Icon RXT Leaf Spring Broken
Discussion in 'Suspension' started by 1BadTundra, May 11, 2022.
  1. May 11, 2022 at 5:11 PM
    1BadTundra
    1BadTundra [OP] New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Hey all, just a heads up. Aside from the poor tech support I've gotten over the last 3 years (documented on many different threads on here)20220511_085249.jpg as to arrangement of the leaf pack, I now have a broken leaf. I contacted Icon warranty dept, and haven't gotten a response. Please learn from my mistake and stay away from Icon.
    reywcms likes this.
  2. May 11, 2022 at 5:14 PM
    1BadTundra
    Clinton
    Too Much to List
    No, I do not wheel this truck, I actually noticed this today while installing air bags since she squats so bad when towing my trailer....My 6000lb (at fully loaded) boat & trailer. This is most likely the reason for the sagging. I really thought they were just wearing out.
  3. May 12, 2022 at 3:19 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I always pull my truck out of the water after launching the boat...
    Crazy those leafs (leaves.?) are only 3 years old with that corrosion.
    Thank you for the feedback, and I hope Icon decides to do the right thing by you.
  4. May 12, 2022 at 8:35 AM
    1BadTundra
    Clinton
    Too Much to List
    I hope so too... Those things started to rust about a month after I installed them. It was nuts! They look as old as the rest of the truck LoL. I live in PA, when we back the boat, we never even get the leafs wet LoL. It looks like I keep it on the Atlantic coast!
  5. May 12, 2022 at 9:32 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    The rust on those is quite considerable. You might have received a bad batch, mine look brand new... granted, I added several coats of anti-rust paint and half a can of dry PTFE before installing them.
  6. May 12, 2022 at 9:35 AM
    1BadTundra
    Clinton
    Too Much to List
    I'm going to reach out to them today if I don't hear back. My truck is down until I get this fixed. This is the leaf you remove when you do the "option 2" setup.
  7. May 12, 2022 at 9:35 AM
    1BadTundra
    Clinton
    Too Much to List
    I thought the rust was heavy
  8. May 14, 2022 at 3:46 PM
    1BadTundra
    Clinton
    Too Much to List
    Here it is... I'm now at "Option 2". Took out leaf #3, incidently the one that was broken, and the good one on the other side, and left the extra leaf in. That equates to 3" of lift, then added a 2" block, and added a set of airbags. That should do it for now. Icon replied and said they are sending a new leaf out, but would be a little bit because of supply chain shortages. This setup may just work better. The bag setup is rough country air bag setup, the mounting plates are perfect so there's minimal overhang from the side. I added a 2" spacer, and Daystar cradles. With the tires on they just comfortably into the cradle.
    C.I. likes this.
  9. May 15, 2022 at 10:22 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    I bet Icon never intended the extra leaf to be a spare :D
    1BadTundra[OP] likes this.
  10. May 15, 2022 at 11:04 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Scary, ive had mine for about 8 months now and they still look brand new.
  11. May 15, 2022 at 11:12 AM
    1BadTundra
    Clinton
    Too Much to List
    Granted, I've had these for 3 years, hopefully by now they've figured out a better rust inhibitor.
  12. May 16, 2022 at 7:00 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Well, leafs tend to rust superficially, the issue here might be bad steel... too many unknowns to be sure, metal fatigue may also be involved.
    OEM springs can look rusty and even have some minor flakes, will likely last +20 years without a recoat because they're quality materials.
