Icon leaf spring install help.
Discussion in 'ICON Vehicle Dynamics' started by Nbab23, May 23, 2023.
  1. May 23, 2023 at 8:05 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    So working on installing the Icon RXT leaf packs and dobinson shackles. Everything is going smoothly until I put in the icon springs. I can’t get the center pin of the leaf springs to line up with the hole in the axle. I believe they are oriented correctly with the big wrap to the front?? Wondering if I am missing something. Everything I read said the military wrap or the big loop goes to the front.
  2. May 23, 2023 at 8:08 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I see there are 3 holes in the axle, does it go into the front one and not the center?
  3. May 23, 2023 at 8:11 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Or does the axle need to come forward some? Now that I look at it from further back it looks like it does.
  4. May 23, 2023 at 8:13 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Axle needs to come forward. Mine shifted and I spent way too long trying to figure this out. I used a ratchet strap to pull it forward and get the leaf pack pin into the center hole on the axle plate.
    memario1214, Tundra234 and Nbab23[OP] like this.
  5. May 23, 2023 at 8:15 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Awesome. Thanks. I was going to lose my mind if I pressed out the wrong side for new bushings.
  6. May 23, 2023 at 8:20 AM
    It should go in the center hole.
    Nbab23[QUOTED][OP] likes this.
  7. May 23, 2023 at 8:22 AM
    If I recall, it may move a little easier if you loosen the ubolts on the other side.
    Nbab23[OP] and AZTundra like this.
  8. May 23, 2023 at 8:27 AM
    AZTundra
    Paul
    Phoenix, AZ
    This should definitely help give it a little more maneuverability to assist with aligning the pin.
    Nbab23[OP] and Tundra234[QUOTED] like this.
  9. May 23, 2023 at 9:13 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Thanks all. I did loosen the U bolts a bit on the other side and ratcheted it in place. Time to rinse and repeat on the other side!
    Tundra234 and TRDFerguson like this.
  10. May 23, 2023 at 2:03 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Finished and about to take it for a test drive. Much better stance with the icons option 1, dobinson shackles/bushings and some sumo springs.
  11. May 24, 2023 at 4:45 PM
    GreatWhiteGax
    GreatWhiteGax New Member
    2016 SR5 Silver
    Leveling Kit, Wheels & Tires
    Just started this same surgery yesterday. I’m running option 3 on the icons and can’t seem to get the shackle lined up with the rear spring hole. They’re a lot beefier way more droop than stick springs. Did you attach the front spring bolt first and then the rear shackle or visa versa? @Nbab23 any tips much appreciated!
    Nbab23[OP] likes this.
  12. May 24, 2023 at 4:49 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Bolt in the front first, and you'll need a LOT of droop to get the rear shackle eyes lined up. Make sure to watch your brake and ABS line (disconnect them) and do the extension brackets afterwards.
  13. May 24, 2023 at 5:51 PM
    GreatWhiteGax
    2016 SR5 Silver
    @TRDFerguson That did the trick! Got ‘er in there. Icon instructions don’t mention anything about greasing their bushings, I’m assuming their pre -greased??
  14. May 24, 2023 at 7:04 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Agreed. I think a big thing is jacking up the frame high enough so you are able to lower the axle as far as needed to get everything lined up and watching/disconnecting the ABS and brake line brackets in the process. My caliper was about a 1/2 from the ground when I was installing it. I probably should have went higher with the frame prior to starting as I was cutting it close.
  15. May 24, 2023 at 7:07 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    As far as pre-greased, I don't think they are. At least not that I saw. I replaced my shackles with Dobinsons which came with their own bushings so I pressed out the rear bushing on the Icon leaf and kept the front as is. I greased the inside of both pretty heavily with a silicone based grease
    GreatWhiteGax[QUOTED] likes this.
  16. Jun 1, 2024 at 3:45 PM
    Mizterusa
    Mizterusa New Member
    2007 Toyota Tundra crewmax SR5 TRD
    S&B intake, MBRP dual exhaust and a killa sound system
    So it's printed "front" right on the top and it looks in ur Pic that it's facing the rear?? Also they state in both packs that these will not work with TRD sway bar so they do still clear?
  17. Jun 3, 2024 at 10:28 AM
    Mizterusa
    I think fronts always 1st
  18. Jun 3, 2024 at 10:42 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Leaf Springs-always put the front solid hangar bolt in loose. Line up spring center pins and loosely put u-bolts over but
    don't tighten. Rear hangar last loosely, insert all the bolts loosely before you even begin to think of tightening anything.
    It should be a loose hanging mass before you attempt to tighten any of the nuts/bolts. If you have all the threads started
    and it's in place you could drop the shock in now as it might be a bit easier before the spring is tight but don't let it
    push the u-bolt plate away. I've done more than a few leaf spring kits.
  19. Jun 3, 2024 at 10:44 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Curious as to what made you decide on SumoSprings? I put a set on the front of my Land Cruiser to help reduce dive impacts.
    I love them.
  20. Jun 8, 2024 at 3:33 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    No it’s not. That’s just a number on there. And no issues clearing the rear sway bar thankfully. I didn’t even know that icon had that warning.
  21. Jun 8, 2024 at 3:35 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Since I raised everything in the rear I figured I’d use them like a longer bump stop and they can double when I have the truck loaded up. I don’t tow or haul that much but I wanted the extra support of the springs when I do.
    Cruiserpilot[QUOTED] likes this.
  22. Jun 8, 2024 at 5:13 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That's exactly what they are designed for. They are a very cool invention. They make excellent 'soft' bumpstops.
