & #3). The top pic looks like you have it placed between leafs #3 & #4 counting down from top.
