Icon Rebounds with 285/70/17 Tires?
Discussion in 'Wheels & Tires' started by Buckmark1, May 9, 2019.
  1. May 9, 2019 at 4:40 AM
    Buckmark1
    Buckmark1 [OP] New Member
    TX
    2019 Cement SR5 CM - TSS Off Road 4x4
    Will this set-up work with 2019 stock suspension?
  2. May 9, 2019 at 5:00 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Buckmark1[OP] likes this.
  3. May 9, 2019 at 5:10 AM
    Buckmark1
    TX
  4. Oct 9, 2020 at 12:10 PM
    Eldeanyo
    Eldeanyo New Member
    Daniel
    2019 SR5 CM off road
    Seat covers
    Did you end up doing this? Any photos, how did it turn out?
  5. Oct 11, 2020 at 10:15 PM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Here's mine on Method 17's, +25, with 285/70r17 BFG. The front is leveled but you shouldn't have to worry about rubbing.
    JRock, Eldeanyo and junior like this.
  6. Oct 12, 2020 at 1:44 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    It will work that’s what I am running.
  7. Oct 12, 2020 at 3:03 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    You can go bigger, I’m at 295/70r17 stock suspension. Would probably go 285/75r17 with any lift.
  8. Dec 7, 2020 at 12:27 PM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    I got Falken WildPeaks that are 315 70 R17 and Icon Rebound 17x8.5. I'm thinking of going down to 285 70 r17 and keeping the Icons. What width are your Method 17s? I'm trying to get a picture of I'm going to get more wheel than tire width-wise. Thanks!
  9. Dec 7, 2020 at 1:58 PM
    Highsierraguy
    Nor Cal
    Not sure on the width but the tire definitely sticks out further than the wheel. I’ve since gotten rid of the 285/70 as I thought it looked too small. Went with Toyo AT3’s in 285/75.
  10. Dec 7, 2020 at 2:40 PM
    2point5seconds
    Sensei
    Nor Cal
    I like the 315s. Wasn't sure if I wanted to do the cab mount chop and maybe void the warranty yet.
    That's what I was worried about with the 285/70s looking like too small of a tire. dang. had them order the 285s. should have waited to hear your opinion.
  11. Dec 24, 2020 at 10:04 AM
    DedDucks
    DedDucks New Member
    Brett
    Tatum, TX
    2021 Cement SR5 Crewmax TSS 4x4
    Do you happen to have a front on shot to show the 285/70r17 on +25 offset? There is just not much out there on 285/70 with that offset. Yours looks good!
  12. Dec 24, 2020 at 11:20 AM
    Highsierraguy
    Nor Cal
    Heh well I sold them and ended up getting Toyo AT3 285/75r17. They ended up looking a little too small for my taste and I had a lot of issues balancing them.
    DedDucks[QUOTED] likes this.
  13. Jan 10, 2021 at 7:29 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I may just be dumb, but I think those are
    the Method 702s?? I can’t find them in the tundra bolt pattern at a +25 offset!
    Mind sharing where you found them?
  14. Jan 10, 2021 at 7:37 AM
    Highsierraguy
    Nor Cal
    Method 313
    CCLJ03[QUOTED] likes this.
  15. Jan 10, 2021 at 7:57 AM
    CCLJ03
    Craig
    thank you!!
    Highsierraguy[QUOTED] likes this.
